Question about Sony KDF-E60A20 60 in. LCD HDTV
Screen goes black and sound goes away too
Shortly after powering on my screen goes black and the sound goes out. The power light flashes a while then it comes back on for a minute. It does this in a cycle. Is it my bulb going out? The lamp indicator light never flashes or lights up. Tech said it may be the lamp.
    Problem Solver:
  • 5 Answers
Remove the lower front panel by removing the 2 large round screw heads at the lower back corners, one on each side. Remove the retaining screw on the right side of the metal horizontal retaining strip in front of the bulb holder, remove bulb retaining screw in the upper left corner of the bulb holder. Pull the bulb holder out towards you and check for dust build up on the top screen on the bulb casing, if there is an abundance of dust it will restrict the airflow across the face of the bulb which causes it to heat up and turn off. Once the dust has been cleaned your bulb should now work as it should without a problem.
Posted on Mar 13, 2008
  • 4 Answers
I had this problem and ordered a new replacement XL2200 lamp from Sony and that fixed it. By the way, the lamp installs from the front so there's no need to pull your TV out from the wall. Look at you manual, it is accurate in this respect. My lamp only lasted about 15 months. It costs $200 plus about $16 to ship. You can order direct from Sony on line service.
Tom
Posted on Feb 27, 2008
Mine is doing the same, but I noticed that this issue happens when there are high white tones in the screen (explosions, essurance commercials). It is not random in my set, it's always related to brilliant shots in the screen. Tech support will come tomorrow to replace power board (voltage spike), then I'll show him my observations to get his feedback.
Posted on Oct 23, 2007
Hyundai monitor on for 5 minutes and screen goes black
Have you ever opened up the monitor to clean the dust out,it could be your heating up and then letting it sit will bring it back.If your unsure how to do this ask a tech.
Apr 21, 2017 | Hyundai X224W
The TV was turned off; and when it was turn on later, the green light blinked (while with only black screen w/no sound, or bulb illumination front/back of unit); and shortly afterwards the status ligh
Lamp is possible----
Mitsubishi TV troubleshooting
Here's something that might also be useful. After you turn on the set, and get the regular red blinky lights, hold down the Device and Menu buttons together for about 5 seconds.
The Power light will start to flash in a two digit sequence.
For example, 3 flashes, then 7 flashes = 37.
Here are the error codes, and the corresponding problem:
12 = No error detected, check power supply.
32 = Lamp Cover is open.
33 = Air filter cover is open.
34 = Lamp abnormality
36 = Light Engine (DMD or Lamp Fan stopped)
37 = Exhaust or Lamp Ballast Fan stopped
38 = Lamp Temperature High
39 = DMD Temperature High
41 = Short is detected
44 = DVI cable between FMT and Engine disconnected
Jul 17, 2012 | Televison & Video
I have a Panasonic PT-52LCX66 television that I bought just over 4 years ago. I have replaced the bulb for the second time just 3 months ago and now the set will just shut off after about 3 minutes of...
Tv making and have clicking sounds as tv shutdown as lights flashes?Yes.The board that call the Ballast board might be dying and dead soon.This Ballast board job responsible only are to ingnite the tv projection lamp only.
Jun 30, 2011 | Panasonic PT-52LCX66 Projection Television
Screen goes dark after few minutes
check your LCD inverter maybe there is loss connection or some parts damage from inverter.
May 05, 2009 | Polaroid TLA-01511C 15 in. LCD Television
Tv powers up and the screen then goes black..still has sound thou
power pack capacitors are going bad, need to have then replaced.
hope this helps
Apr 06, 2009 | Akai LCT2715 27 in. LCD Television
Set up only visible for 2 seconds, then black - Aquous lc-37d43u
Unfortunately I can promise you that you CANNOT repair this. Your power and opc lights coming on, but the tv is not coming on. That is a issue within the tv. Give sharp a call and they will have somebody come fix your tv free of charge, if they cant fix it, they will replace it for free. That is the only thing you can do. Sorry bro
Dec 10, 2008 | Sharp LC-37D4U 37 in. LCD Television
After power outage, tv doesn't turn on
First, the blinking light is a code, how many blinks? Second, regulators are not resettable. Don
Aug 17, 2007 | Panasonic CT-36HL43 36" TV
TV Picture Goes Black
I had the same exact problem.
I removed the bulb and cleaned it. There is a small screen at the top of the bulb and it was covered with dust. Once it was cleaned I replaced the bulb and it solved the problem.
Thanks to those who posted the solutions
Jul 28, 2007 | Sony Grand WEGA KDF-60WF655 60" Rear...
Sony KDF-E60A20 60 in. LCD HDTV Logo
185 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
