Question about Lexmark Z705 Inkjet Printer
Lexmark Z705 how can I have the printer print in black only, not color?
  • Lexmark Master
  • 13,433 Answers
In the printing preferences you need to select Black and white.
1. open the document you want to print
2. click file
3. click print
4. select printer from list, then click on preferences
5. look around the pages.
In Color tab I found a print in Grayscale - this setting will print the document in black and white colors, the pages may be diffrent on diffrent printers. look for black and white setting or Grayscale.
picture: printing preferences, color page on a hp printer, select grayscale with black cartridge only.
Posted on May 19, 2009
Folkpottery@bellsouth.netmy z705 is 3yrs old and takes print command ,goes through the print mode but nothing on paper.refilled black cartridge but still nothing on paper?cartridge blots ink on paper...
It could be a cartridge, hardware or a software problem. Try to print a hardware test page on the printer. Please follow the steps in this article from the Lexmark website How to Perform the Hardware Test on the Lexmark Z705 Photo Jetprinter. This is a good way to start the troubleshooting. Keep me updated. Thanks.
Dec 28, 2010 | Lexmark Z705 Inkjet Printer
Printer will not print yellow or orange, but prints other colors correctly. Brand new lexmark cartridge.
Yellow is one of the printer's "primary" colours.
Orange is mix of "red" and "yellow".
So, an empty "yellow" cartridge, or clogged ink-jets would cause your symptoms.
Sep 17, 2010 | Lexmark Z705 Photo Jetprinter InkJet
I have a Z705 and it will not print after windows
You need to reinstall the drivers for your printer. If you don't have the windows 7 drivers for your printer, you can use the driver for Vista. It should work.
Nov 24, 2009 | Lexmark Z705 Inkjet Printer
Lexmark z705 printing blank envelopes soft ware ok
The problem that you are experiencing is caused by the way the text is formatted in most word processing documents. By default envelopes are printed not in black, but a dark gray. This confuses the printer and causes it to use the color cartridge to process gray instead of using the black cartridge.
You can fix this problem with one of two ways:
1. Click on "Start", "Control Panel" and click on "Printers and Faxes." Right click on the "Lexmark Printer" icon and select "Properties." Click on "Printing Preferences." Go to "Quality/Copies" tab and select the option "Print color images in black and white."
2. You can also change the color of you text to a true black in your word processor. This will require you to resort to the word processor's documentation and help files.
Both of these settings will cause your printer to use the black cartridge instead of the color. If either one of these solutions solves your problem, it means your color cartridge needs to be cleaned or replaced. If you feel that the color cartridge should not be out of ink, please follow the steps given below:
Clean Nozzle Procedure:
1. Go to the "Solution Center" and click on the "Maintenance" tab.
2. Select "Clean to fix horizontal strips."
The colors that you should see here are black, yellow, magenta (a reddish purple) and cyan (a dark sky blue). You should notice the diagonal lines above and below the solid horizontal lines. These diagonal lines should be solid from left to right with no gaps.
If there are gaps in the lines or the print diminishes across the page, you should run the "Clean Print Nozzles" page a couple more times to try and clear it up. If you still have gaps at the top and bottom, you should "wick" the cartridges by following the steps given below:
“Wicking” Procedure:
1. Select "Install color/black cartridge" and remove the cartridge from the printer.
2. Get a damp paper towel.
3. Set the ink cartridge right side up on the damp paper towel so that the ink nozzles are against the towel and hold the cartridge in this position for about 15 seconds.
4. Now wipe the print head (on the bottom where the ink comes out) across in one direction only (left to right) until it looks clean.
5. Next dab the cartridge on the towel to make sure that the ink is flowing.
6. Snap the cartridge back into the printer.
7. On your computer, select "Old Cartridge installed."
8. Repeat the "Clean to fix horizontal strips" procedure listed above.
If this procedure does not help, please let us know so that we can continue with technical support.
Oct 01, 2009 | Lexmark Z705 Inkjet Printer
Printer printing blank evelopes ....everything else prints ok. Lexmark printer Z705
Check your setup in your envelope printing software, make sure it's set for the size envelope you're using, it might be printing in the air next to the envelope.
Sep 30, 2009 | Lexmark Z705 Inkjet Printer
Our lexmark Z705 printer only prints won't print black.
Clean your printer cartridge printer maintainence program or alignment or head clean
Jun 27, 2009 | Lexmark Z705 Photo Jetprinter InkJet
Lexmark Z705 Printer Problem
The ink in the other is empty or if its refilled cartridge then ink is not filled correctly and cartridge cannot be used,if its new Lexmark cartridges get it replaced because the cartridges come e=with one year warranty.
Apr 14, 2008 | Lexmark Z705 Inkjet Printer
Lexmark Z705 Inkjet Printer Logo
314 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
