Question about Epson Artisan 710 AllInOne InkJet Printer
Need waste ink reset counter for epson artisan 710
Getting message that the service life of ink pads are near the end.
Lonewolf1038
  • 6 Answers
SOURCE: epson stylus photo r320 ink pad relacement
Here's 3 things you can do to get around this...depending if your printer is new and still under warranty or not (do NOT void your warranty!).
I have used all 3, but the third one was a lifesaver (AND money-saver!). About once a year I have to reset the printer using #2, but other than that....#3 is the greatest!!!
1. Try resetting it by, unplugging the power cord then while holding down the POWER STOP and MAINTENANCE buttons simultaneously while replugging the power cord caused a reset to zero on the counter. You will still have to replace the pads or redirect the waste ink tube to a receptacle on the outside of the printer, hope this helps?
2. If you go to inkjetprinterhelp.us there you will find the ssc service utility. Once you open the page click on the service utility and then choose the english version unless you can spk russian.If you then scroll to the bottom of the page and install the prog. Once you have installed the prog you will get the ssc utility logo in your bottom tray. Right click the icon and then select reset protection counter from the protection counter drop down. Once you have done this restart your computer and this should reset the system.
3. INSTALL AN EXTERNAL WASTE TANK and forget all about those gunky ink pads forever!
On the left rear of these printers is a small trapdoor held by a single screw.
Remove it, look inside (down and to your left) and you'll see the waste ink tube.
The tube is free at one end, and with a suitably curved piece of wire you can hook it and wangle the end out through the opening (you may dislodge a small piece of plastic in the process -- just put it back where it was, it's only a vibration damper.) I found the tube to be rather short....so I added an extension since I do not have room directly behind my printer for a container. I used the tubing you use with oxygen tanks or fish tank bubblers. They also make a little plastic connector so you can join the two together.
At this point, you're almost there.
All you need now is a suitable container for the waste ink, and I drilled a small hole in the trapdoor cover so you can put it back on without pinching the tube (or you could just leave it off.)
The container is a small square one with a snap-on lid, approx. 60mm square and holding about 150ml -- they're sold in sets of three for a few cents and are for making ice-blocks etc. in your freezer. Any small container will work.
Make a hole in the lid (slightly larger than the tube to let air escape) insert the tube and forget about the internal pads forever.
I've had mine in place for almost 2 yrs now and it works like a charm. If you need photos, let me know and I have a couple I can send you.
Posted on Jul 01, 2008
SOURCE: Need To Replace The Waste Ink Pad on my Epson Stylus C66
I modified a little what Worldvet had done. I opened the door as if to change the ink cartridges. I first used a pair of needle nosed pliers and carefully took out the sponge type pad which is along bottom of the printhead travel lane. One will see the two center plactic guides within this lane. The sponge is very delicate, so be very gentle in removing it. It has ink residue in it so use gloves if necessary and upon removal place the sponge on a paper towel folded in triplicate so the ink does not bleed through the towel. Remember to what position it was before removal, so there is no problem when you try to replace the sponge after cleaning.
The second sponge I removed as follows: With the power on, I pressed the ink cartridge removal light (red) (far left) once. This moved the print head to the "far left", before the position to change cartridges. With the power still on and the printhead to the far left, I was able to very gently (with the same needlenose Pliers) remove the sponge under where the printhead was parked. It too is very delicate and be careful not to rip it. It too, one will find, has two plastic slots on the botton which the sponge will have to be returned into. I then turned the printer off, which caused the printer head to return to the parked position.
I took both sponges, and with Alcohol (Pharmacy type), I placed the sponges in a disposable plastic bowl and filled it with the alcohol. I gently used the needle nosed pliers (Closed) as a device to gently press on the sponges which were submerged into the alcohol. I continued to alternate up and down the sponge pads, causing the alcohol to dilute and clean the pads. When the alcohol became saturated with the ink from the pads, I took the pads out of the alcohol bowl and placed the pads on a triple folded paper towel so the remaining ink would not bleed through anything.
I then took the bowl of alcohol/ink and while I flushed the toilet and the water was going down, I emptied the alcohol down the middle of the water spout as the toilet water was completing its flush. This keeps any ink from touching any porcelion.
I then refilled the plastic bowl again with fresh alcohol and resubmersed the pads, just incase there was any ink still left in them. Upon pressing on the pads and the alcohol remained clear (indicating all the ink was removed) I again used another set of paper towels, trippled, and placed the pads onto the paper towels, and squezzed them dry. I disposed of the alcohol the same as before.
I then, first replaced the large pad onto the printhead travel lane, back into the same position, being careful that the holes and slots fits back into its proper position and the edges are tucked under the proper hooks (little plastic hooks attached to the side of the travel lane).
Upon reinstallation I pressed gently on the pad to make sure it was secure.
