Question about Cuisinart SS-700 5-Cup Coffee Maker
What might stop electrical slow?
Is there a fuse or circuit breaker in the Cuisinart SS-700 5-Cup Coffee Maker? Lately, this machine has been used in a home with really bad water, it was returned to me because it would not turn on. There was a significant build-up of white sediment in the water reservoir.
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 36 Answers
Hello, Vickie
Your machine does not turn on AND you have (or had) calcium deposits in the reservoir valve so, my best guess is:
First the calcium deposits blocked water from going into the heating unit.
Then, the heating unit over-heated and the thermal fuse opened to prevent a fire.
So, you may have to replace the thermal fuse.
This will require disassembly to access the water heating module, locating of the thermal fuse, reading the fuse information from the spent fuse, locating a source for a replacement fuse...etc. Thermal fuses cost about $2 at electronic supply outlets.
Ted
Posted on Mar 24, 2014
4 Suggested Answers
SOURCE: Cuisinart Grind & Brew not using all the water in the reservoir
I was having problems like this and then I read on a different string on this website that people have had success by flushing the system numerous times (sometimes up to six times) with vinegar. I took out the charcoal filter and flushed once with vinegar but only saw a small amount of improvement. I was out of vinegar so I used Lemishine mixed with water and it went from making one cup to making a full pot with one flush.
Posted on Jan 08, 2009
  • 4 Answers
SOURCE: Cuisinart Dcc-1200 coffee maker is gurgling a lot,
I had this same problem and found that coffee grounds had somehow gotten in to the water reservoir and had been circulating thru the machine clogging the charcoal filter. This must have prevented the water from entering the heating chamber efficiently and therefore continued to gurgle until it all got thru. I flushed out the reservoir by holding the pot upside down and shooting water into the reservoir. It took some time to get all the grounds out. I took out the charcoal filter, flushed out that section and replaced it with a new filter. When finished, I ran thru a solution of white vinegar for good measure and bingo!! The coffee pot works perfectly.
Posted on Mar 05, 2010
heatman101
  • 43501 Answers
SOURCE: my cuisinart keurig coffee maker
Here is a tip that I wrote that will give you some things to try that will help you get your Keurig coffee brewer working again.
Keurig Coffee Brewer not making a full cup of Coffee
heatman101
Posted on Feb 26, 2011
I have a cup o matic and it has recently started leaking from the main unit...???? Can I fix it?
you can if you can find where the leak is, and as long as it is just a worn o-ring and not a crack. You could contact Cuisinart for service? There are some articles on your particular problem in the main link at the bottom.
Pt 1: How To Use: Cuisinart SS-1 Cup-O-Matic Coffee Maker - YouTube
? 10:04
https://www.youtube.com/watch?v=jEPf5hXWkB4
Oct 18, 2007 - Uploaded by Jay Brewer
Learn how to use coffee pods and ground coffee with the Cuisinart SS-1 Cup-O-Matic Coffee Maker.
SS-1 - Coffee Makers - Discontinued - Cuisinart.com
https://www.cuisinart.com/discontinued/coffee_makers/ss-1/ Regular or bold, large or small - your ideal cup should never be compromised. Now with the Cuisinart® Cup-O-Matic™ Coffeemaker, it's easy to brew your cup ...
[PDF]Cup-O-Matic™ Coffeemaker SS-1 - Cuisinart
https://www.cuisinart.com/share/pdf/manuals/ss-1.pdf Cup-O-Matic™ Coffeemaker. SS-1. For your safety and continued enjoyment of this product, always read the instruction book carefully before using.
Amazon.com: Customer reviews: Cuisinart SS-1 Cup-O-Matic Single ...
https://www.amazon.com/Cuisinart-SS-1-Matic-Coffeemaker.../B000RIAIXO Find helpful customer reviews and review ratings for Cuisinart SS-1 Cup-O-Matic Single Serve Coffeemaker, Black and Brushed Chrome at Amazon.com.
Cuisinart® Cup-O-Matic™ Single Serve Coffee Maker - Bed Bath ...
www.bedbathandbeyond.ca/store/product/cuisinart-reg-cup-o-matic.../1014760199 Regular or bold, large or small, your ideal cup should never be compromised. Now with the Cuisinart® Cup-O-Matic™ Coffee Maker, it's easy to brew your cup ...
Cuisinart Cup-O-Matic Single Serve Coffeemaker Review
www.goodhousekeeping.com/.../cuisinart-cup-o-matic-single-serve-coffeemaker-881/ Rating: 2 - ‎1 review
Unlike coffeemakers that only make a cup at a time, this model can be used with your favorite ground coffee as well as from coffee pods.
Single Serve Coffee Forums
cup matic leaking water Google Search
Sep 03, 2017 | Coffee Makers & Espresso Machines
How can i empty the inner tank of a cuisinart ss 700 fr
Hi, Susan
I don't have your model but I'm going to guess that you should remove the external reservoir and run the machine as if you were making tea or coffee.
Mar 22, 2014 | Cuisinart SS-700 5-Cup Coffee Maker
Water continuously comes out when you press brew
Water flow meter failure. Not to familiar with this brand though.
May 20, 2013 | Cuisinart SS-700 5-Cup Coffee Maker
My cuisinart keurig ss 700 wont turn on
sounds crazy but check switch on side of machine if you have already srry wild shot in the dark (some people dont see extra buttons and switches even though they are good w electronics) took me an hour to realize i had one in plain view and i repair cell phones all day
Nov 28, 2012 | Cuisinart SS-700 5-Cup Coffee Maker
Ss-700 keeps flashin Not Ready
I had the flashing not ready problem with my SS-700 Cuisinart as well. I pressed and held the rinse and Hot Water buttons at the same time for about 10 seconds while the Not Ready was flashing. After 10 sec or so the display went off completely. I then powered up with the power switch on the side and the coffee maker came and is working fine so far.
May 13, 2012 | Cuisinart SS-700 5-Cup Coffee Maker
Leaking underneath
You are not alone having the water leak in your SS-700. For better understanding what caused that leak please read the review on Cuisinart SS-700:
http://www.cuisinartfoodprocessordeals.com/cuisinart-ss-700/
Nov 22, 2011 | Cuisinart SS-700 5-Cup Coffee Maker
Cuisinart ss-700 open head message stays on...
I have the same problem and wonder how to fix it
Feb 03, 2011 | Cuisinart SS-700 5-Cup Coffee Maker
Cuisinart SS-700 5-Cup Coffee Maker Logo
254 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
880runner
Level 1 Expert
Michael Galve
Michael Galve
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
