Question about ASUS P4S800D-X Motherboard
How to connect the front panel on the motherboard
2 Suggested Answers
  • 114 Answers
SOURCE: need connection diagram for awrdacpi
http://support.asus.com/download.aspx?SLanguage=en&p=1&m=M2N-MX+SE&hashedid=LqXTJVvWNyI6cj2d
Download the installation manual in your language from there.
Posted on Jul 23, 2011
It is same for my P5KPL AM/PS front pannel is not working for this mainboard. My OS is windowdow xp 7
For that you need to check the front panel connection to motherboard. You can see diagram below . Click here Download manual from below link then connect front panel connection to motherboard. You can also find the diagram on motherboard there are some pins on corner of the motherboard where you need to terminate front panel connection. You can read diagram near those pins. Let me know if you need further assistance. Thanks for using FixYa.
Nov 28, 2010 | ASUS P5KPL-AM SE Motherboard
How can i connect front panel audio
You will need to install a extra hardware, a sound card with the internal extension using cable.
You will get extra cable with the sound card which will fit in front panel.
Nov 03, 2009 | Intel DG31PR Motherboard
Could you please help to connect the front panel headphone connection to the motherboard
Here is a link to this motherboard's manual:
http://download.intel.com/support/motherboards/desktop/d101ggc/sb/d3458804_en1.pdf
On page 38, you will find the connection diagram for front panel headphone connection.
Jul 14, 2009 | Intel D101GGC Motherboard
Not work audio front panel.What`s the problems. How to connect cables in motherboard. please help
The front audio panel will only work if connected to motherboard. Try
connecting to the audio panel in the back of the computer (directly
to the motherboard). If the rear panel audio plug (green) doesn't work
then the audio drivers that came with the motherboard might need to
be installed. Check your audio driver status with operating system.
Jul 08, 2009 | Abit GD8 Pro Motherboard
How to connect the front panel sould device?
Do you mean speaker or front panel audio? The front panel audio connector is located at the rear of the board, behind the PCI connectors - the speaker connections are in the panel connector block (2x10 pin header) located at the front left of the board.
With the board in it's normal position, the speaker pins are on the right hand side of that block, on the pin nearest the front and the one 3 positions behind that
<back of board>
| HD LED + | | Power LED +
| HD LED - | |
| | | Power LED -
| Power SW | |
| Power SW | | Speaker
| Reset SW | |
| Reset SW | | Speaker
Front of board
Jul 03, 2009 | ASUS K8V-MX Motherboard
Describ connect front usb in msi motherboard
Diagonally opposite to where you connect you keyboard and mouse, there are pins to connect the front panel USB. You can identify it on the motherboard by the names USB5 or USB4 written on the motherboard. Just connect the front panel USB connector to either of these pins.
Jun 07, 2009 | Intel Motherboard
Is It required to connect Tower Front Panel I/O to Motherboard
The power button on the front panel would definitely need to be hooked up to the motherboard so you can power up the computer.
If you have any usb slots or a media card reader on the front panel, or both, then you would need to hook those up as well, otherwise the main one you need to connect would be the power button.
May 23, 2009 | ASUS P4V8X-MX Motherboard
Usb front panel connection
it depends on weither the case and the motherboard are the same usb connection . make sure that there both usb 2.0 or 1.1 not one or the other as the connections or not compatible .
May 01, 2009 | ASUS P4SGX-MX Motherboard
Where to hookup front panel (PIII-3754LMR - AMPTRON)
Front Panel Connector The front panel header is where the connectors of hard disk drive activity lights, case speaker, reset button, power on/off button, computer power on light, and key lock, are connected to make them function smoothly. In the past days, users always have difficulty connecting the front panel due to a lack of standard location on the motherboard. Today, AOpen integrated all these disorder but essential front panel connectors into one 20-pin connector for easy usage. Connecting the front panel would no longer be the headache of installing motherboard anymore. Below is a view of this user-friendly front panel connector of AOpen motherboard.
please rate this post.
or donate on madridtelecom@gmail.com
Feb 08, 2009 | Intel Motherboard
Problem with microphone
most of the old motherboards dont support the audio and mic port to work both in back side(back panel header) and front side (front panel header)simultaneously...
most of the old motherboards dont support multi streaming so you cant make both the back panel header and front panel header to work at a time ie i mean you cant connect both panel header at a time ...
you can just refer to your motherboard manual for the detailed information about it ..
in your motherboard if there is any option to connect the front panel header to the motherboard other than the back panel header you can connect it to that the detailed pin information will be given in the motherboard manual ..
if you dont have the option in the motherboard to connect the front panel header seperately then you must remove the pins connected from the back panel header and you must insert the front panel header pins .
this will disable your back panel audio ,mic,linein functionalities but you will be able to connect in front panel header , this front panel header will work ..
if the motherboard is not compatible then the system assembler will leave the front panel wires not connecting to motherboard ..
like this only one panel can work at a time ,
but in the latest motherboards the multi streaming technology has been introduced so both the panels can work at a time and can play different audio on 2 different panels ...
thank you
bye
any doubts you can reply me
i am always here to assist you
please rate my solution
have a nice day
Aug 10, 2008 | ASUS P5VD2-MX SE Motherboard
ASUS P4S800D-X Motherboard Logo
18 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
