NO ME PERMITE INSTALAR EL SISTEMA OPERATIVO
SOURCE: SMART Failure Predicted on Hard
Changing the hard drive is a last resort. action. Loose or defective hard drive data cable as well as data corruption can cause the same alarm. Disconnect and reconnect the data cable. Download seatools and run it.
SOURCE: smart failure predicted on hard
It means that your hard drive is going to crash soon. If all of your important stuff is on there and you don't have an external hard driver or flash driver, shut down the computer until you do. Once you own another hard drive, boot back up and start the backing up process. There is a fantastic free backup program available here:
http://www.fbackup.com/
One trick I've found that works is placing the hard drive in a refrigerator for 30 mins before using it. This will extend it's life by at least 15 minutes.
Good luck to you, and pleas leave me a positive rating! :)
SOURCE: smart failure predicted on hard disk 4 toshiba
You may continue on and boot the system.
However it is time to backup the data on that drive and replace it.
the S.M.A.R.T system is a warning.
SMART failure error means your hard drive is dying and there is no way to make it working for a longer period of time.
Soon, your hard drive will fail permanently and won't give second chance to work and so prevents you to access any of your important data.
So, before disaster strikes, you're highly recommended to backup and replace your hard drive as soon as you can. Otherwise, you might be in big trouble.
Hope it helps!!
HI
PLEASE VISIT THE SITE
http://www.ookz.com.pl/presario-2100/
http://www.driver-updater.net/0/HP/
Regards
Vipin Kakkar
