Question about 03177 Speedometer Cable C70Z17260C, C8GY17260A
2003 honda xr250l sat in shed for 2years everything works except for speedo all 8's on display (battery was flat and needed replacing)
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 133 Answers
I think may be condensation has got in to the speedo would recomend replaement off the speedo
Posted on Dec 31, 2013
07 chevy uplander ran out of fuel,with 1/8 tank on way,to store now the battery save active displays when I attempt to start the van like,it set off an alarm. How can I get it running
Battery Saver Active
Refer to Charging System Description and Operation
The BATTERY SAVER ACTIVE message will display on the driver information center (DIC) when the vehicle enters a load shed 2 event. Refer to Load Shed System Description and Operation for load shed 2 setting criteria.
Electrical Power Management
The electrical power management (EPM) is used to monitor and control the charging system and alert the driver of possible problems within the charging system. The EPM system makes the most efficient use of the generator output, improves the battery state-of-charge (SOC), extends battery life, and manages system electrical loads.
The load shed operation is a means of reducing electrical loads during a low voltage or low battery SOC condition.
The idle boost operation is a means of improving generator performance during a low voltage or low battery SOC condition.
Each EPM function, either idle boost or load shed, is discrete. No 2 functions are active at the same time. Idle boost is activated in incremental steps, idle boost 1 must be active before idle boost 2 can be active. The criteria used by the body control module (BCM) to regulate EPM are outlined below:
I dought you will be able to get it running , except by luck . The best thing you could do is have a qualified repair shop diagnose it . The first place to start would be to hook up to a factory diagnostic scan tool , Check for DTC'S - diagnostic trouble codes .
Jan 28, 2017 | 2007 Chevrolet Uplander
Where can I find a replacement roof panel for a Leisure Stronghold 10x8 shed?
Probably not a very good answer since the Owner / Installation Manual for this shed specifically states "do not contact the store....". Instead, follow instructions in the manual and contact US Leisure at 1-877-638-7056. Ext 6. Get ready for voice mail and punch the buttons HE...LL. These people apparently cannot hire folks to run their phones or customer service department. Sat on hold and running buttons in their system for 35 minutes the other day before giving up.
Aug 12, 2014 | Us Leisure Storage Building. Stronghold 10...
Help with xr250l that won't start well.
Hi, John and the usual suspects are:
1. Enrichner system plugged, not properly functioning or improperly operated.
2. Fuel overflow line pinched or clogged.
3. Restricted fuel supply.
4. Gas cap and or fuel tank not venting properly.
5. Plugged slow jet or passages.
6. Inlet system air leak.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Xr hard start solved Heres the fix
How to kick start cold XR250
Honda XR250R Service Manual
http://www.partsfish.com/page/oem-parts-for-honda
Honda XR250R Owner Manual
Jun 25, 2012 | 1998 Honda XR 250 R
Leave honda crv 2003 in parking lot while on vacation (7 days) come back car won't start I mean nothing, need to jump start and it's okay, Happened twice I left with everything off and shut with...
not really, except unhook the battery. there are several things constantly running all the time. 'clock,computer, etc. eventially, the battery will drain. then again, your battery may be weak. an auto parts store will test it for free.
Sep 15, 2011 | 2003 Honda CR-V
2003 honda shadow spirit speedo quit working
Check front rim where speedo cable connects.Speedo's are manual so 90% of the time the problem lies with the cable.
Jul 17, 2011 | 2003 Honda VT 750 CD Shadow A.C.E. Deluxe
Hi, I am considering purchasing a 1984 Honda vt 250cc everything is in working order except the speedo the owner has had a small digital one fitted. The fuel tank will also need repairing or replacing...
Getting parts will be difficult. You can coat the inside of the gas tank with a product called " KREEM ". This will stop the leak permanently. Google kreem and you can find where to buy it and even view videos on how to use it. Please rate my answer. Thanks.
May 10, 2011 | Honda VT 250 F Motorcycles
How much oil in xr250r??
Oil change only...
XR250L XR250R................................. 1.3 liters (1.37 US qt)
XR400R.............................................. 1.7 liters (1.8 US qt)
Oil & filter change...
XR250L XR250R................................. 1.4 liters (1.5 US qt)
XR400R.............................................. 1.8 liters (1.9 US qt)
After engine rebuild...
XR250R, 1986 through 1995 XR250L..... 1.6 liters (1.7 US qt)
1996 and later XR250R........................ 1.7 liters (1.8 US qt)
XR400R.............................................. 2.2 liters (2.3 US qt)
Jul 11, 2009 | 1997 Honda XR 250 R
03177 Speedometer Cable C70Z17260C, C8GY17260A Logo
64 people viewed this question
Top Dorman Vehicle Parts & Accessories Experts
yobo007
yobo007
cgswift
Level 1 Expert
Willie Keisser
Are you a Dorman Vehicle Part and Accessory Expert? Answer questions, earn points and help others
