Question about Diesel Anti-Intelligent
Dont know how to adjust time
I have no manual for this watch and i cannot adjust the time
I need to know how to set my skmei watch
I need to change date and time for skmei 1065 pls help me ;)
May 07, 2012 | Watches
I have a watch Casio Sheen watch for women..It was set my the sales clerk when i bought it in Macau which have the same time in the Philippines. I am currently in Qatar now which is 5 hours behind the time...
Hi,you need to look at the user manual..and since you do not have it , to download a soft version of the user manual pls visit the URL below..
Hope this helps! Take care and please Remember to rate/vote and give me
4 Thumbs Up for me to continue for Helping out the Community :)
Thanks
CASIO Watch User Manual Archives http://world.casio.com/wat/download/en/manual/
Use this page to download a copy of CASIO watch manuals in PDF format.
To download a PDF file, enter the four-digit (or three-digit) module number marked on the back cover of your watch.
Jun 21, 2011 | Casio Sheen watch #SHN140D4A Watch for...
I don't know how to set the time on my trailsman sport watch the number on the back of the watch is lwl189b 107 cr2016
Thank you for contacting FIxYa.
I dont know anything about this watch, Is it a digital? If so, here are generic instructions for digital watches that might help.
CHANGING DIGITAL TIME:
  • Examine your watch. Attempt to find its "Mode" button; nearly every digital watch has one. The various modes might include "Date," "Alarm" and "Stopwatch" among others. Repeatedly press "Mode" to cycle through the modes available on your watch until you have it in the mode that displays the current time.
  • 2 Locate the button that allows you to adjust the settings on your watch; this button could be labeled "Set" or "Adjust." Once you've found this button, press it in and hold it. After a few moments, the time display should begin to flash.
  • 3 Select either minutes or hours as the aspect of the time you'd like to adjust. Press the "Mode" key to cycle through your options; each element should begin to flash as it's selected.
  • 4 Press a button to adjust the time element you've selected; the button for doing this will vary from watch to watch. If there are up and down arrows on your watch, use them to increase or decrease the number. A button labeled as another function could serve this purpose too; trying pressing the various buttons on your watch to discover the correct one to adjust the time.
  • 5 Move on to the next element you want to adjust, such as minutes or the date, by pressing the "Mode" display.
  • 6 Press the "Set" button to finalize the new time on your watch. You'll know that the time has been set when the numbers stop flashing.
  • Best regards. Jewel
    Sep 14, 2010 | Watches
    I dont know how to adjust time
    You can download a manual or contact Tissot direct at this link:
    http://support.tissot.ch/
    Best regards
    Aug 19, 2010 | Tissot T-Touch T33159851 Wrist Watch
    I dont know how to change the time? I have no
    to press left side upper button and right side butom button to set the time
    May 16, 2010 | Casio BabyG Shock Resistant Blue Sports...
    Rado diastar swiss 196-0364-3
    I bought the same watch recently and have the same problem. The hours can be adjusted in the dual time zone by looking up the manual, but the minutes stay put. I can't bring them to blink so that these could be adjusted. Any ideas? I sent a mail to Rado through their website but no answer.
    Jan 06, 2009 | Rado Coupole R22531723 Watch
    Nike watch problem
    Okay, mine's a Chisel but I'm pretty sure the module is similar, if not the same, across the Mettle range.
    Anyway, press and hold the light button - marked adjust - until the display says "hold to adjust"; after a couple of seconds the time display will return and the hours will be flashing.
    To adjust up, press "start/+" and down press "stop/-". To cycle through the options, press "mode".
    Once you're done, press the "adjust" button again to return to regular timekeeping mode.
    Enjoy your Sledge - if you don't I'll have it!!
    Regards,
    Martin.
    Jul 16, 2008 | Nike Mettle Sledge Watch WC0040 096
    I have a Casio CPW-310-1VDS watch. Is there a special procedure to change its battery? This is watch has the ability to notify the wearer of the times for prayer (a popular model worn by Muslims) and also...
    Guys, I just realised that there is a mark called AC on the back of the module next to a gold small circle pad. Once you change the battery, you need to connect a wire or paperclip or something similar between the back or positive of the battery and the pad, it should then come alive. Good luck
    Apr 26, 2008 | Watches
    Analog setting
    The solution is in the user manual: pres "mode" six times, then press "adjust". The minute hand can only advance, by pressing "search", holding it pressed or pressing "light" and "search" at the same time. When you are satisfied with the settings, press "adjust" again to finish the procedure.
    Nov 13, 2007 | Casio AW80-7AV Wrist Watch
    Diesel Anti-Intelligent Logo
    35 people viewed this question
    Top Diesel Watches Experts
    Ansel Alberto
    Ansel Alberto
    Jimmy Accardi
    Are you a Diesel Watch Expert? Answer questions, earn points and help others
