Question about De'Longhi En520.S Nespresso Lattissima Plus Coffee Maker, Silver
I've got nespresso lattissima, when I insert the milk compartment, the two light don't stop flashing! HELP! Thanks
Nespresso latisima The milk stopped frothing. Tried to clean the container but it still doesn't do it.
NESPRESSO LATTISSIMA Instructions Manual
Look under troubleshooting...uhhhh...perhaps page 7. They specifically talk about milk has stopped or not giving good froth.
Semper Fi,
Z
Feb 14, 2018 | Nespresso Coffee Makers & Espresso...
Cappuccino and latte macchiato buttons blinking
The unit is heating the steam - the lights should switch to contant once the right temperature is reached. Make sure to always descale the machine if the cappuccino button light turns orange.
Mar 29, 2014 | De'Longhi Nespresso Lattissima Plus...
Milk warmer container on side of machine
Check the heater or the thermal fuse, they may be busted.
Mar 12, 2014 | Nespresso Lattissima 660.R
I have a Nespresso Lattisima and all four lights are blinking four times in quick succession and nothing is working. I've tried emptying it out and it's done that, but still the same problem.
Your machine has almost certainly entered the water quality mode. (Water hardness setting). This is very easy to fix. Switch machine off. Before switching back on press and hold any off the following buttons: Latte Macchaito (top right) for soft water, Cappuccino (bottom right) for medium water or finally both of them for hard water. While holding the correct buttons switch the machine back on BUT hold for approx. 10 seconds or until all lights stop flashing, (APART FROM THE BUTTON YOUR HOLDING). This will reset the machine and you're good to go. Regards Coffee Engineer!
Jan 17, 2013 | Nespresso Lattissima 660.R
Lattissima red light keeps flashing
Take the water tank off and dry the bottom of it.
May 25, 2012 | Nespresso Lattissima 660.R
Blinking orange light on model D290 and it is not full of capsules
I solved this problem by realizing that I had forgotten to insert back a certain piece of plastic, that I had taken out to clean. this caused the blinking light
Jan 04, 2010 | Nespresso Coffee Makers & Espresso...
I cannot get my Nespresso Lattissima to clean out milk when clean button is pressed, nothing happens. Can you help me?
Have to pull out the entire container and push it back into the unit so it fully connects with the machine. Then try again.
Dec 04, 2009 | Nespresso Lattissima 660.R
Coffee not hot enough Is there a way to modify the factory settings to make coffee/milk warmer for the Nespresso Latissima machine?
Before placing first coffee capsule in the machine, run the large espresso cup button into a cup (clear water will come out). This primes the machine and makes for hotter coffee.
Oct 03, 2009 | Nespresso Lattissima 660.R
De'Longhi En520.S Nespresso Lattissima Plus Coffee Maker, Silver Logo
42 people viewed this question
Top De'Longhi Coffee Makers & Espresso Machines Experts
ray gallant
Tom Chichester
Shrikant Shinde
Shrikant Shinde
Level 1 Expert
Are you a De'Longhi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
