Question about Air Intake Hose Ssangyong Rodius 2 7xdi Hump Bellow 3 25-3 5 Inch Od
Airbag light on a ssangyong kyron 2.0 l xdi auto 2006 need to find relay for it tried all connections under front seats does anyone know location of relay thanks
There is no problem with airbags but light is constantly lit when ignition is on
There is a problem but you'll have to plug it in to a computer to read the fault code and then clear the memory to put the light out. If it comes back on you'll have to fix whatever problem is showing up on the diagnostic
Posted on Jan 04, 2014
Diagnose 2006 Scion tc SRS code B1826 lh circuit
there is a TSB available if you're under 60,000 miles take it the dealer.
light occurs when:The center airbag sensor assembly receives an open circuit signal in the side squib (front passenger side) circuit for 2 seconds.
possible trouble areas include:Front seat airbag assembly RH (side squib (front passenger side)), Center airbag sensor assembly, & No. 2 floor wire.
Jan 21, 2017 | 2006 Scion tC
Glow plug light
the light is on because there is current flowing to earth. I would be checking the relay as it may be failing and is turning on the glo -plugs when it is not necessary
Mar 11, 2014 | SsangYong Cars & Trucks
Airbag light eluminated need to turn it off please help tried all connections under seats but light still on someone told me to find relay for airbag but cant find location its on a ssangyong kyron 2.0 l...
Sorry to tell you this but this light is run from the BCM. you have to go to your dealer for a diagnostic or the other option is a pretty smiley face over the light
Dec 30, 2013 | Air Intake Hose Ssangyong Rodius 2 7xdi...
Pollen filter
The filter will clean most of the pollen and other particles up. Just be sure to clean or replace the filter regularly. Some modern air conditioners will let you know when they think the s dirty and needs to be replaced usually located in the front if u have allergies id say wear a mask and if u talking about a car it's under dashboard u can't miss it
Nov 25, 2013 | 2010 SsangYong Kyron 270
Ssangyong kyron wont start when cold
I had a similar problem with my Ssangyong Rexton. Unfortunately, it is the injector pump, the filter gets clogged with micro-particles of crud. Take it to a diesel pump specialist (as a Ssangyong dealer won't know what to do in my experience and they will charge $000's to fix) and get them to remove and clean the injector pump.
Oct 14, 2012 | 2007 SsangYong Kyron 2.0D
I have a 2006 Jetta and the airbag light is coming on. I have been through a factory recall fix and a software upgrade and now the dealer wants to charge me 400 bucks to troubleshoot the wiring. Does...
if the airbag light is on then its not a fuse ,most likely cause is the wiring under the seat or the serpentine winding under the steering wheel airbag ,try disconnecting the battery then cleaning the connection under the seat and also the plug into the pyrotechnic device on the seat belt anchorage.If you still cannot get it right then use a diesel preheater timer relay and connect the airbag light through this so the light goes out after a few seconds then vehicle will pass its vehicle mechanical inspection test
May 02, 2011 | 2006 Volkswagen Jetta
Airbag light staying on
You need to connect to vag com or some else computer program to see the error code and when remove prroblem you need to delet the error from car computer memory to get rid of the light.
The most common problems are: blown fuse, bad connection under the seat or something like that! But you can't do nothing without the comp.
Nov 30, 2010 | 2006 Volkswagen Jetta
The airbag light came on and stayed on for no reason.
I have the same issue (which comes and goes often).
It is caused by a loose wire connection, used for the drivers side airbag located in the seat.. The connector for mine is located under the front drivers seat. There are a couple of connectors that are connected to a bar under the front of the seat. I don't recall which one is used for the Airbag sensor.
Feb 15, 2009 | 2000 Chevrolet Impala
Airbag light
i found it at last. there was a loose wire under the driver seat. as simple as such.
Jan 12, 2009 | 1999 BMW 323 Series
Air Intake Hose Ssangyong Rodius 2 7xdi Hump Bellow 3 25-3 5 Inch Od Logo
115 people viewed this question
Top Magnum Tuning Vehicle Parts & Accessories Experts
mekanik84
 Robert
Robert
Level 1 Expert
xkikbxr
Are you a Magnum Tuning Vehicle Part and Accessory Expert? Answer questions, earn points and help others
