Question about Radio Communications
How do I install insignia ns-c6500-A ceiling speakers?
The speaker grill isn't removable
SOURCE: Remove base of Insignia ns-ltdvd26-09
to remove base from insignia tv
1)remove plastic cover from bottom rear of tv
2)remove 8 philips head screws on rear of tv above base
3)pick up tv and base will come off
once you remove it you realize how easy it is
Posted on Aug 26, 2008
  • 1861 Answers
SOURCE: replacing front door speakers
You need to pull the door panel to get to the speaker. It is bolted to the door shell, not the door panel.
Posted on Sep 19, 2008
SOURCE: need to remove speaker grill on pioneer speaker
If it is a 95-97, the speaker grills are not designed to come off by themselves. You have to actually take off the door panel. There should be screws all the way around the outside as well as 2 larger screws in the middle of the door covered by plastic caps. Remove all of those and you can finally get access to the speakers themselves. Hope this helps....
Posted on Jan 14, 2009
sg1972
  • 225 Answers
SOURCE: How do I remove the cloth grill cover from the front of speaker?
Some speaker manufacturers design their boxes with non-removable front grills. Be thankful that you can remove the back because I've seen these sealed as well. Once inside, the speakers should be mounted from the inside (mounting screws on inside) compared to front mounted. IF they are not then either you're not using the proper method to remove the grill OR it's glued in place and will require breaking the glue bond to release the grill. One note to remember...non-removable grills can mean the manufacturer has something to hide.
Posted on Mar 23, 2009
askjhuber
  • 59 Answers
SOURCE: how do i replace toyota camry 2000 rear speakers?
These grills just pop off then there is a few scres that hold the speakers in.
Posted on May 17, 2009
How to run the speaker wires from the subwoofer to the onkyo 7.2 tx-nr626
See Onkyo manual here: http://filedepot.onkyousa.com/Files/own_manuals/TX-NR626_English.pdf
Insignia manual:
http://audio.manualsonline.com/manuals/mfg/insignia/nsht51.html?p=1
Best hookup method for sub is to use the LINE LEVEL INPUT on the Insignia, wired with RCA cables to the Subwoofer Pre Out jacks on the Onkyo
Jul 20, 2015 | Insignia NS-HT51 Speaker
How to open Insignia Model:NS-E2111 speaker not working
remove front cover and unlach bottom to get accses to speakers .
Sep 04, 2014 | Insignia Set Of 4 Indoor/outdoor Speakers,...
Replace fuse
Fuse on the sub can be removed by inserting a straight screwdriver and turning counterclockwise (unplug sub first). It should pop out. Replace with exact same fuse.
Jan 09, 2014 | Insignia NS-HT51 Speaker
Insignia ns-lcd22 speakers not working
To replace the speakers, you have to open its back cover. If you wish to get some details, check the site linked here. http://electronicshelponline.blogspot.com/Pull up older posts. Disassemble procedure to many popular brand TVs are given with illustrations.
Dec 31, 2013 | Insignia NS-LCD22-09 LCD HDTV
Insignia NS-LB032X-10A we bought from a friend that claimed virtually no use and we have not manual and can't get any sound out of it. Please help if you can. It is a 32 TV &built in DVD year 2009
Do you mean the NS-LBD32X-10A? The manual is available here: http://insigniaproducts.com/products/televisions/NS-LBD32X-10A.html?supportTab=open . The direct link to the manual is http://insigniaproducts.com/cms/documents/NS-LBD32X-10A%20UM%20EN.pdf .
Check if the speakers are muted or if the volume is low. Then go to the Menu and in the Audio submenu go down to Speakers. Make sure that the internal speakers are on.
If the speakers still don't work, they may have failed or the wiring may be damaged. Unfortunately, I do not see any speakers for the TV from my usual vendors.
I hope this helps.
Jun 21, 2011 | Insignia Televison & Video
Insignia ns ht51 subwoofer the speaker is vibrating but with no sound i believe it is the fuse, if so which fuse do i need
If the fuse had blown the sub woofer would be dead. I think you have a very low frequency oscillation problem . Now the frequency is so low ( below 15Hz ) one cannot hear it but if you look at the sub woofer speaker it will be pushing like a piston - to and fro very powerfully.
You will need professional help on this one.
Apr 28, 2011 | Insignia NS-HT51 Speaker
I need to download the driver that was accidently deleted from my computer. I have the Insignia speakers, NS-3006. Help!
Goto device manager select your speaker right click hit on update..!
*Device manager (Run >>>devmgmt.msc)
Jan 15, 2011 | Insignia NS3006 2 Speakers
Can't get face plate off of MTX 610CM ceiling speakers
Its a pain, espicially if the grills were painted before installation.
In the industry we use a "grill puller" which is nothing more then a wire hook with a loop for your finger.
If the holes are big enough bend a paperclip into a hook, grab it with needle nose pliars and pull the grill through the hole near the edge.
If it doesn't fit then use a small pointed knife or awl, stick the point in a grill hole around the egde and pull it down a bit, work your way around until you can grab the grill with your fingers.
Let me know if you need anymore guidance......be careful I've replaced alot of destroyed speakers!
Cheers,
Kevin
Feb 03, 2010 | MTX 610CM Speaker
How do i wire external rock speakers with 6 wires to my internal sound system with only two wires
Here is a link to the installation guide... for Insignia Simulated Rock Speakers... http://insigniaproducts.com/cms/documents/NS-R2111%20UM%20EN_SP_FR.pdf
Jun 12, 2009 | Insignia Simulated Rock Outdoor Speakers...
Csi sp-6c removal
Your speaker cover should either twist and gently pull off or may just need gentle prying with a small screwdriver. Before attempting is your speaker grill foam or metal. Some like my pioneers, you must gently remove the actual grill and not the entire facia itself to access the speaker removal. If you need to remove the grill, i recommend using a tiny screwdriver and gently work around the edges evenly. Steve
Dec 15, 2008 | CSi Speco SP-6C Main / Stereo Speaker
Radio Communications Logo
21 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Are you a Radio Communication Expert? Answer questions, earn points and help others
