Question about s80 s80 spoiler, tailgate, primed 001. spoiler unpainted
The midgate and tailgate windows on my 2004 GMC envoy XUV are not working. they are down and will not go up
  • Volvo Master
  • 2,475 Answers
If this happened all at once, probably the fuse or relay controlling the electricity to these windows has blown. That fuse or relay may be under the dash or under the hood. If they failed one at a time, you may need to replace the motors and /or the regulators for these. This is a common problem on vehicles with electric windows, usually they begin to fail from 7 years to older.
Be blessed.
Posted on Jan 02, 2014
Midgate want let down 2004 Envoy XUV
Folloow the link to find instruction on replacing the window regulator for the midgate http://forums.trailvoy.com/showthread.php?t=90533
Jan 06, 2017 | 2004 GMC Envoy
Midgate closed window up dash says midgate ajar. Its fully closed
Hello Anonymous,
These system are controlled by an electronic module that should
send a fault code to the BCM (Body Control Module) and accessed via the DLC (Diagnostic/Data Link Connector) if a fault is present.
Some Auto parts stores will connect a OBDII scanner to your vehicle for free and provide you with a starting point should any fault codes be present. Fault code scanning is always the first step in trouble shooting a problem.
May 21, 2016 | 2004 GMC Envoy XUV
How to fix my rear tailgate window
check the fuse/relay. if it is neither of these check the switch with a multimeter. If you can hear the motor trying to move the glass when you try the switch it may be the regulator needs attention. It may be the motor needs to be replaced.
check fuse and relay along with the switch first then the regulator and motor afterwards. Replacing the small electronics is obviously easier than having to open up the tailgate to check the mechanics of the winedow.
Sep 13, 2015 | 2004 GMC Envoy XUV
Tail gate on 2004 Envoy XUV
The tailgate assembly requires regular lubrication and adjustment in order to keep functioning properly. If it has stopped functioning, follow the manufacturer's recommendations for periodic lubrication and adjustment.
May 12, 2015 | 2004 GMC Envoy XUV
Glass divider between passenger and truck bed does not roll up
I assume you have an XUV. Same thing happened to me a few months back. If the glass isn't broken ( and you would have heard it if it did), its the "midgate window regulator" that has failed. I recently installed one myself and it's not terribly difficult [couple of hours x 2 nights by myself - easier with another pair of hands] if you are somewhat mechanically inclined and have a basic tool set. Here's a start on finding the part: https://www.google.com/#q=envoy%20xuv%20midgate%20regulator Google : "envoy xuv midgate regulator installation" and you'll be able to see a few examples.
Mar 14, 2014 | 2004 GMC Envoy
04 GMC Envoy XUV midgate window fell won't come back up; motor runs ,window won't move
The same thing happened to my '04 XUV. Discovered broken white nylon/plastic that retains the end of the lift cable. Ordered a new lift gate motor/mechanism assembly ($250) online and replaced it myself. Be sure to buy a new limit switch ($13) also. I did not and regretted it because you must remove the old limit switch from the old motor assembly so you can re-assemble it to the new motor assembly. While removing the old switch from the old assembly, I broke it. Had to then order a new switch. The cost to ship the switch separately was more than the switch. The whole thing did not really take that long and was surprisingly easy. It works great now.
Dec 13, 2010 | 2004 GMC Envoy
Tailgate will not open at all, i can unlock the doors, but the end gate will not unlock, how can i open it. 2004 envoy xuv
do you have the tailgate with the window in the upper half and does the window open?
Oct 11, 2010 | 2004 GMC Envoy
2004 envoy xuv tailgate problems, will not latch or open sideways. I have a 02 Envoy SLT the rear liftgate Dose not have power. the wipers dont work the Lock dont work I can not program my keyless entry....
I also have a 2004 GMC XUV. My gate would go down but not swing open. In trying to fix it, the gate then refused to go to the flat position.I have removed the cover plate on the gate and found the one of the solenoids loose from its mounting. Resetting the computer by disconnecting both battery leads and holding them together for ten seconds worked to restore function to the gate going flat, but the swing still does not work. I believe it is a bad solenoid or motor for the bottem left latch pin.
Feb 24, 2009 | 2004 GMC Envoy
s80 s80 spoiler, tailgate, primed 001. spoiler unpainted Logo
80 people viewed this question
Top Volvo Vehicle Parts & Accessories Experts
xxxxxx xxx
Thomas Perkins
Thomas Perkins
bosy1
Are you a Volvo Vehicle Part and Accessory Expert? Answer questions, earn points and help others
