Question about Honeywell he225h8908 bypass humidifier,12 gpd,w/ humidistat
Honeywell HE225 flow-through humidifier leaks water
4 Suggested Answers
SOURCE: Continous ware flow on Honeywell HE220A Humidifier
I am having the same problem. I have had my humidifier for about 5 years now and I just started having the problem where the water continuously flows through the solenoid. I took apart the solenoid by removing the fittings from both sides. When I did that, I noticed that there was a hole in the metal that allowed me to see through to the other side. Apparently, it had corroded and and broken through, allowing the water to pass through the solenoid without really going through the valve within the solenoid. There are several sites that sell replacements for about $70, which is not cheap, but cheaper than buing a new humidifier for $120. Here is one site I found: http://www.iaqsource.com/product.php/honeywell/32001639-002/?product=112783&category=1142
Posted on Nov 20, 2008
  • 9 Answers
SOURCE: Honeywell HE225 Humidifier will not draw water
Check for 24volts at the valve. Some techs install these so it only comes on when the furnace calls for heat. It should have its own transformer.
Posted on Jan 19, 2009
  • 189 Answers
SOURCE: No Water flow thru Humidifier
Loosen the brass fitting where it connects to the soleniod valve. If water comes out your saddle valve is ok. Carefully retighten this fitting. With the humidifier turned on loosen the first fitting down stream from the valve see if water comes out. if it does turn the humidifier off and see if it stops, it should. That will tell you the the valve is ok then, just clean the filter and the oriface. if it does not turn on and off check the wiring. if ok replace the valve.
Good luck
Posted on Mar 29, 2009
How to connect the wires from the H8908A Humidistat and HE225 Humidifier to a carier model 58 STA090-14 furnace please? Thank you.
Not sure how much this will help you, but here is a link in pdf format to the Installation Manual, if you don't have one http://www.honeywellcentral.com/ssi/pdf/honeywell-commercial/HE220-Installation.pdf
If all else fails here is a number for Honeywell. Ask for Technical Support. (877) 841-2840
Feb 09, 2011 | Honeywell HE220A1019 Whole House...
Hi, We have a new house fitted with a Honeywell HE225 humidifier. It does not seem to work. Doesn't matter what we set it to, there is still way too much condensation on all the windows. We ended up...
Cut the power to the whole house humidifier and turn off the water pipe to it. If you want it running in the winter, put the water back on, but put a timer or a humidistat on the power cable to only allow it to run a certain amount of time per day, or to only run it the humidistat shows an RH lower than 45 percent (or whatever your comfort level is).
May 27, 2017 | Honeywell HE225B Humidifier
I have a Honeywell humidfier HE 220A with a KIP U147112 pump. A lot of water bypasses the humidifer and I use 5 gal. in 24 hours. is there an adjustment on the pump to reduce the flow, or some other...
I have a Honeywell humidfier HE 220A with a KIP U147112 valve. Will turning the large screw head on the valve decrease the volume of water flow through the humidifier. Too much water is being wasted.
Dec 20, 2010 | Honeywell HE220A1019 Whole House...
Water flow from humidifier never stops. Even when furnace is off.
No, it will not stop flowwing if it is the water supply. A solenoid valve opens the flow everytime there is a call for humidity, but it stops at the humidifier when there is no call, so it will leak from that point until it is fixed or tightened.
Apr 17, 2009 | Honeywell HE365 Humidifier
My HE260A is discharging too much water
these are flow thru models and a lot of water passes thru them. The instructions say to not limit the water by closing valve at all!
Feb 22, 2009 | Honeywell HE220A1019 Whole House...
Jan 02, 2009 | Honeywell HE220A1019 Whole House...
Good luck
Nov 22, 2008 | Honeywell HE365 Humidifier
Water leak
Sounds like the air flow is too great and it is blowing the water in the bottom of the tray around before it gets a chance to drain. Try placing your summer, winter damper at half closed to slow the airflow down a little.
Nov 19, 2008 | Honeywell HE220A1019 Whole House...
Lack of humidity
Try the following test, ( I will resume this is a flow through humidifier)
Spray water directly oin the filter make sure it is saturated. Some water should leak from the bottom. After 10 min measure the Humidity to see if this helped. If there is a higher level of humidity the pbm is that not enough water is saturating the filter. Check the level of the filter & water feed nozzle.
Option 2 is to connect the water feed tube to a Hot water source.
Hope this helps.
Dec 28, 2007 | Honeywell HE220A1019 Whole House...
Water flow through humidifier
I installed this humidifier (and had a lot of trouble installing it!) and was surprised by the flow of water. Mine leaks out of the bottom of the unit so I haven't actually used it yet. I'll try to figure out why it's leaking this weekend. I thought there would be less water flowing through the pad. I suspect that the weight of the unit is causing it to not be plumb so some water is dripping off of the pad and past the drain tray.
Nov 30, 2007 | Honeywell HE360A1027 Whole House...
Honeywell he225h8908 bypass humidifier,12 gpd,w/ humidistat Logo
211 people viewed this question
Top Honeywell Humidifiers Experts
Dennis
jdthefixer
Bill Long
Are you a Honeywell Humidifier Expert? Answer questions, earn points and help others
