Consumersupport lenovo com
Hi I have a Lenovo PC K430 that I bought in april of this year, every thing was working great, till two days ago when I turned it on, the display says that can't find any signal from the pc, I reset the HDMI cable and nothing, replaced the HDMI cable and nothing,used a 19 pins port cable and nothing, I noticed that the Hard disc light lit for about five seconds every time I turn the pc on and then there is no more activity even if I insert a CD or DVD the screen still not sensing any signal fron the PC, when the pc was ok normally started with a high noise and quiets after few seconds, now this noise continues as pc is on and won't initiate.
    Problem Solver:
  • 5 Answers
Sounds like your power supply is having trouble. Is the inside filled with dust bunnies? Get some canned air and blow out the inside of the machine. Make sure all the fans spin freely. Once in a while the video card will need to be pulled out and reseated to reestabilish electrical connection. At the least, clean and replug... at the most, a new power supply.
Posted on Dec 30, 2013
SOURCE: computer powers on, but does nothing
it's stupid but can be the function button + f1 that turns the screen in black
Posted on Oct 04, 2007
  • 56 Answers
SOURCE: cannot display image on a proector using Lenovo laptop
Sounds like an extended desktop. have you tried dragging an open window (ie. internet explorer webpage) to the top, right, bottom, AND left? When you get to one of the edges, move it like you are moving it off and it should move to the other screen. You can change your setting to 'duplicate' your desktop in your video settings.
Posted on Apr 29, 2008
wealthwise
  • 111 Answers
SOURCE: Acer Aspire not booting
I'm inclined to believe something is going on with the DVD drive, perhaps a I/O cable or driver issue, it just seems like what you said about the drive sounding like it's trying to read is a clue, what I would try if you have not already ,is since you said you can get to get to the Bios usually the default for boot sequence is CD/DVD drive first unless you change it, see if you can change the boot sequence from DVD drive first to HDD first and see if you can bypass it, then it might just boot, if that works then that was the cause,I see no other reason why the Drive should be trying to read other than the boot sequence. if not then it might be more complicated and could be a hardware issue somewhere,
Hoep this helps.
Posted on Dec 05, 2008
zohail
  • 1223 Answers
SOURCE: my Cd dvd drive not working for Lenovo 3000 Y410 Laptop
ur lens is getting weak
pls try this take out the dvd from drive u will see a shiny eye like thing it is lens try to clean it in circular motions with very soft cloth used to clean lcd's and then try those dvd 's otherwise u have to get the drive replaced ur lens is weaken due to some faulty media and excessive use it is a normal wear and tear process
pls rate me fixya for my help
Posted on Mar 06, 2009
  • 3940 Answers
SOURCE: Dell Inspiron 9400 display goes blank after a few minutes
If the issue occurs in the safe mode, then I'm suspecting a failure of the LCD backlight. (It warms up and quits) Also see if video stays on using an external monitor. If it does, then the LCD is most likely failing.
If video goes out on an external monitor as well, then the Video card is failing due to overheating. Make sure all vents are free of dust (Clean with canned compressed air) and the all fans are functional (Run the fan test in diagnostics) If fans check up, then video card is failure point. If fans fail diags, replace affected fan 1st
Posted on May 22, 2009
It's probably a short delay. Wait a few days since packages often take time to arrive.
Aug 20, 2013 | Computers & Internet
Lenovo k430 won't boot windows 7
might due to harddisk partition and format.
you need to use other utility software to format then only install.
But your recovery parttition will gone.
Never able to restore back to win8
Mar 02, 2013 | Lenovo K430 31092JU Desktop PC Windows 7...
Sound device not working, cant install driver softwere
windows xp: http://consumersupport.lenovo.com/ot/en/driversdownloads/Drivers_Show_2511.html
vista: http://consumersupport.lenovo.com/ot/en/driversdownloads/Drivers_Show_4790.html
win 7: http://consumersupport.lenovo.com/ot/en/driversdownloads/Drivers_Show_3190.html
May 05, 2012 | Hi-Capacity Computers & Internet
I want driver of webcam for lenovo z560
here's the download page for lenovo z560 drivers: http://consumersupport.lenovo.com/uk/en/DriversDownloads/drivers_list.aspx?CategoryID=37684
you can also use option 3 on this site to download and install automatically all needed drivers
Oct 16, 2010 | Computers & Internet
I had problem with my webcamera , it did not work properly. can you show me the drive for that. my LENOVO 7757
Hi. You can download the drivers for this machine at consumersupport@lenovo.com, just enter the serial no. and it will give you the drivers for your machine, also try pressing the Fn+Esc Button on your keyboard to enable or disable your webcam. Hope this helps
Jun 08, 2010 | Lenovo 3000 Y410 Laptop
I need all drivers for XP version. for Lenovo 38Q
Hi
Go to this link and put the serial number of the system and it should fire back the right drivers for it.
http://consumersupport.lenovo.com/en/DriversDownloads/drivers.html
Thanks
Taz
Oct 29, 2009 | Lenovo 3000 Y410 Laptop
How to install the hardware drivers and set the wiresless internet access in lenovo y330 series
Broadcom Wireless Driver (Windows Vista)
http://consumersupport.lenovo.com/en/DriversDownloads/drivers_show_661.html
Broadcom Wireless Driver (Windows XP)
http://consumersupport.lenovo.com/en/DriversDownloads/drivers_show_326.html
Intel Wireless Driver (Windows Vista)
http://consumersupport.lenovo.com/en/DriversDownloads/drivers_show_310.html
Intel Wireless Driver (Windows XP)
http://consumersupport.lenovo.com/en/DriversDownloads/drivers_show_1263.html
Just download them and run the setup file to install the drivers :)
If you found this helpful , please rate my solution below
Kind Regards
1234s282
Jul 02, 2009 | Lenovo 3000 N100 CoreDT2080 VB PC Notebook
Computers & Internet Logo
19 people viewed this question
David Payne
David Payne
