Question about AEG B2100-4 Electric Single Oven
I have an electrolux D2100-4m and have just replaced the heating element. However when I removed the element cover there was a taped seal that covered a hole at the back of the oven. This was damaged and i need to find out what I need to replace it with - it is not listed as a part with AEG
  • 139 Answers
SOURCE: AEG double oven- fan assisted not heating up
you oven element has failed.
it is located at the back of most electric ovens sometimes at the top,,
the insulation of the element has failed and when you come to remove it you will see visually see the damage... its easy to replace as there are only wires attached to it and only a few screws to undue to get to it..
hope this helps cheers
the washdoctor
Posted on Aug 24, 2008
barkencoa
  • 3463 Answers
SOURCE: aeg competence b2190-1m oven not heating
If the fan is working o/k, then you need replace the oven element.
To access this, remove inner rear cover of oven, there you will see the circular element.
Unscrew the screws securing it ,and remove element.
Detach wires and transfer to new element, be careful not to lose the wires behind the oven rear, refit element and rear cover.
please rate my solution.
Thanks
Posted on Jan 27, 2009
barkencoa
  • 3463 Answers
SOURCE: my AEG Electrolux fan assisted oven does not heat
If the fan and light work o/k, then you need to replace the oven element.
Please rate my solution.
Thanks.
Posted on Nov 03, 2009
barkencoa
  • 3463 Answers
SOURCE: AEG Competence Oven not working
If you are certain that the element is o/k, and it is not heating, then thwere are 2 possibilitues.
1- the oven thermostat could be faulty, whereby it is giving a feed to the element.
2-some ovens have a fan only setting, as well as heat and fan, make sure that it is not on a fan only setting.
Hope this helps.
Posted on Feb 05, 2010
barkencoa
  • 3463 Answers
SOURCE: How do i replace the
If it is a fan assisted oven, remove the screws securing the rear cover inside the oven compartment, remove cover, and you should see the oven element there.
Undo the element, and fit new one.
Posted on Aug 04, 2010
Testimonial: "Very helpfull much appreciated."
Electrolux microwave oven. model no. NF40065 browning element not working
The safest way to check it is to disconnect it from the mains. wait 15minutes in case the capacitor is still charged. Remove the cover and check for a low resistance across the element. It should read less that 180R.
It is a standard element so spares from a model number near to yours may fit.
Jan 03, 2018 | Electrolux Ovens
No heat when fn oven is on light works as does grill & base
If the fan is working o/k, then you need to replace the oven element located behind a removeable cover at the rear of the oven compartment.
Nov 23, 2010 | Electrolux EOB6632 Electric Single Oven
Elextrolux Oven stopped generating heat. Grill working ok. Sparks came out of Fan area followed by cloud of ash. What could be the possible cause and what part could be required ?
Hi.
It will be the oven element that has failed.
This is located at the rear of the oven compartment where the the fan is.
Remove the cover at the rear of the oven there you will see the oven element, a very easy job to replace.
Nov 10, 2010 | Electrolux 30" Built-In Single Electric...
My cooker won't heat up
remove the rear panel covering the fan (4 screws) from inside oven. The element is round the fan. you may see where the element has burnt through or split or distorted the element.
Jul 23, 2010 | Electrolux Ovens
Heard a pop/bang and now no heat
Sounds like the oven element has blown.
To fit a new one, remove cover at rear of inner oven compartment, there you will see the round fan element.
Apr 06, 2010 | Electrolux EOD5330 Ultrafan Electric...
EOD6330 main oven - fan works but oven does not heat up, do I need a new element? LAW
More than likely it is the element that has failed.
This usually located at rear of oven compartment behind removeable cover.
Jan 30, 2010 | Electrolux EOD6330 Ultrafan Electric...
The fan works but there is no heat
The problem is usually caused by a faulty oven element.
This is usually located at the rear of the oven compartment, behind a removeable cover.
Hope this helps.
Dec 19, 2009 | Electrolux EOB5630 Ultrafan Electric...
My bottom oven is not heating up?
If it is an all electric fan assisted oven, and the fan is working o/k, then the oven element has probably failed.
This is located at the rear of the oven compartment behind a removeable cover.
Hope this helps.
Dec 09, 2009 | AEG Ovens
Electrolux EOB5630
Not sure that I can help but will certainly try. You need to check to see if the power is getting to the oven. As the grill, light and fan are working it seems that it is. With the Oven not heating up I would suggest that it is possibly the Oven Element. Usually to check these you need to remove the cover inside the oven and also the back cover. You will probably find the power is getting to the element but the element is not working and needs replacing. Before removing it MAKE SURE YOU TURN OFF THE POWER TO THE OVEN. Should only be 2 or 3 wires going to the element which will need to be removed before removal. Usually only a couple of screws hold the element in and once removed you may have to wiggle the element a little to get it out. Replacement is just a reversal of the removal procedure. I had to replace the one in our oven 2 weeks ago as we had the same problem. It is fine now and was only the element. Just MAKE SURE you TURN OFF THE POWER before removing the element. Hope this helps.
regards
Bryan
Nov 16, 2007 | Electrolux EOB6636X Ultrafan Electric...
AEG B2100-4 Electric Single Oven Logo
Top AEG Ovens Experts
ashburton
Sal De
Steve
Are you an AEG Oven Expert? Answer questions, earn points and help others
