Danesmoor slpj20-25 Arrived after being away when oil had run out but refilled. Boiler ran for a day then the boiler stopped and lockout happened. When we tried to restart there was a humming sound and then lock out occured again. We cannot now restart it. Any ideas?
Hi try this link and go to page 16 fault finding it should give you a clue, I think it may just need bleeding. http://www.bhspares.co.uk/wp-content/themes/RevampV3/manuals/Worcester%20Bosch/DanesmoorSLPJ15-19.pdf Cheers Andy
Posted on Dec 30, 2013
2 Suggested Answers
SOURCE: My oil boiler is a
The actual final solution was to replace the fuel valve/solenoid following which the boiler has run without failure.
The conclusion was that the fuel valve solenoid was ok when cold but when heated up had some sort of electrical breakdown in its coils, causing the fuel valve to fluctuate until the boiler locked out.
Posted on Oct 17, 2008
Ran out of oil, when refilled managed to get heating working but oven not
How to bleed and restart your oil heating. - Instructables
www.instructables.com/.../How-to-bleed-and-restart-your-oil...
InstructablesGo to the oil tank and make sure there's oil in it, or you'll be wasting your time. ... you to get lucky but it has happened to me and it seems to help get the fuel moving a ... I am thinking the boiler is not working so do not want to spend money buying lots of ... Bleeding brilliant - now the wife doesn't have to know we ran out of oil!Missing: oven
how to mend it .com - Clearing airlock from riello oil burner?
www.howtomendit.com > Heating, Oil Filled Radiators
The temp knob on my bosch oven has stopped working. ? Search: Go ... I've now replensihed the oil but the system keeps cutting out after a few moments trying to ignite the oil. ... With guests arriving to rent my house yesterday, I ran out if fuel,refilled and ... Have now managed to restore heating and hot water to my house.
My Craftsman lawn mower wont start after it ran out of gas ...
www.shopyourway.com > Manage My Life > Questions
Dec 21, 2015 | Ovens
Hi. We have a potterton netaheat profile boiler and the pressure has dropped so low nothing will work. I know it needs to be recharged but don't know how to do it. The only visible pipes are on the top...
The cold water feed to the boiler is where you will find the refill point which should be at the base of the boiler where all the pipes come in
Oct 06, 2017 | Water Heaters
Weill mclain oil burner beckett burner starts and stops
So you are saying it will run and shut off but NOT go into lockout? What is the boiler temp? Do you have a low water cutoff ?
Jan 27, 2018 | Heating & Cooling
Potterton statesman oil central heating boiler the household oil ran out and i had it refilled and now the lock out button is illuminated i believe i have to press the burner reset button but not sure...
Hello my name is Heath it will be my pleasure to assist you. You will have to push and hold the reset in on the side of the control for 15 seconds. But you will also have to bleed the air from the system from the 3/8 nipple on the lower left side once the lockout has been released and the motor starts.
Sep 05, 2010 | Heating & Cooling
On the ideal c95ff the boiler the red neon lockout
overheat stat , does it come back on with reset ?best of luck
Jul 23, 2009 | Water Heaters
I need to restart my boiler after running out of oil
Try a website called www.repairclinic.com and see if that will answer your problem.
Jan 19, 2009 | Water Heaters
My oil boiler is a Danesmoor SLPJ 20-25 with an Electro Oil Inter 2011 burner. The oil tank ran out and after refilling the burner ran ok for approximately 6 minutes, the control box chattered and the...
you could have a problem with a temperature sensor.
it would not be the flame sensor since it could not wait 6 mins to sense that there is flame in the unit.
could be a temperature sensor problem where it is sensing a temperature which could be correct but it is sending a wrong signal to the controller to turn off the flame and start another cycle.
tnx 4 using fixya,
drcool
Oct 04, 2008 | Heating & Cooling
Oil fired boiler
Check how all three "on/off" sequences are programmed firsrt, then all other programmable options. Make sure sliders are in the sliders are in the correct possition. If it becomes more complicated than launching a space shuttle, reset it. Unless your house is a mansion keep it simple with just day and night modes. the money you save wont even cover the cost to fix the hole you punch in the wall trying to do fancy programming ;-D
Nov 24, 2017 | Honeywell Programmable Thermostat Heater
Oil boiler won't run
What make and model burner do you have?
Feb 23, 2008 | SySTOR Systems (400S52) Burner
Heating & Cooling Logo
93 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