Replacing the second pad, I again turned on the printer and pressed the ink replacement light (red), same as before, causing the printhead to travel to the far left as before. I then very carefully replaced the second pad into the slot from which it came from.
After I made sure the second pad was secure in its proper position, I pressed the ink replacement light twice, causing the printhead to return back to the parking position. I had already reset the counter, so that was not neccessary. I returned to the computer and printed a test page to make sure the printer was working properly, at which time it was, so I therefore returned to what I was doing and the Service Warning was cleared. My fingers got a little ink; but what the heck, soap will take care of that! Good for another 20,000 pages. Hope this helps, not as bad a it sounds.
Posted on Mar 26, 2009
  • 5 Answers
SOURCE: EPSON 2200 - Waste Ink Pad Replacement
You can replace the pads yourself.... I wouldn't really mess with it though. There are other ways Google search "Waste Ink Epson 2200" to see how to setup an external tank.. I have mine setup this way and its been no problem.... If you're set on taking them out remove the screws from the sides and middle and the bottom will drop away and reveal the pads.
Posted on Apr 16, 2009
rioglen
  • 95 Answers
SOURCE: Epson R220 parts near end of life error
its a tweak with epson.... they have a counter there that intentionally stops it from working even through your printer is still in good condition.
there is an available driver that could correct that depending on the operating system you are using. i think if i maybe correct it only works with and o/s that is winxp.
the drivers name is inkpad reset utilty.
try to check the website www.epson.com/ipr for the inkpad reset utility
Posted on Sep 10, 2009
pineworks
  • 4041 Answers
SOURCE: Have a need to reset the waste ink counter on an
Hi
I looked around for you and I have found some links for you to look at it tells you what you need to do, just click on the links and have a look.
Link 1 = http://www.wasteink.co.uk/waste-ink-mods/epson-artisan-800-mod/
Link 2 = http://freedomtoprint.com/epson-inkjet-printer-reviews/epson/artisan-800/
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Jan 31, 2010
End of service for epson wf 7610
If your Epson WorkForce WF-7610 printer shows error message "The Printer's Ink Pads at the end of Their service life" and Epson WorkForce WF-7610 printer has a red light blinking problem: You should be download and reset Epson WorkForce WF-7610 printer Waste Ink Pads Counter with Epson WorkForce WF-7610 Resetter.
Go to this link, you should be able to download the resetter and follow the procedures step by step.
Reset Epson WorkForce WF 7610 End of Service Life Error message Wic Reset...
Jul 22, 2017 | Epson Office Equipment & Supplies
How can reset epson artisan 730 using ssc service4.30 in winddows 7/8
Download WIC Reset Utility - Free - 2Manuals.com
www.2manuals.com > ... > WIC_RESET
Operation Systems: Windows XP, Windows 7, 8, 10, Mac OS ... THE WIC ResetUtility WILL RESET Your Epson Inkjet Printers WASTE INK COUNTERS ... 700, Artisan 710, Artisan 720, Artisan 725, Artisan 730, Artisan 800, Artisan 810, Artisan 830, .... Q.: If I buy 5 RESET KEYs I can use them for different printer models?
WIC Reset Utility - Reset Epson printers Waste ink Counters
wic-reset-utility.blogspot.com/
Oct 5, 2014 - Artisan 720.725\Artisan 730\Artisan 800\Artisan 810\Artisan 830 .... If I buy 5 Reset Keys CAN I use them for different printer models? .... The Windows 7 WICReset Utility - for Waste Ink Pad Counter reset - Service ... Reset epson printer protection counter using ssc service utility, reseter epson r220 [...]
Printer Manual: SSC Service Utility for Epson Stylus Printers
printermanua.blogspot.com/2014/.../ssc-service-utility-for-epson-stylus.h...
Feb 22, 2014 - Problems with Epson printer, the red and greenness lightheaded ...
Jan 27, 2016 | Epson PRINTER,ARTISAN 730
Epson stylus TX121 printer's ink pads are at the end of their service life
My printer name
Epson tx121
it's show "The printer's ink pads are nearing the end of their service life. Please contact Epson support".
May 14, 2012 | Epson Stylus TX120 Inkjet Multifunction...
The printer's ink pads are at the end of their service life. Please contact Epson support.
Nov 30, 2011 | Epson Stylus Multifunction Inkjet Printer/...
I switch my CX6600 on but all I get is the exclamation mark light up. |The displau says that par6ts are at the end of their service life. No warning! Anyone help please
That message indicates that the porous waste ink pads inside your product are near the end of their service life. Epson recommends replacing the printer, but if you want to continue using it, I'd suggest having the printer serviced at an Epson Customer Care Center. You may also be able to have the ink pads replaced by an independent service provider and use the Ink Pad Reset Utility to reset the Ink Pad Counter to continue using the printer. However, replacement of ink pads is relatively expensive and may not be a good investment for lower cost printers because the printers' other components also may be near the end of usable life. Hope that helps!
