Question about Sony VAIO PCG-K23 Notebook
Replace Mother board
How do I remove the mother board?  I have removed all visible screws, but there seem to be 2-3 places that are still fastened down.  How do I release those areas that don't appear to have any screws?
  • thibby3 Oct 19, 2007
    I finally figured it out.  The speaker enclosure just pops out without any screws.  This revealed the screws to remove the keyboard.  After that it is quite apparent how to keep proceding.  I was trying to remove the back of the laptop first.....
  • 64 Answers
You did not provide a model number but did you remove the keyboard first?
Posted on Oct 19, 2007
  • Fred Steinberg
    Fred Steinberg Oct 19, 2007
    Sorry, I did just see the model number.
Stuck mother board hp pavilion 764c
Check to see if the ports themselves are screwed to the back panel of the case. I don't know about your specific model but usually if you get all the screws it should lift out no problem. Also, you should not need to remove any motherboard components to get at these screws, they should all be visible.
Feb 03, 2014 | HP Computers & Internet
Dell dhm capacitors
There might be screws that hold the motherboard to the metal cover or there is a latch that you can press that will make it slide out.
It's easier to replace the motherboard than try to fix the capacitors.
May 13, 2012 | Dell Computers & Internet
Power will only stay 0n for a few sec and then shuts off
Hi,the problem with your ps3 is a heat sync failure,it's a common problem with the ps3,however,here is a detailed solution to help you out;
You have to disassemble the ps3 first, (hint) there is a srew were your rubber boot is on the bottom were it stands up remove this srew but you my have to get a star bit with a hole in the center of it. 2. After removing the cover then sides to the screw,lift the cover to remove all visible screws in the second cover.
3. Lift the second cover in a hinged motion to the front of the ps3 be careful not to pull the hidden carbon wire underneath of the cover if done properly you will see the wire when you lift the cover. To release the wire you must lift gently on the black clip holding it and it will release with no problem.
4. You then lift the blue ray drive up and then dissconnect the wires to it. then remove the power pack which is to the left of the blue ray drive remember there are screws holding this down, remove the wires then remove this peice as well, then remove any remaining screws on the mother board cover except the large philip head screws holding the clips that are in a slant. lift the mother board out to reveil the fan on the bottom now remove the srews that are slanted. the fan will then seperat from the mother board. then clean both of the contacts on the mother board and fan with rubbing alcohol. then seperate the metal from the mother board.
attention; there will be a watch battery connected to the metal,disconnect from the mother board. gently lift up on the metal to seperate the mother board from the metal. At this point you must be extra careful not to move any of the parts on the mother board remove the rubber peices then cover the heat syncs so they dont melt use a heat gun that can reach a temp. of 350 degrees Cel heat for 15 sec on the three heat sinks with a distance of 1 inch or greater move the heat gun counter clockwise on the sensors. during this time the peice must be level or it will hurt the system. After heated you will then need to let cool for 15 min. then flip the board over and hit the exact same spots in the same steps. at this point your problem is solved. Make sure all the peices of rubber that was on the chips is put back in the right spots too.You then put the metal back on the systems mother board at this point clean the syncs again then apply the artic silver in a thin bead on two heat syncs note not too much and not to little just enough to cover the syncs with a thin coat then connect to the fan. reconnect the fan then put the screws back in that holds them together then reattach the power supply but dont srew it down then remove the srews on the fan moter then remove it plug in your system switch it on stand by then press the sensor pad metal to start the system note this will not hurt your system this causes the artic silver to soder the heat syncs together only do this till you see a orange light come from the board near the fan then shut the system down then reattach the fan and reassemble.
Take care
Jun 19, 2010 | Sony Playstation 3 (PS3) Console
How do i replace fan acer 5739g
1.first remove battery and adopter.remove back side covers,wireless lan antenna
2. remove all the screws in bottom side.
3.just above the keboard ,the front panel neds to removed with little preasure from fingers and remove the flat cable jently. remove lcd panel cable,pull out wlan cable in upword direction.
4.un-screw screws over keyboard and lift the keyboard,look at the bottom remove the flat cable(the brown colored lock should be pushed up jently.
