Question about Pantech C300 Cellular Phone
LIttle Red Phone with the vibrate squggle lines
My phone will not ring at this time, when I opened my phone it is now showing a red phone with squiggle lines around it.  I have tried to get the ringer to work and it will not get off this feature....any advice?
  • Eric Burton
    Eric Burton Oct 18, 2007
    I found out that if I did the mast reset then everything will go back to factory setting, advice save everything to your sims card before doing this because I lost all my paied ring tones.
    IF you do not know what your reset password is mine was 1234 like most phones.
I had the same prob. Do NOT RESET YOUR PHONE! I did. lost about 300 pics of my new born baby:( Any way today I was reading the manual, (maybe a year old now!) and it showed the * key as a short cut to vibrate. Just hold it down. So I did it showed the red shacky phone again! I freaked (didnt want to reset it again) but realized you just hold the * a second or two and it goes back to normal! too easy :)
Posted on Apr 06, 2008
  • 4 Answers
It is in vibrate mode. Simply press and hold the "*" key at the lower left.
Posted on Jun 05, 2009
  • 4 Answers
It could be on vibrate or airplane mode or something. just change the settings maybe it will work?
Posted on Aug 26, 2008
Phone line doesn't ring
First, lets get rid of the static. Try Feature #86. This will turn off background music. When a music source is not attached you get static.
Enter programming by using Feature XXX66344 password 266344. The display should show "Terminals&Sets" press the top right button with an indicator in the display. The display should show "Show set: ____ enter the extension number that you want to check or program. The display will show ***:name. Press the top right button three times. The display will show Show Line:____ with options to Scan or List. If you select Scan it will show the lines assigned to that phone. If you select List it will start with the first line in your phone system showing one of four states 1- Unassigned, 2- Ring Only, 3- Appear&Ring, 4- Appear only. Change the selection on the line by using the CHNG soft button. This is where line assignments are changed from the four states for each extension.
The only other thing that will keep an extension from ringing is "Do Not Disturb" or DND. Feature 85 and #85 will turn this feature on and Off.
Jan 31, 2014 | NorStar Meridian M7310 Phone
Power light flashing green to red
Assuming the "squiggle line" is the Utility LED the unit has proper power. The light is steady green and not flashing, correct?
Have you reset the unit?
Try removing all but one attached device to verify it's not an overload condition.
A photo of the control panel would help.
Dec 23, 2012 | HP Compaq T1500 XR (204203003) UPS System
How do i connect a 1960 rotary phone up?Which wires do i hook up? I have a blue wire &a blue white wire coming into my building,
The Blue and Blue/white represent the first pair in a multi pair telephone cable. The second pair is orange the third is green and so forth. If this line is active, you will get a dial tone when you place a telephone instrument on this pair (or any subsequent live pair). Notice. If you are hanging on to the pair when the telephone rings - you will experience a 60 volt DC shock. It will not kill you but you may find it unpleasant.
On your Western Electric '500' telephone set, you should have three wires coming out of the original cable, a red, a green and a yellow. Normally, the red and the green will operate your phone on a 'private line' (only one customer on a private line). Try various combinations until you get a dial tone. You no doubt have a private line as there are very few party lines around these days if you are in the USA (and please do not say). Once up on a time, there were "party lines" where neighbors shared a line and they knew the call was for them based on the number of rings. The first customer got one ring, the second customer got two rings and so forth up th as many as 4 rings. When the telephone rang, you listened for the number of rings and answered only if it was your number. Picking up a call that was not your ring was frowned upon though it was not unknown for neighbors to listen in to other neighbors calls. It was like a reality show!
If your 500 has been upgraded with a RJ-11 wire, plug the wire in just as you would any modern telephone. If yours doesn't ring, remove the cover and study the interface. You will find several terminals marked L1, L2 etc. Move the wire you find on a "L" terminal to the various otgher L terminals until it rings when called. You may also have to adjust the spring on the ringer to get it to operate properly.
I hope this information helps you get your 1960 telephone to work.
Thank you for your interest in FixYa.com and enjoy your old telephone.
