Question about 60 series Diesel Power Service Manuals On-Highway
Mower wont start think its the seleniod ?can somebody please tell me how to put a new one in
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 10 Answers
I can tell you that throwing parts at a mechanical or electrical problem that you have not properly diagnosed is like playing the lottery (crappy odds). I assume you are talking about a starter solenoid. how 'bout checking to see if its bad. Step 1: check battery (I said check not replace). Step 2: Find the solenoid and make sure its getting power. There should be 2 pretty thick cables connected to it and one smaller wire. 1 of the large cables should be hot at all times, the other large cable should ground through the starter, and the little wire is the "signal" wire from your ignition switch. The signal wire is only hot when your turning the key to crank the starter. Step 3: If you've got power to 1 big cable, and ground at the other big cable then find something conductive that is at least as thick as the cables (i use a wrench, screwdriver, pliers... whatever) and touch it to both terminals for about 1-2 seconds (where the cables connect to the solenoid). Be warned, there will be some sparks, and the tool may stick to the terminals (weld itself) a little. You are effectively bypassing (jumping) the solenoid by closing the connection with a tool. If it cranks while jumping the solenoid, and you are getting voltage on the signal wire, then you need a solenoid.
Posted on Dec 31, 2013
  • Francisco Pintado
    Francisco Pintado Dec 31, 2013
    I can tell you that throwing parts at a mechanical or electrical problem that you have not properly diagnosed is like playing the lottery (crappy odds). I assume you are talking about a starter solenoid. how 'bout checking to see if its bad. Step 1: check battery (I said check not replace). Step 2: Find the solenoid and make sure its getting power. There should be 2 pretty thick cables connected to it and one smaller wire. 1 of the large cables should be hot at all times, the other large cable should ground through the starter, and the little wire is the "signal" wire from your ignition switch. The signal wire is only hot when your turning the key to crank the starter. Step 3: If you've got power to 1 big cable, and ground at the other big cable then find something conductive that is at least as thick as the cables (i use a wrench, screwdriver, pliers... whatever) and touch it to both terminals for about 1-2 seconds (where the cables connect to the solenoid). Be warned, there will be some sparks, and the tool may stick to the terminals (weld itself) a little. You are effectively bypassing (jumping) the solenoid by closing the connection with a tool. If it cranks while jumping the solenoid, and you are getting voltage on the signal wire when turning the key, then you need a solenoid.
Cub cadet trouble shooting
Check the "engage" switch. If it is shorted, it will drain the battery.
Jul 07, 2014 | Garden
How do you replace a starter seleniod on a Craftsman riding lawn mower, 17.5 HP?
It mounted to panel under the dash. Unhooked battery, (2)then unbolt solenoid,(1)then unhook wiring. Install new.
May 17, 2014 | Craftsman Garden
My 1985 F250 starts then dies after a few seconds of running. I put on a brand new ignition control module, and that wasnt it. I also replaced the ignition coil, ignition coil cap, and Bought a bran
By your description it sounds like you have carburetor issues, Possible clogged metering jets , a float problem , throttle adjustment or even possibly a major vacuum leak.
Feb 10, 2014 | Ford F-250 Cars & Trucks
Where i put the oil, i dont know where, somebody please tell me, thank you
There should be a small plug on the side of the engine close to the deck. It will either have a slot in it or two small round tabs. YOu can loosen it with a screwdriver. The oil should be filled to the top of the opening you can see looking down in the hole.
Oct 01, 2010 | Yard Machines 50 Torque 2in1 22" Push Lawn...
My tractor mower wont start. I have put in a new
If your starter does not have a solenoid on it,you can tell by checking to see if has only one post[no solenoid ]or three posts[solenoid style],then you need to check the starter relay[ or solenoid] that is mounted elsewhere on the machine.If there is a wire that goes to ground on it and one that comes live with the key in the start position the the solenoid[or relay],is defective.If you have no power from the ignition switch in the start position then you likely have a bad safety switch somewhere,usually the pto or park brake switch.
May 12, 2010 | Garden
Car won't start
buy a cheap volt meter check voltage on both sides of the starter seleniod on the fenderwell if you have 12 volts on both sides while cranking test voltage at starter if you have 12 volts at starter with fully charged battery and it doesnt start you will need a starter it also sounds like you might need an alternator once you can get it started
Dec 09, 2009 | 1984 Ford Crown Victoria
60 series Diesel Power Service Manuals On-Highway Logo
Top Detroit Red Vehicle Parts & Accessories Experts
Lawrence Oravetz
Gloria Vernon
Gloria Vernon
Level 1 Expert
Lucy Angela
Lucy Angela
Are you a Detroit Red Vehicle Part and Accessory Expert? Answer questions, earn points and help others