5.remove the touch-pad flat cable similarly & remove
any other cables
6.jently pull the top panel towards you with fingers( observr any cables/wires conected to mother board)
7.once front panel is removed remove other cables /wires connected to usb/phone socket/wlan.
8.un-screw the screws with arrow indicater to remove mother board from back panel.
9. remove the screws form heat sink attached fan jently.
replace the fan or heat sink with fan of the same part number.( a.  put few drops of any oil betwen gap pan blade and plastic it might clear dust    b. in case fan is smooth then 5 volts wont be comming from mother board(red wire) then u requir proffesional help ).
10. follow the reverse procedure to assemble the laptop.
*****before you start any work ground ur body start with bare foot as all devices are esd sensitive. try with your own risk iam not responsible for consiquential
damage to device/person .these are just hints to help*****
Mar 11, 2010 | Computers & Internet
Model: TFX27PFSM BB Ice/water dispenser mother
The board will remove by prying at the bottom of the board . Sometimes I can use my hand only , pulling out from the bottom , to remove . Other times , I have to pry from the bottom to remove . Do not try to remove the dispensor frame , only the board .
Oct 10, 2009 | GE Profile CustomStyle PSI23NGR Side by...
How do I change a Samsung SGH-F700V Glass Digital Touch Screen?
It is a pain but, what you need to do is to remove the mother board from the back piece . The Camera Lens Piece is about 6 screws after which you have access to the mother board there is a small screw in the center of the phone if the  you was looking it at from the back for a picture  you would see it where the battery was located when you carefully remove it you or slide it to the side you will now see the access holes for the other two screws of the digitizer make sure it is slide open as in the keyboard is visible and you should be able to see them
May 24, 2009 | Samsung Ultra Smart F700
Can't get to the mother board on Acer Travelmate 4011
All i can really offer for help is to try to remove the screws on the underside of the notebook. That is how i have to remove the keyboard on my Sony vaio. I cannot find anything online that describes how to remove the keyboard. But i can say when you get the keyboard off follow the link i provided above and click on the link that says "How to fortify damaged power jack connection in a laptop" This gives excellent instructions on how to repair this jack.
Or if you want to buy a new one follow this link to buy one off e-bay.
If you look on the laptop repair link it gives you a good idea about how to remove the keyboard so follow those directions as close as you can. And remember that these computers use a lot of snap fasteners so some stuff may be snapped in place and not screwed down.
Jan 28, 2009 | Acer TravelMate 2300 Notebook
Replacing the mother board on my LG machine washing
disconnect power remove screw from back holding down top,slide top towards back. control panel is located on left rear of cabinet. remove 1 screw on back which hold panel in place. panel will side to inside to release from cabinet , pry open cover disconnect all connections (all connectors are color coded and are diffrent sizes)reverse process. hope this helps
Dec 15, 2008 | Washing Machines
Dell Inspiron 1000 Disassembly
The teardown information from rbrown67 was very accurate and easy to follow. It helped tremendously in tearing down my machine to replace the AC plug.
Mar 14, 2008 | Dell Inspiron 1000 Notebook
Sharp actius mp30 hard drive replacement?
It is a standard 2.5" IDE laptop drive. You have to dis-assemble to mother board. Easy to do if you are comfortable with internals. You have to remove a million screws to get case apart. All visible on bottom, also internal pc card next to memory card has 2 screws. Don't forget back side hinge screws and edge screws on upper part of lower shell visible in back and when dvd/cd is pulled (2 bottom screws hold player in. The shell come apart easily little force no tricky pressure or lock taps. Where it hinges on back top side next to LCD screen lift gently straight up this is where it is most resistant. A few ribbon cables and 2 wire cables to disconnect. After lower case top is off a few screws holding mother board (arrows) needs to be removed to lift motherboard. Drive is connected to mother board by ribbon cable lift pry gently up to release it. Drive is held in by 4 screws. Good luck. If you do not want to do this just get a 2.5" usb drive. You can buy the drives and external case or by already made ones e.g. WD passport.
BTW I am looking for an actius mp-30 casing, mine has damage.
If you have any questions post to contact me
Jan 05, 2008 | Sharp Actius MP30 Notebook
Sony VAIO PCG-K23 Notebook Logo
62 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
