Beeping 3 times startup
When I power up my computer it beeps three times and doesn't start up it goes into hybernation mode I think cause my dvd player will open up and close but thats it. It was working fine before that.
    Top Expert:
  • Computers & ... Master
  • 22,109 Answers
It really depends on what make or model as they seem to have different methods to get out of hybernation mode.
Posted on Dec 30, 2013
SOURCE: Beeps at Boot Up, but doesn't actually Boot Up.
u can try to take off the hdd, and at the same time, pls clean the memory slot in your laptop with a brush & some liquid solvent.. After that, try booting it without any HDD. If u did not see any error messages, try take out the CMOS backup battery and neasure its voltage or get it replaced. Pls revert...
Posted on Oct 09, 2007
harvester3
  • 181 Answers
SOURCE: IBM Thinkpad T30 2367 beeps 8 times
It's your memory, or more to the point, the memory slots. take all memory out, install 1 piece in the slot closest to the back of the laptop, push down on the memory as if pushing it into the motherboard, and hold pressure while booting.
Bet that works. if not, let me know.
I've got the same machine.
Good luck
Posted on Jan 04, 2008
frankzjm
  • 191 Answers
SOURCE: HP Pavillion dv5 startup problems, no screen 3 beeps in loop
Hi, you need do follow things:
1) check RAM in the back small cover of laptop, clean RAM pins and slots set back or change RAM position each other ,or replace other RAM(same model) if old RAM not works.
2) take out the wireless card in the back small cover that is MINI PCI slot, then turn on. sometimes it cancause this trouble.
help you fix it, and any question keep in touch please.
Posted on May 14, 2009
leecom72
  • 4806 Answers
SOURCE: Dell Inspiron 700m won't start
It sounds like there is an issue with the system memory.
Remove both the power adapter and the battery. Turn the laptop over and locate the RAM (memory) cover and remove the holding screw.
Take out the system memory and clean the brass contacts, also clean the slots that the memory sits in.
Re-seat the memory making sure it clips into place nice and tight and replace the RAM cover.
Return power to the laptop and turn it on to see if that has helped.
If it still won't boot up then you may need to purchase new memory for the laptop.
Good luck.
Posted on Sep 28, 2009
Testimonial: "leecom72, Thank you for the prompt advice. I tried it cleaning it, but still not working. I'll try new memory (wanted to upgrade anyways). Thanks!"
SOURCE: Hearing continuous beep sound at startup that disappears on Esc
I started having the smae problem yesterday with my Acer 1410 bought end of 2009. It started after I had stoped some suspicious process to work on start up (using msconfig). During the night I scanned the computer for virus but found nothing. Tonight I will enable those process to work on start up again and see what happens.
I will post the information tomorrow.
Posted on Aug 10, 2010
After adding rewritable DVD player to Compaq evo now it will start turn off and back on beep three times than monitor goes into sleep mode how can I fix it
Without the DVD try installing the device drivers for the DVD player. (what's themodel of your coputer )
18.January.2016
Oct 29, 2015 | Compaq Computers & Internet
Compaq presario C700 continous beep when starting up
Potential Hard Drive failure, (Hard drive s.m.a.r.t. beep) or if MB beep it's chassis intrusion..
1. Remove battery + disconnect power
2. Hold down power button for 20 seconds
3. connect power only (no battery)
4. Turn computer on.
If the beeps stopped.. get a new battery, if the beeps continue..
ABANDON SHIP!
Apr 27, 2014 | Compaq Presario 1200,1600, Series CD...
6 beeps what dose it means
Dell beep codes:
If your computer beeps during start-up:
Run Dell Diagnostics to identify a more serious cause.
Beep Codes Your computer might emit a series of beeps during start-up if the monitor cannot display errors or problems. This series of beeps, called a beep code, identifies a problem. One possible beep code (code 1-3-1) consists of one beep, a burst of three beeps, and then one beep. This beep code tells you that the computer encountered a memory problem.
Contact Dell for technical assistance.
Code Cause 1-1-2 Microprocessor register failure 1-1-3 NVRAM read/write failure 1-1-4 ROM BIOS checksum failure 1-2-1 Programmable interval timer failure 1-2-2 DMA initialization failure 1-2-3 DMA page register read/write failure 1-3 Video Memory test failure 1-3-1 through 2-4-4 Memory not being properly identified or used 3-1-1 Slave DMA register failure 3-1-2 Master DMA register failure 3-1-3 Master interrupt mask register failure 3-1-4 Slave interrupt mask register failure 3-2-2 Interrupt vector loading failure 3-2-4 Keyboard Controller test failure 3-3-1 NVRAM power loss 3-3-2 Invalid NVRAM configuration 3-3-4 Video Memory test failure 3-4-1 Screen initialization failure 3-4-2 Screen retrace failure 3-4-3 Search for video ROM failure 4-2-1 No timer tick 4-2-2 Shutdown failure 4-2-3 Gate A20 failure 4-2-4 Unexpected interrupt in protected mode 4-3-1 Memory failure above address 0FFFFh 4-3-3 Timer-chip counter 2 failure 4-3-4 Time-of-day clock stopped 4-4-1 Serial or parallel port test failure 4-4-2 Failure to decompress code to shadowed memory 4-4-3 Math-coprocessor test failure 4-4-4 Cache test failure
Aug 12, 2013 | Dell Gx620 Gx 620 Sff P4 Ht 2.8ghz 1gb...
