Question about Air Intake Hose Ssangyong Rodius 2 7xdi Hump Bellow 3 25-3 5 Inch Od
Airbag light eluminated need to turn it off please help tried all connections under seats but light still on someone told me to find relay for airbag but cant find location its on a ssangyong kyron 2.0 l xdi auto
    Sergeant:
    Champion:
  • 293 Answers
Sorry to tell you this but this light is run from the BCM. you have to go to your dealer for a diagnostic or the other option is a pretty smiley face over the light
Posted on Dec 30, 2013
Why is the passenger airbag light on?
Could be a problem with the sensor in the seat. The system thinks someone is sitting in the seat and the seat belt is not fastened.
Nov 19, 2015 | Cars & Trucks
Turn of the airbag light
Hey, my mate had a problem like that, with the airbag light beeing on, just in a Mini, he went to a garage and they told him the sensor in the passenger seat was broken, and the entire seat needed to be changed, costing around 2.250$. He searched a little around and found an airbag emulator, that gets your system to think someone is always seated. In case of an accident the airbag will ALWAYS go off, on both driver and passenger seat. He found it on amazon: http://www.amazon.com/gp/aag/main/ref=olp_merch_name_1?ie=UTF8&asin=B00E3C1IPW&isAmazonFulfilled=0&seller=A3VPDTQ49IXC7U - it is a quick fix, but a solid one.
Mar 01, 2014 | 1999 Ford Mondeo
Airbag light staying on BA Fairmont
Poor connection on yellow connector under a seat causes problem. If blinks two times x 9= driver side problem if two+tree times = passenger side .This connector supplies power to airbag installed in a seat . Try first to move connector or pull wires gently to gain contact . If on another restart works fine you solved it but it wont last because wire contacts are loose . Use imagination how to gain permanent contact! i have used soldering method after a few times had to take seat out. Problem is if more than one driver drives a car and seat adjustment is needed regularly.
Hope it helped to someone...
Dec 18, 2012 | Ford Fairmont Cars & Trucks
I have a 2006 Jetta and the airbag light is coming on. I have been through a factory recall fix and a software upgrade and now the dealer wants to charge me 400 bucks to troubleshoot the wiring. Does...
if the airbag light is on then its not a fuse ,most likely cause is the wiring under the seat or the serpentine winding under the steering wheel airbag ,try disconnecting the battery then cleaning the connection under the seat and also the plug into the pyrotechnic device on the seat belt anchorage.If you still cannot get it right then use a diesel preheater timer relay and connect the airbag light through this so the light goes out after a few seconds then vehicle will pass its vehicle mechanical inspection test
May 02, 2011 | 2006 Volkswagen Jetta
The airbag light on my dash will not go off when i turn on car,but it will go off when someone sits on the seat(front passenger),can you help please?
Thats the occupancy under the seat base at fault. Check to see if its connected properly under the seat. If not you will need a new one. Quite a common fault i had it with my 330.
Feb 22, 2011 | 1999 BMW 318 ti
2003 TT Air Bag & Seat Belt warning lights not eluminating
It is fairly complicated to remove the instrument panel to replace the light bulb. It requires you to remove the steering wheel and airbag module and several other components.
The sound you hear may be the coolant pump for the turbo.
Sep 10, 2009 | 2000 Audi TT
Airbag light won't turn off
listen some times the airbag comes on due to a bad car seat belt relay or motor! if one of ur car seat belt doesnt work! thats were u gonna have the problem they all have a sensor under the car seat and a scanner shuould pinp point ur problem if u go to air bag
May 03, 2009 | 1998 Chevrolet Monte Carlo
Airbag light on
Whoever Told you that is an Idiot! There is a Relay for the Air Bag System Under the Hood in the Fuse Relay box. Sometimes the Dealer must reset But, Not usually.
Jan 24, 2009 | 2003 Hyundai Tiburon
In my Equinox 2007 , i repaired under seat and cleaning after that the Passenger air bag is shown OFF , what cause and solution please ??
The airbag will not be active until enough weight is in the seat, I believe it is somewhere around 70 pounds. Try having someone sit in the seat and see if the airbag is turned on. Let me know if this helps and please rate this solution.  lone99star
Jan 11, 2009 | 2005 Chevrolet Equinox
Air Intake Hose Ssangyong Rodius 2 7xdi Hump Bellow 3 25-3 5 Inch Od Logo
64 people viewed this question
Top Magnum Tuning Vehicle Parts & Accessories Experts
mekanik84
 Robert
Robert
Level 1 Expert
xkikbxr
Are you a Magnum Tuning Vehicle Part and Accessory Expert? Answer questions, earn points and help others
