Question about Dryers
Maytag mde5500aw Weak motor or belt
  • Kevin R
    Kevin R Dec 30, 2013
    Model MDE5500AYW - drum tumbles when empty, but under a load ( wet clothes or me holding drum briefly) and the tumbling stops.
  • 51 Answers
If the motor stops when you hold it, it's the motor. If the motor still runs it's the belt or the belt tensioner is worn out.
Posted on Jan 06, 2014
  • Kevin R
    Kevin R Jan 11, 2014
    Thank you Ralph, I replaced the belt and it is working well now. Qieter and it keeps tumbling. Thank you for the tip.
Maytag dependable care quiet plus ii
Hi, The belt should be in a straight line from the motor to the drum.
If alignment is not corrected damage to belt may occure.
Normally if all parts are working properly the belt should align itself.
Make sure that belt is not rubbing on any other parts. (slowing motor down). Lube all moving parts with lube oil. Don't put oil on belt.(only on bearings of motor and drum).
Jan 20, 2014 | Dryers
Admiralwasherm#aav7000aww fills up just humswont agitate
Possible that the motor is not starting up as the starting capacitor to the motor is weak. check if the motor is warm after switching off power. if so it is confirmed. Otherwise it can be due to a belt issue, bearing failure and jamming of the agitator and shaft.
check power to the motor during the wash cycle to confirm , if not the control unit is a suspect.
Jul 05, 2012 | Maytag Admiral AAV7000A
On wash cycle it makes a loud banging noise
Hello, The banging noise is from loose lower front weight mounting bolts or a loose bolt securing the driven pulley. Check the motor adjustment bolt for tightness. The noise could be from a loose wire harness, plastic purse-lock wire harness retainer on upper hose hitting the top cover or a plastic injection mold standoff on the outer tub bearing housing may possibly be interfering with the driven pulley. Also, check the drive belt for a weak spot on the belt. Usually felt on the backside of the belt as a "flat" spot. Check the belt for a weak seam and replace it.
It may also occur due to the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it.
Thanks
Jun 14, 2010 | Maytag Bravos MTW6600T Top Load Washer
I replaced the motor and it still makes noise. I am able to move the motor and get the noise to stop. Would a belt cause this? Thx
Maytag has the motor spring loaded and if the springs are weak or the belt is bad pulling on the motor may help. So yes, it could be a belt.
Dec 31, 2009 | Maytag HAV4657 Top Load Washer
The Maytag washer doesn't spin and had a burning rubber smell. Motor operates, but the drum does not spin. Belts have slack, motor pulley show evidence of belt turning which caused the burning rubber...
You should have a tensioner pully (a small wheel on a piece of spring steel) that hold the belt tight.
If that spring steel is broken or weak, then you will have to take the broken one to your local appliance repair parts shop and obtain a new one.
That should keep the belt tight and keep the drum spinning.... -Jim
Oct 23, 2009 | Washing Machines
Maytag neptune washer sounds like tornado during spin cycle
Hi!
The reason of this noise is from loose lower front weight mounting bolts or a loose bolt securing
the driven pulley. Check the motor adjustment bolt for tightness. The noise could be from a loose wire harness, plastic purse-lock wire harness retainer on upper hose hitting the top cover or a plastic injection mold standoff on the outer tub bearing housing may possibly be interfering with the driven pulley. Also, check the drive belt for a weak spot on the belt. Ussually felt on the backside of the belt as a "flat" spot. Check the belt for a weak seam and replace it.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
May 06, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag MAV 7000 stopped in rinse cycle with water in tub. When turned on, there is a low buz sound. Was making a louder noise prior to stopping.
RepairClinic.com
The top of the washer lifts up like a car hood after two clips between the top and the front panel are pushed with a putty knife. Once the top is flipped open, the screws that hold the front panel in place at the top can be removed and the panel lifted off. The belt may be bad or something may be stopping the belt like a bad pump. Or the transmission drive pulley and bearing may be going bad. If the bearings above the transmission drive pulley fail the brake will not release correctly in the spin cycle causing weak, slow or no spin. The belt & pulley system can be accessed by tipping the washer back. The belt is routed around all three pulleys under the washer and is fairly loose until the motor starts. It is the torque of the motor that gives the belt tension. Leaking or loud "jet engine" sound in spin indicates a bad main tub seal at the outer tub which has caused the spin bearing to fail. This is a complicated repair as the inner and outer tubs need to be removed from the washer to access and replace the seal and bearing components.
Go here for: Maytag-Washing-Machine-Parts
May 05, 2009 | Maytag Atlantis MAV7000
Washer machine maytag neptune front load
take the back panel off,see if the belt has broke if not,check your motor control board for burn spots ,front bottom right inside washer,if not that then your motor has gotten weak and will not turn the drum,let me knoe what you find-mike
Jul 12, 2008 | Maytag Neptune MAH5500B Front Load Washer
Burning Smell when spinning
8 yrs old....The LATs were the best models for Maytag...Maybe it's time to replace the belt..Slipping belts smell bad.
Jun 09, 2008 | Maytag Dependable Care LAT9416
Maytag Washer
Sound like you have something stuck in the pump check the hose going into from the tub
Jan 26, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Dryers Logo
52 people viewed this question
Top Dryers Experts
