Question about Yamaha YPG-635 Portable Grand Piano
Dead keys and/or multi-touch failure
My Yamaha YPG-635 keyboard's 88 keys all work when independently pressed. On a few keys, when one key is pressed and held down, the key next to it won't work. This happens for four separate sets of two-keys next to each other in random places across the whole keyboard. Is this a key or key contact failure or does a cable and/or board need to be replaced inside?
  • Steve Lutz Jan 05, 2014
    The problem is isolated to the E and F keys only throughout the entire 88-keys. Every set of E and F keys has an issue with multitouch. When the E key is held down, the F key won't work. Also, when the F key is held down, the E key won't work. All E and F keys work independently though.
2 Suggested Answers
Hacklet
  • 18 Answers
SOURCE: Roland 3000 Digital Piano 88-Key Full-size weighted keyboard
It's not really for the faint of heart, but generally this is caused by gunk getting into the key circutry. Underlying the 3000's keyboard is a silicone pad with 2 contacts on it, the measurement between each being hit is the issue usually but yours just sounds like there's something in there causing a physical or contact obstruction.
What you really want to do is to remove the keys and clean everything but this isn't easy... You could try using 99% alcohol (from a pharmacy) to clean inside it which may well help you.
There's a good thread on a similar issue at:
http://www.electronicspoint.com/roland-hp-3000s-digital-piano-dodgy-note-t18946.html
Which may help you work out how to do the disassembly if you are brave, but I would start with pouring some alcohol in and poking it and hoping for the best 1st. It sounds crude, but it works amazingly well with some things.
Posted on Jul 12, 2009
Does it have an internal battery?
HQRP AC Adapter / Power Supply for Yamaha PSR ... - Fixya
www.fixya.com/search/...hqrp_ac_adapter_power_supply_yamaha.../60...
HQRP AC Adapter / Power Supply for Yamaha PSR-280 / PSR280 / PSR-290 / PSR290 Keyboards Replacement plus HQRP Coaster, 600 related issues. ... is there an internal battery to protect memory and if so, do i need to replace it? yes there ...HQRP AC Adapter / Power Supply for Yamaha DGX-620 / DGX620 / DGX- ...
www.fixya.com/...hqrp_ac_adapter_power_supply_yamaha_psr/adapter
HQRP AC Adapter / Power Supply for Yamaha PSR-280 / PSR280 / PSR-290 / PSR290 Keyboards Replacement plus HQRP Coaster, adapter related ... need a new one, you could try to get a replacement from casio or try to get an ... It MAY appear to operate on DC BUT it can't generate the +/- voltages internally for sound .
Musical Instruments - Keyboard Accessories on Pinterest ...
https://www.pinterest.com/.../musical-instruments-keyboard-accessories/
HQRP AC Adapter / Power Supply compatible with Fulltone CATALYST / CHORALFLANGE Guitar Effects pedals Replacement plus HQRP Coaster by HQRP. $7.91. ... The MS-90 is a column monitor stand that features three internal channels - .... Yamaha SK88 Survival Kit for 88-Key YPG Series Keyboards by Yamaha.
Dec 25, 2015 | HQRP AC Adapter / Power Supply for Yamaha...
How do I adjust the contrast on the display screen of my yamaha ypg-535?
There is a contrast control knob on the rear panel of the instrument.
Oct 20, 2015 | Yamaha YPG-535 88-Key Portable Grand Piano
How do I adjust the screen contrast on this keyboard?
The contrast control knob is on the rear panel of the instrument.
Oct 20, 2015 | Yamaha YPG-535 88 Portable Electronic...
No sound on one key
That's very annoying! The keys press on to a contact strip running the length of the keyboard. Over time this wears out and notes can either stop being dynamic or stop playing altogether. You can buy the strip off ebay and have a go replacing it yourself - not too expensive. I paid someone 50pounds to supply and fit one to a 61-note keyboard.
Dec 18, 2013 | Yamaha YPG-625 (YPG625) Digital Piano
Some keys not working on yamaha ypg 235
check conection betwwin keyboard to mother board
Oct 18, 2013 | Yamaha Portable Keyboard with 61...
How to fix Yamaha PSR 400 dead keys?
Normally this would be from dirty or broken key contacts.
Apr 19, 2013 | Yamaha YPT400 61 Key Portable Keyboard...
Dead keys yamaha psr e413 keyboard
Dead keys on Yamaha PSR e413 keyboard: Flip keyboard upside down, remove cover screws (use marked cardboard template to remember where they came out), spray suspect key-contacts with fast-drying contact cleaner, (usually a PCB with a matrix of contacts under keys), re-assemble base cover, wiggle faulty keys as far as possible to 'scrub' any dirt or oxidization. If this cleaning trick doesn't work, get a pro to check it.
Dec 08, 2012 | Yamaha PSRE413 Keyboard
YPG535 keyboard is touch sensitive though one key suddenly makes a hammering (hard) sound when touching softly (seems to have lost its touch sensitivity). Does anyone have any insights on this issue?
Yep! Each key has two contacts, These are often conductive rubber pills that are pressed by the keys onto circuit traces completing the circuit. One of the contacts makes before the other so the procesor can measure the time between the closure of the two contacts. When one of the contacts doesn't make, the velocity is sensed as MAXIMUM so it HAMMERS !!!
Your problem is a contact isn't making... Your probllem to fix it is to ACCESS the contacts to clean them. Clean the contacts with ONLY 99% isoprophyl alcohol and Q tips.
Mar 01, 2011 | Yamaha YPG-535 88 Portable Electronic...
Yamaha YPG-635 Portable Grand Piano Logo
79 people viewed this question
Top Yamaha Music Experts
Michial Gueffroy
Mike
Are you a Yamaha Music Expert? Answer questions, earn points and help others