Mar 03, 2011 | Epson Stylus CX6600 All-In-One InkJet...
Parts inside your printer are near the end of their service life. See your printer documentation. _ Epson R200 printer.
Regarding the Epson Artisan 800, I must thank FixYa and ask that the search for a solution be discontinued.Yesterday, I had an unfortunate accident while trying to unclog the print head which had been printing poorly over the last three months. I used a syringe to force a solvent solution through the clogged head. To my utter surprise the supply line exploded with a loud "POP" meanwhile spraying ink all over the place. At this point it was clear that it was pointless trying to redeem the old Artisan 800. Thank you FixYa. Henry.
Feb 27, 2011 | Epson Stylus Photo R200 InkJet Printer
Parts inside end life
Q: What should I do if my printer driver displays the message parts inside my printer are reaching their end of service life?
A: See the Epson Ink Pad Reset Utility page.
Epson Ink Pads Reset Utility
If your product is displaying an end of life service message, please view and complete the required information below to proceed.
Please explain the message I am getting in my printer driver that says parts inside my printer are reaching their end of service life.
Like so many other products, all Epson consumer ink jet products have a finite life span due to component wear during normal use. At some point, the product will reach a condition where either satisfactory print quality cannot be maintained or components have reached the end of their usable life. This is the normal product life cycle for highly mechanical devices like printers. This message is a warning that certain parts have reached the end of their usable life and that your printer will no longer work until it is serviced.
What parts are we talking about?
The message refers to the ink pads, which are actually a number of porous pads in the printer that collect, distribute, and very importantly contain the ink that is not used on printed pages. Ink is collected by these pads during the initial setup of the product, during cleaning cycles and when printing borderless photographs. Most users will not receive this message before the printer is replaced for other reasons. Some high volume users or those who use the printer for many years may receive this message about ink pads before other components reach the end of their usable life.
Why does my printer stop functioning when I get the message?
Epson is committed to ensuring the proper operation of all our devices to minimize the risks of property damage or personal injury during the lifespan of the product. The printers are designed to stop operating at the point where further use without replacing the ink pads could create risks of property damage from ink spills or safety issues related to excess ink contacting an electrical component
Is there anything I can do to continue using my printer?
Epson recommends replacing the printer, but if you want to continue using it, Epson recommends having the printer serviced at an Epson Customer Care Center. You may also be able to have the ink pads replaced by an independent service provider and use the Ink Pad Reset Utility to reset the Ink Pad Counter to continue using the printer. Please note that replacement of ink pads is relatively expensive and may not be a good investment for lower cost printers because the printers' other components also may be near the end of usable life. Epson does not recommend ink pad replacement by users without technical training or resetting the Ink Pad Counter without replacing the ink pads.
Note: This utility is for Windows XP and Vista operating systems only. We hope to develop an option for Mac users as well; however, we do not have an ETA or the OS requirement at this time.
To download this utility, please complete all fields below, select the agreement check-box and click Download. Required fields are noted with an asterisk(*). Some models may require you to be redirected to another website to finalize the process.
Go to this link to complete the agreement to recieve the Epson Ink Pad Reset Utility.
http://www.epson.com/cgi-bin/Store/support/InkPadsForm.jsp
Trust this is helpful. :)
Dec 09, 2010 | Epson Stylus Photo 1400 Printer
Printer won't printer as message says parts are
Part are end life cycle : waste ink pad full. Need to reset waste ink counter. SSc ver 4.3 support RX 620 and 640. U can try using printer model RX 640. Menu Protection Counter, Show current value for checking. Reset protection counter. Or Try to find RX630 adjusment at indoreset,blogspot.com. Don't forget to replace or wash the pad. Or extend outlet waste ink pipe to outside.
Jun 28, 2009 | Epson RX620 All-In-One InkJet Photo...
Printer send s message Life of parts ending
The "end of life" message means that the waste pads are full of waste ink.
You need to either:
  • get the printer serviced at an Epson service center
    OR
  • install an external waste ink counter and reset the waste ink/protection counter.
All the information you need to install an external waste ink tank is available from here:
http://www.continuousink.info/forum/viewtopic.php?t=4096
Resetting the waste ink counter is easily done using the IPR utility which you can read more about and find downloads for, from here:
http://www.wasteink.co.uk/epson-ipr-reset/
Hope that helps..
Martin
May 19, 2009 | Epson Stylus R340 InkJet Photo Printer
i have a problem with my printer epson stylus C90. may i know what to do when parts of my printer are near the end of their life service.? how can i fix it?
Dec 07, 2008 | Epson Stylus Photo R300 InkJet Printer
Epson Artisan 710 AllInOne InkJet Printer Logo
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