Mar 14, 2011 | Computers & Internet
Only certain lines ring on certain phones
Programming2.gif is done on M7310, M7324 and T7316 sets.
To set up ringing you need to enter programming2.gif by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
The screen should say TERMINALS&SETS.
The 4 top line/feature keys are now used for programming.
At the terminals&sets prompt, press the show key (top right arrow).
The display should now ask for an extension number. Enter extension number you wish to program ringing on.
Press the show key (top right arrow)
The display should sat LINE ACCESS
Press the show key (top right arrow) .
The display should say LINE ASSIGNMENT.
The display ask for a line number. press list
The display should say line 001: appear& ring2.gif
press next key (lower right arrow)til you see the line port number you wish to program (004)
The display should say line 0xx: appear only
press the Chng key till it says appear & ring
press the release key when finished
Oct 07, 2009 | NorStar M7310 Corded Phone
Hi, When the phone rings into the office my phone is th eonly phone that doesnt show on what line the call is coming in to. One of the other phones is fed directly from mine and it shows it perfectly
This is probably something that requires a technician unless you're familiar with ICD groups. The lines appear on buttons and your phone probably lights with a solid red light to show the line is busy, but you can't pick it up. By default, ICD code 600 is ring group 1, but you have to get access into SYSTEM programming to add your extension to it. The ring condition, immediate, no ring, or ring delay x rings is also part of the programming.
Carl
Sep 30, 2009 | Panasonic KX-T7630 Corded Phone
Cannot program Speed Dial
Try adding Cisco 7914 (time two) for additional (other) phone lines, or define caller group so phone call rings around.
Jan 17, 2009 | Cisco 7940 IP Phone
Making the date and time show after the phone rings.
Sounds like you have several issues here...Time & date is set by entering the DB Administrator, then using the code 08-14. Feature69 defaults a set, not the time. The incoming display is normal, as you are a member of the first UCD group. When you pick up the phone, it shows ICM because you are in intercom mode. There are 3 different ITCM modes: green, red, blank. Your extension button lights red because it's an indicator that you are on the phone.
Jan 16, 2009 | Comdial 8324S-PT Corded Phone
We have a PT61LCX65 Panasonic Tv that has purple squiggle lines
TRY THE MENU FOR A COLOR CONVERSION OPTION TO FIX THAT
Dec 16, 2008 | Panasonic PT-52LCX65 44" HDTV
Only First Phone in the system will ring on incoming calls
These manuals are available on the norstar web site.
Jul 08, 2008 | NorStar M7310 Corded Phone
Phone doesn't ring at station
Sounds like your station (phone) is set to not ring. You need to check your ring assignment.
Feat # *
Enter password (default is 000000)
Press the soft key under "show"
Press the soft key under "next" until 1. STATION appears in the display.
Press the soft key under "show" SHOW STA:_ appears.
Enter your station number and press the show soft key
Press the "next" soft key until RING ASSIGNMENT shows on the display.
Press the "show" soft key. You will see CO LINE 1 : followed by NONE or DAY or NITE or BOTH.
If it says NONE, your phone never rings for an incoming call. If DAY or NIGHT your phone rings depending on the time of day and the time definitions for DAY and NIGHT programmed into the KEY unit. If it says BOTH, your phone should ring all the time.
If you need to change the setting, press the "chg" soft key until the desired setting comes up.
When you're done with LINE 1, press the "next" soft key to move to the next line. Repeat the process for all your active lines. Obvisously changing settings on lines with no CO connection will have no affect.
While your in the mode, check your RECEIVE ASSIGNM as well to make sure your phone is configured to receive incoming call. It was the station feature just before the RING ASSIGNMENT feature.
Hope this helps.
Jun 04, 2008 | Vodavi Starplus SP7314-08 Corded Phone
Pantech C300 Cellular Phone Logo
61 people viewed this question
Top Pantech Cell Phones Experts
Marvin
Marvin
Edward Greene
Gary Nitowski
Are you a Pantech Cell Phone Expert? Answer questions, earn points and help others
