Question about GE Monogram ZISS420NRSS 42" Built-In Side-By-Side Refrigerator (ZIS-S420NRSS, ZIS S420NRSS)
Water line connectors/tubing? GE Monogram Refrigerator
We are trying to replace a water line that runs from the lower right corner of the back of the refrigerator to the lower left corner of the front (runs under the fridge).
We have made two trips to HD and Lowes with no success - each connector does not fit. I have tried to track down the parts online and can find the quick connect but cannot locate what size the existing tubing is coming from the underside of the refrigerator. It's not 1/4" and although the quick connect is sold as 5/16", a 5/16" union with inserts does not work either. Anyone know what ID/OD we are dealing with on this tubing?
  • 25 Answers
Go to your local appliance parts dealer , they should be able to get the parts you need
Posted on May 21, 2009
Can a water in the refrigerator side by side be fixed
Posted on Jul 09, 2009
My GE monogram refrigerator keeps freezing up. My repair man has replaced the thermistor and the control board, and neither fixed the problem. He told me to contact GE, but I can't seem to find a number to...
This might seem silly but sometimes having the Controls turned to max will cause a refrigerator or freezer to freeze up.
Another problem could be if there's a water input system that runs through the inside of the unit for ice-makers or water dispenser internally. It could be a broken/worn tubing that needs to be replaced. If there's any water running on the outside or condensation on the tube it would explain the extra water or water vapor that's causing the refrigerator to freeze up.
Does there seem to be a source of the ice, or any place that's specifically worse than others.
Aug 31, 2013 | GE Monogram ZICS360NRRH C... Bottom...
I have a 2004 GE Monogram zisw420dmc refer. There are often small drips on the floor under the lower left and right corners of the freezer door. The fiberboard and stainless door cover have become damaged...
The drain in the freezer behind back lower panel
needs opening. You can see it at the bottom of the back panel
underneath the evaporator coils. (The cold coils)
Run Hot water in the drain until it clears or use a hairdryer.
When the defrost melts the water it goes down the drain
If the drain is clogged with Ice or ? The defrost water
overflows into the ref. or freezer or on floor
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If you need more help GO HERE:
http://www.applianceaid.com/procedures.html
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
Sep 23, 2011 | GE Monogram Side by Side Refrigerator
Problem with the GE Monogram ZISS420DMSS Side by Side Refrigerator. Defrost Drain tube clogged. Icicles form in the frezer compartment. How do I fix? Thanks.
Leo Ponder
imufo2
Aug 17, 2011 | GE Monogram® ZISS420DMSS Side by Side...
Flow from water dispenser has decreased by half- How can we increase this back to normal?
replace the water filter located inside the refrigerator sides upper right hand corner,a quarter turn counter-clockwise will remove it
Jan 01, 2011 | GE Monogram Side by Side Refrigerator
No water will come out of the door
At the bottom of the freezer door ( remove the kick plate ) , there will be a water line . Follow this line , about 6 " to a connector . Push in on the white ring and pull out the line , at the same time . Activate the water dispensor pad and see if water flows from the line under the refrig . If it does , then the line in the door is frozen . Either raise the freezer temp for several days , so the line in the door will thaw , or , I have heard using an air tank will blow the ice out of the line in the door . If no water comes from the line under the refrig , while activating the pad , then replace the water valve , behind the refrig , the piece the wall water line connects to on the refrig . GE has a dispensor heater pt. # WR41X10173 to stop this freezing and it comes with instructions .
May 25, 2010 | GE Profile 25.6 Cu. Ft. Side-by-Side...
GE Monogram Built-in refrig has blocked evaporator drain.
You should be able to see the drain under the coil. Part 804 on this diagram. Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing.
Aug 25, 2009 | GE Monogram ZISS420NRSS 42" Built-In...
Ice build up bottom of freezer and water on floor GE Monogram
I had the same problem. The drain tube is located below the pan below the fins at the rear of your freezer. The drain tube has a trap (s-shaped curve) to prevent air flow out of the freezer. The problem is that water gets in this tube and freezes. I took the sheet metal cover off the back, got a turkey baster and flexible tube, and continuously flushed hot water (after the freezer had been turned off around an hour to thaw). Eventually the plug gave way.
Apr 09, 2009 | GE Monogram ZICS360NR Bottom Freezer...
How to locate the water filter
Be sure to turn off the water valve before you start.
The water tube is probably kinked at the front lower left corner. Take the front lower grill off of the refrigerator and open the left door (freezer) and see if the translucent plastic tube is kinked where it comes from the bottom of the refrigerator and goes up into the door.
If it is, there is plenty of tubing to allow you to pull it out of the connector at the corner and cut off the kinked part and re-insert the tube.
Turn the water valve back on.
(This was the problem with my fridge and I had to show the Sears technician.  He had already told me to call a plumber and get a dedicated water line due to low water pressure!  Imagine the cost if I had believed him.  Works great - good flow and no leaks.)
Hope this helps.
Nov 23, 2008 | Kenmore 57029 Side by Side Refrigerator
Ge monogram sidebyside refrigerator
check the flap thats lets the ice come out,i don't think its closing all the way,thats why your getting frost,the water dispenser problem is the water inlet valve on the lower back of frig. and should be replaced,let me know more-mike
Oct 21, 2008 | GE Monogram ZIR36NMRH Refrigerator
Ge monogram water line
the water dispenser does not dispense water, although i can hear the motor running, but water is reaching the ice maker.
any tips?
You may have a clogged water line or filter something blocking the flow of the water or you may have to replace the filter or a water line – it may have a defective sending unit / pump and it would be wise to check it out with a regular service tech and to also check your owner’s manual for troubleshooting.
Apr 14, 2008 | GE Monogram® ZISS420DMSS Side by Side...
GE Monogram ZISS420NRSS 42" Built-In Side-By-Side Refrigerator (ZIS-S420NRSS, ZIS S420NRSS) Logo
471 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
