Samsung rear projection TV
My Tv screen keeps flashing 'AGING' in red letters near the centre of the screen........how do I resolve this issue?
Lawrence
  • ams30gts Nov 07, 2008
    i have exactly the same problem. i hit the menu button and and it is gone when the menu is up, but goes right back after i go back to watching tv
After getting off the phone with samsung customer support, this si the method i used to get rid of it.
hold "menu" button on the TV for 10 seconds and poof. gone
Posted on Nov 07, 2008
Problem sorted----thank you LEADTECH
Posted on Oct 21, 2007
    Novelist:
  • 192 Answers
Hit the Menu button on the television and this will resolve the problem.
If it doesn't then reply to this post and I will respond.
  • 372 Answers
Hi.
What is the model number of your Samsung tv ?
http://dysonmanuals.inc.io/
Posted on Oct 19, 2007
  • chris pursloe
    chris pursloe Oct 20, 2007
    Hi.
    Sorry I cant find any info on that particular model.
    What country are you in ?
Screan shuts off after 30 seconds and 3 lights flash on botton near power button.
Contact Samsung tech support, Tell them this info, they should be able to tell you the type of problem you have
Feb 12, 2014 | Samsung HLP5085W 50" Rear Projection...
My Phillips Big Screen TV is having audio problems I cannot hear anything but the picture is still great. Do you have an solution to resolve my issue?.
I would certainly challenge the fact that your SSB is bad. This SSB is known as the the small signal board. This board is a little larger than a credit card and is seated on top of the signal module( The board with all the RCA jacks and RF connections). It is located inside the TV on the left side of the rear of the TV. I must caution you, the replacement board will exceed any expectations you may have for repair. The cost of this SSB will be near $300 dollars. Then you will need a TV tech to enter the software to correct geometry. This SSB controls the screen size and colors (gray scale) and sound, etc. Sorry to lay the hard core facts. But it will not be feasible to repair this aging TV. I have seen and repaired many of these when they were under warranty! Thanks for asking and show all hands of support.
May 13, 2011 | Philips 60PW9363 60" Rear Projection...
58" Sony HD Projection
go to wwwsomelifeblog.com/2007/06sony-projection-tv-red-line-repair.html
Sep 30, 2009 | Sony KP-51HW40 51" Rear Projection...
When I turn my rear projection television on, the
Ur power board ic converter board it dead.
U know about a little about electronic the plug
go direct to the board order that board or repair man cost part labors about $575.
Aug 13, 2009 | Samsung HCM422W 42" Rear Projection...
Samsung HCN4727W Rear Projection TV, green screen, audio works
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai2_bing.gif,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jul 10, 2009 | Samsung HL-R4667W Rear Projection...
Sony projection TV when turned on a solid red line across screen when turned of a flash of red and until the tv is warmed up red ghost letters behind the normal black ones
Hi, you will have to replace the convergence circuit board on this unit. it is failing to calibrate the rgb stream.I'm sensing signal board failure as well.
Mar 08, 2009 | Sony KP-51WS500 51" Rear Projection...
Aging 43H7143
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Dec 24, 2007 | Toshiba 43H71 43" Rear Projection...
Red Lines
Red convergence IC defective===Replace Stk392-040 IC's.
Change both for reliability.I use Panasonic brand with no recalls.
let me know how it goes....T.
Oct 23, 2007 | Samsung HCL552W 55" Rear Projection...
TV Flickers red lines across tv screen
Sounds like you have an intermitant overdrive situation on the red CRT. This could be caused by a bad component on the Red CRT board, an intermittantly shorting CRT or the circuitry in the main board. You should not run it until the problem is resolved as you could damage the CRT if it is not already bad. This is something that unless you are a qualified tech you are not going to have any success resolving. It should not be very hard for a good tech to diagnose the problem. Costs will depend on the part which is bad. If it is the red CRT it probably is not worth fixing, but it could be a 50 cent capacitor. Certainly worth the cost of a service call. Good luck.
Jun 29, 2006 | Samsung HCL4715W 47" Rear Projection...
Televison & Video Logo
93 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
