Question about Razor USA Razor Ground Force Drifter Go Kart
Charger light stays green all the time - Razor USA Razor Ground Force Drifter Go Kart
E300 , replaced both batteries , now charger light stays green although just plugged in to new batteries for first time. What is it now ?
This is most likely the control module.It can cause this.I had it happen before :) hope this helps.Buy one at www.razor.com or on ebay.
Feb 06, 2014 | Razor E300 Scooter
Makita bl1830 charges but stays on static red light
Chargers have been known to lie about what they are indicating. Even though you say the batteries were charged only a hanful of times, they may, in fact, have expired
Apr 03, 2013 | Makita 2 Bl1830 18v Battery,dc18ra Charger...
Changed plug were u connect to charge the bella now the charger light stays green
check the charger end with a multimeter and make sure that its showing that its putting out the correct voltage
May 22, 2012 | Razor USA Razor Pocket Mod Electric...
Charger model FY 4101 green light stay lite all the time, and hoveround battery is still dead
When the green light stays on regardless of dead battery, this means the battery is defective. The battery must present a load to the charger, which causes the charger voltage to drop, turning the charger on. When the battery is defective, it will not load the charger, and the charger voltage stays at full charge value. This of course, causes the green light to be switched on.
Sep 16, 2010 | Electronics - Others
What does it mean when a household battery charger flashes red then green? The charger is a SYNERGY DIGITAL rapid quick charger. I'm trying to charge new AA Energizer Lithium batteries.
When the charger light is changing from red to green that is a indication that it is charging the battery. When the charge is complete the light will stay green until the battery is removed or the charger is unplugged.
Jun 06, 2010 | Energizer Rechargable Battery with Charger
Battery #1 terminal lights red and stays red.
Disconnect the - lead from that battery, Repower the charger. The LED should be green. If it stays RED, charger defective.
Reconnect the - lead to the battery, measure voltage when charger is on. Should be between 11.5 and 13 volts. If OK, replace the battery. If lower than 11.5, check for charger cable connections OR for a connected load ( power drawing ) of more than 10 amps.
Sep 20, 2017 | Guest 2631a 30 Amp Battery Charger
Green and yellow lights both stay on and it never
see if your charger is under warranty and have it replaced..yours is bad..
Nov 13, 2009 | Ryobi Multi-Volt Battery Charger
Need to diagnose and repair hoveround battery charger
check current output of charger to see if it makes info on back mostlikely charger went bad
Jul 06, 2009 | Electronics - Others
How do I reset s9....the green light stays on constantly and I cannot connect at all.
If you guys haven't found a solution, you might want to try this out. Have your S9 charger hooked up to the unit and plug the charger into a surge protector. Flick the main switch of the surge protector on and off a few times and it should turn off the unit. Then turn on and pair if need to and it should be fine. Hope that works for ya!
Cpl. Ramos
Jun 24, 2009 | Motorola Mobility S9 Headphones
Kenko
read the owners hand book
normally the lights stay red until the battery is charged then it goes green
if the power is cut or if you switch the point off with the charger still in it and do not remove the charged battery , the battery will discharge through the charger
Mar 27, 2017 | Kenko MC-4 DG for Nikon AF 2x (MC4AFNDG)...
Razor USA Razor Ground Force Drifter Go Kart Logo
20 people viewed this question
Top Razor USA Toys Experts
Adam Fjeld
Adam Fjeld
Steve P
Steve P
Are you a Razor USA Toy Expert? Answer questions, earn points and help others
