Question about Poulan Snowblower 205cc 8.0 TP Briggs OHV ES 27 PR8P27ES
Poulan troubleshooting problem starting; sometimes will start but after a few minutes just dies; I've replaced the spark plug and the gas....no luck
4 Suggested Answers
wilsodfarm
  • 986 Answers
SOURCE: Describe your Poulan "" Push
Please change your are filter,or clean it, I hope this helps you and thank you
Posted on Sep 10, 2009
  • 4088 Answers
SOURCE: Doesn't want to start. Replace carb and ran for
The spark should be blue and snappy. Try a new plug--any help? If not, it may need a new ignition module. Check the flywheel magnets--they should be quite strong. The module gap with the magnets underneath the poles should be about business card thickness. Check the air cleaner and muffler for plugging. Hope this gets it running!
Posted on Apr 09, 2010
  • 248 Answers
SOURCE: Poulan pro 4218 avl, starts (sometimes) then dies,
may be choke problem,about 20.00 for repairman to fix
Posted on Oct 08, 2010
I have a Poulan Pro High Output Engine that won't start, I've replaced spark plug and filter but still no luck getting it to start. When and if I get it started it idles high and when
Carb adjustment. Start with 1 full turn out on both low and high side. If it fall on it's face, turn the low side out an additional 1/4 turn.
Sep 27, 2014 | Poulan Garden
Poulan ym20cs won't stay running
Sounds like it needs carb adjusted and/or rebuilt.
Jun 24, 2014 | Poulan Garden
Poulan snowblower won't start; it backfires and sometimes starts but only lasts a few minutes if lucky; I've replaced spark plug and gas.....no luck
Gotta take the Bowl off the carburetor and see if the Jet is Plugged up.
Today's Ethanol gas ills carburetors. New gas wont help a gummed up carb from leftover old gas.
Dec 30, 2013 | Poulan Snowblower 205cc 8.0 TP Briggs OHV...
Sputters after driving a few minutes, tries to stall out.
1st move is to ck the fuel PSI & emissions. Possible cooling system cause.Scan computer & check sensor readings & the emissions readings are the first moves. Check spark plugs, ignition spark etc. Good luck
Mar 25, 2017 | 1999 Volkswagen Cabrio
95 Park Avenue Ultra dies for no reason I can find, I've replaced the crank sensor, cam ssensor, spark module, fuel filter, I've had the injectors tested, fuel pump tested, plugs & wires t
As you have probably figured out by now, you will have to treat it as a no start and troubleshoot it when it fails to start. Until you figure out if you are loosing spark or fuel to the injectors when the engine dies you have no direction to go in.
Aug 20, 2012 | Buick Cars & Trucks
Weed eater starts but won't stay running
just bought a new Poulan 25cc 2cycle gas power weed eater . I can start it with the choke on but as soon as put on run it dies.
Jul 08, 2010 | Poulan 25cc 2-Cycle Gas Powered String...
Primer will not pull gas to carb and will not run. gasket replaced
You can check the priming circuit manually by pulling the plug off the spark plug and then with our hand over the air inlet to the carb have someone give the mower 3-5 pull starts. Then, put the plug boot back on and try to start it. Did it work? Is it still running? If it started and ran your primer bulb probably has a leak and needs replacement. If it started and ran for a few seconds and died clean out the main jet and the bowl inlet.
You can look at the breakdown of the carb in your manual to see where these parts are. Or just go online and find a familiar carb diagram and work from there.
Good luck and be careful!
May 24, 2010 | Poulan "Poulan" Push Mower
Have craftsman chain saw, runs ok for a few minutes then dies. found broken gas line.replaced fuel line,air filter,spark plug, checked muffler, also mixed fresh gas.eng acts like its out of gas. leave it...
The plugged vent gets my vote. Loosen the fuel cap when it starts to starve.
All Poulan IPLs (exploded parts list) are here:
Poulan.com
http://www.ordertree.com/modelinfo/POULAN-WEED-EATER/75.59.html
Find your model, what little fuel system detail there is can be found on it. HTH
Lou
Oct 04, 2009 | Garden
Sep 10, 2009 | Poulan "" Push Mower
Poulan Snowblower 205cc 8.0 TP Briggs OHV ES 27 PR8P27ES Logo
41 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