How to fix a laptop that doesn't turn on but beeps 1 long beep and 3short beeps
This POST cade is related to RAM problem
one beep, three short beeps
three short beeps, one beep
  • Memory problem: bad DIMM or bad DIMM slot
Try reseating the RAM, if this does not work then remove the RAM module and take it to your friendly computer repair shop and get them to test the RAM for you.
May 12, 2012 | HP Pavilion ze2000 Notebook
When I turn on my dell 9200, a beeping sound starts from the CPU and nothing comes up on the screen
how many beeps you have?if three short beeps its you RAM failure..try to reinsert you RAM or replaced it a new RAM..if theres a long beep..its your video card..
Jul 27, 2011 | Dell Dimension 9200 PC Desktop
Everytime i start up the computer it beeps 3-4 times, and the monitor says vga input not connected...whats could be the problem?
here are the beep codes for your exact dell model. this should give you a starting point on finding out what the problem is.
Reseating the memory modules may fix the beep code errors in the following table. If the problem persists, see "Contacting Dell" in your Owner's Manual for instructions on obtaining technical assistance.
Code
Cause
1-3-1 through 2-4-4
4-3-1
If you hear one of the following beep codes, see "Contacting Dell" in your Owner's Manual for instructions on obtaining technical assistance.
Code
Cause
1-1-2
1-1-3
NVRAM
1-1-4
1-2-1
1-2-2
1-2-3
3-1-1
3-1-2
3-1-3
3-1-4
3-2-2
3-2-4
Keyboard Controller Test failure
3-3-1
NVRAM power loss
3-3-2
NVRAM configuration
3-3-4
Video Memory Test failure
3-4-1
3-4-2
3-4-3
4-2-1
No time tick
4-2-2
Shutdown failure
4-2-3
Gate A20 failure
4-2-4
4-3-3
4-3-4
4-4-1
4-4-4
Cache test failure
Jan 01, 2011 | Dell Dimension 4600 PC Desktop
My pc beeped twice and nothing came
Lack of video signal is usually 1 of 3 things, Power supply (PSU), Video card or Motherboard (mobo).
Situation #1: If you get a blank screen and no sounds or movement it either indicates that the power supply unit (PSU) has failed or something on the motherboard has failed, preventing normal startup.
Situation #1A: You might get some power lights coming on and some fans spinning but the video output does not happen, usually indicates that motherboard or PSU is going out or has gone out. Occasionally it will be due to a weak (damaged) PSU.
Situation #2: If you get sounds (normal Windows startup sounds) and lights but nothing on the screen then it indicates a failed or loose video card.
Always try a different power outlet that you know is working. (Eliminate the easy stuff first!)
If it is out of warranty, try opening up the case, with the power off, of course. If you have Sit #2 and have a video card that you can reseat (take out and then put back in) try that. If it is onboard video then you may have to buy a video card for it.
Also take this time to inspect the capacitors on the motherboard (they look like tiny soda cans) and check for tops that are bulging, swelling or leaking anything. Capacitors should be perfectly flat on top. If you find these then your motherboard is bad (well technically the capacitors on your motherboard are bad). The bad caps will need replacing to fix (not a job for an amateur). If it passes the visual inspection then it may just be your power supply is bad. Notice that a bad PSU does not mean you are getting no power, just not enough to start and run the computer.
A few years ago a company stole the recipe for making capacitors and started making their own capacitors at really cheap prices. The stolen "recipe" was not complete and not correct so these caps started failing after about 2-3 years of use. Emachines, DELL and Gateway were the computer companies most affected by the bad capacitor issues, although any of the big companies could have the same problem. These bad caps also affected power supply makers.
Do you hear anything else during startup, beeps, fans or drives spinning, lights on the front or back of computer flashing or lit up? Do you hear the Windows starting sound?
Let us know more then we can troubleshoot better. Do you have the 4 diagnostic (A,B,C,D) on the rear of the machine? What is the front power light on the CPU doing?
Apr 29, 2009 | Dell Dimension 2400 PC Desktop
Black screen with error codes
I think the msg you are seeing is just the default monitor message when there is no video to display. Here is a list of common beep codes: Are you getting the one long beep at each restart?
Beep Code: Description of Problem: No Beeps Short, No power, Bad CPU/MB, Loose Peripherals One Beep Everything is normal and Computer POSTed fine Two Beeps POST/CMOS Error One Long Beep, One Short Beep Motherboard Problem One Long Beep, Two Short Beeps Video Problem One Long Beep, Three Short Beeps Video Problem Three Long Beeps Keyboard Error Repeated Long Beeps Memory Error Continuous Hi-Lo Beeps CPU Overheating
Dec 16, 2008 | Computers & Internet
Wont Post get 9 beeps!
This problem is due to the mix of registered and unregistered DIMMs. 64Mb and 128 Mb DIMM's are unregistered memory technology 256MB is registered memory technology. A mix of registered and unregistered memory prevents the server from completing startup, and results in an error beep sequence and a blank screen
Oct 08, 2007 | IBM Netfinity 3500 M20 8657 Server
Computers & Internet Logo
26 people viewed this question
David Payne
David Payne
