Question about Panasonic PT-56DLX76 Television
PT-56DLX76 IRIS Malfunction - Panasonic PT-56DLX76 Television
4 Suggested Answers
hardrocko
  • 1476 Answers
SOURCE: Resetting the timer for the
stephanie286,
Here is the porcedure:
The procedure is a little bit tricky so that you do not do it accidentally.
1. Turn on the television.
2. Press the volume down button on the TV display (not the remote)
3. While pressing the volume button, press the "split" or "PIP" button on the remote.
If it works you will see a message saying the lamp timer was reset to 0 and the indicator will turn off.
Thanks for using FixYa and for the great rating.
hardrocko
Posted on Nov 30, 2010
  • 608 Answers
SOURCE: pt-56dlx76 panasonic light flashes red 3 times. I
I had a similar problem with my 42 in Philips LCD HDTV. Here was the problem. My Power Supply Board had several bad capacitors. I opened my TV (warranty was expired ofcourse) and found four bulged capacitors on the PSB. Many major electronics companiesPhilips/Magnavox, Sony, Panasonic, and others were sold capacitors that failedin 2-5 years instead of 10-20. Thecapacitors fail prematurely due to a lack of preservatives. Unfortunately, they were installed in allsorts of devices and cause a wide range of failure problems. Here are some options for you. 1. Have it fixed by a professional $$$$$$$??????? (Is itunder warranty?) Remember, TVs CONTAINHIGH VOLTAGE AND CAN KILL YOU! Do this at your own risk. 2. Open your TV and find PSB. (The board that the power cordplugs into) Check for faulty caps. If you find some (bulged or leaking) bad capsreplace the entire board. The entireboard costs around $250 right now because they are in high demand right now.They can be found at tv-part.com but supplies are limited. I would definitely shop around though. 3. Remove and then replace individual faulty caps. This takes some soldering skill. Caps are inexpensive and if you can take care of it yourselfit will save you hundreds. This may be your problem. If you determine that it might be. I have a Tip/How TO tutorialon this site that may also help. Itgives step by step instructions for replacing caps on PSB #715t2432-2. If this isyour board you are in luck. Here is theLink: Fixingthe Philips Turns/shuts off on its own problem. I'm working on uploading pictures to helpguide people though the process as well. Let me know if I can do anything to help. Hope this helps and if it does please rate itaccordingly. Good luck.Kaufman605
Posted on Dec 16, 2010
TODDAS
  • 431 Answers
SOURCE: My panasonic PT-56DLX76-K TV just shut off and now when I turn it on the power indiction just conitnually flashes green but the TV won't turn on. Any ideas?
Check lamp door and make sure it's secure for the safety switch to be engaged.
Posted on Nov 18, 2011
TV was working fine earlier today. Now, when the TV is turned on, audio and video will be fine for the first 30 seconds, then everything goes black and audio cuts out. When this happens, a faint buzzi
this works for me.....hold down the off button on top of the tv for at least 5 seconds....(not the remote).....then try the remote on button
if it does not work the first time....try holding down the tv off button a bit longer
Jan 02, 2015 | Panasonic PT-56DLX76 Television
Do you have a diagram for where the iris is on the Panasonic PT-AE900U projector? we are trying to repair a grumleing sound
http://www.scribd.com/doc/44911427/AE900-servicemanual Check that link. Page 22 on the document details how to remove the Iris unit, including a picture diagram on how to remove the unit. Hope this helps.
Mar 06, 2011 | Panasonic PT-AE900U Multimedia Projector
Lamp flashes red and tv just shut off
You may have a bad lamp. Open the door on the side & pull lamp. The part number is TY-LA2006. They cost about $200-225. BE SURE to reset the lamp timer. If you buy an original Panasonic TY-LA2006 lamp, it will have instructions to reset lamp timer.
Jan 21, 2011 | Panasonic PT-56DLX76 Television
Pt-56dlx76 panasonic light flashes red 3 times. I just changed lamp.
Dec 16, 2010 | Panasonic PT-56DLX76 Television
Resetting the timer for the lamp on a PT-56DLX76?
stephanie286,
hardrocko
Nov 30, 2010 | Panasonic PT-56DLX76 Television
Panasonic projector PT-AX100E (PTAX100U) shuts down every few minutes, must be re-started several times before it will stay on for good.
Problem is the dynamic iris its broken. The only solucon is to change it so get the projectorn to the nearest panasonic sevice and thety will fiks it on waranty
Jun 07, 2008 | Televison & Video
Annoying projector noise
Well here is a partial solution. Turn off Dynamic Iris and the noise will go away. Now could someone tell me how to fix the Dynamic Iris?
Dec 06, 2007 | Panasonic PT-AE900U Multimedia Projector
Panasonic PT-56DLX76 Television Logo
32 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
