Question about Lexmark C544dn Laser Printer
Lexmark c544 leaves yellow shading on right and left sides of paper
  • 25 Answers
SOURCE: Lexmark E232
If this model has separate toner and photoconductor then the photoconductor is at end of life and needs to be replaced. Follow the directions that come in the new photoconductor package to install and reset the PC count this is important.
Luck
Posted on Mar 11, 2008
Ajkill
  • 2035 Answers
SOURCE: Lexmark X2470 Jam
  1. Turn the printer off and open the access cover.
  2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
  3. Turn the printer on, load some paper, and press the Form Feed button. (On the X83, press the Select button.)
  4. Watch the paper as it feeds through and try to determine where the jam is occurring.
  5. Check to see if all the rollers are turning.
    If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
    If not, there is probably a feed motor or a gear problem and the printer may require service.
  6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
  7. Turn the printer off.
  8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
  9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
IF this did mot work ,Please contact Lexmark as they sent you refurbished printer which may defective roller on it , ask them to send a good printer this time..............
Posted on May 28, 2008
  • 7 Answers
SOURCE: Printer will only pull the paper in from one side.
Hi !!
Usually this problem happens if there is something wrong with paper feed rollers which is inside the printer .
But to fix teh problem you can try this ---
take out ink cartridges, all the cables, power adapter (black rectangular box at the back) and papers from the paper feeder . Then take the printer in your hands, keep it like upside down and shake it for a while .Then keep it back in its position
Afetr 10-15 mins , install cartridges, cables, power adapter and just 1 sheet of paper on the printer . try to print somethg if still it dows same thg then it means that This is a time to buy a new printer on this christmas !!
Regards
Priya
Posted on Dec 04, 2008
SOURCE: Lexmark T 640 leaving faint black lines on right side of page
replace your cartridge, and all should be fine.
Posted on Apr 01, 2009
  • 320 Answers
SOURCE: lexmark laser printer leaving a white streak 2-3
take a q-tip and clean the scanner window. this is located in a 3/16' opening on the roof of the printer cavity it will be about 8inchs long. pull the toner cartridge and feel with your fingers on the roof of the cavity this will be located above the transfer roller slightly towards the front of the printer. white lines like this mean the laser is being blocked usually by a bit of toner or other dirt of some kind
Posted on Dec 07, 2009
My Lexmark C543DN prints with yellow streaksprinter, as you'll see...
Clean the drums on the cyan and magenta developer units with alcohol on a cotton ball. Swipe the damped cotton balls left and right and let it dry, then turn the drum about 20 degrees and repeat until you have cleaned the entire drum. Keep the units out of direct bright light and sunlight. You may also need to clean the transfer belt (black belt inside the front hatch) and rotate that to ensure clean all round. Try your print again.
Oct 28, 2017 | Lexmark Office Equipment & Supplies
Lexmark c544
http://support.lexmark.com/index?page=content&productCode=LEXMARK_C543&segment=SUPPORTproductCode%3D&viewlocale=de_DE&searchid=1284305565139&actp=search&userlocale=DE_CH&id=SO4798
Mar 09, 2015 | Lexmark Office Equipment & Supplies
What is the rear wiring harness for 2001 s-10?
its for the lights mostly..left right tail, brake, backup, license plate..you have brown, yellow, and white, and two shades of green mostly..brown is running(tail/license plate) wire..yellow is left brake, /turn light gren is right side and last wire is reverse..(some may be wrong but its close)..
oh and fuel tank.. sender../pump..not sure of the colors there..I think purple or black..
Jul 10, 2014 | 2001 Chevrolet S-10
Replaced all three color cartridges (they were low), now the yellow doesn't work at all. Ran deep cleaning several times and tried a different yellow cartridge. No luck!
It insists there is a Cartridge problem on the Printer............ In this Case take out the Paper from the Paper Feed Tray........ Unplug the Power Supply from the Printer.......... Remove both the Cartridges from the Printer.......... Now take a size 10 Envelope fold it so that it should become like a thin long strip........ Now Insert that Envelope on the left side corner of the Printer and move it from right to left and left to right as fast as u can for about 10 times.......... Now Insert the Ordinary Papers onto the Printer and insert both the catridges and Turn on the Printer...... Blinking Stopped...........Issue Resolved....... Still Blinking: Remove both the Cartridges take a Paper Towel turn the catridges direction so that u can see a Copper plate with small boxes on it....... Just wipe it twice or thrice with the Paper Towel.......... Now insert it and Power on the Printer and see whether the Lights are still blinking if it is still blinking...... Get the Printer Replaced!!!!!
Good Luck!!!!!
Apr 11, 2013 | Lexmark Pro901 All-In-One Inkjet Printer
Lexmark s600 just installed new yellow cartridge (generic) and it wont recognize it, ran deep clean and it printed plant of yellow! help!
It insists there is a Cartridge problem on the Printer............ In this Case take out the Paper from the Paper Feed Tray........ Unplug the Power Supply from the Printer.......... Remove both the Cartridges from the Printer.......... Now take a size 10 Envelope fold it so that it should become like a thin long strip........ Now Insert that Envelope on the left side corner of the Printer and move it from right to left and left to right as fast as u can for about 10 times.......... Now Insert the Ordinary Papers onto the Printer and insert both the catridges and Turn on the Printer...... Blinking Stopped...........Issue Resolved....... Still Blinking: Remove both the Cartridges take a Paper Towel turn the catridges direction so that u can see a Copper plate with small boxes on it....... Just wipe it twice or thrice with the Paper Towel.......... Now insert it and Power on the Printer and see whether the Lights are still blinking if it is still blinking...... Contact Lexmark at 1-800-539-6275!!!!!
Good Luck!!!!!
Apr 04, 2013 | Lexmark Interact S605 All-in-One Color...
I have a stupid question where the heck do Iload the paper in my Lexmark X2350 printer??
Facing towards front of the printer, on the back of it you have raiser - paper support panel, with side slider on the left hand, push slider towards left in full.
Paper accepted by this printer is all standard grades, like A4, L4 and fall in these dimensions:
width min/max - 76mm to 216mm (3" to 8.5")
lenght min/max - 127mm to 432mm (5" to 17")
Printer will accept paper weight between 60g and 180g, that meant that all standard weight of paper including cardstock will be accepted, printer as well will print photo and envelopes.
• The paper is loaded against the right side of the paper support.
• The paper guide rests against the left edge of the paper.
1. Put paper long way vertical on raiser (paper support), about 80 to 100 pages of standard paper will fit there (depends on thisckness),
2. Push paper against right side
3. Adjust width with left hand slider. Do not buckle the paper!
After print paper is ejected at front bottom slot, printer side up. if you use photpaper or gloss paper, remove it immediatelly as need longer drying time and will get smudget by next printsheet.
You can find information with pictures in your manual on page 13/14.
Hope this will help you print beautiful pictures!
Aug 11, 2010 | Lexmark Z2300 InkJet Printer
Ok i have a problem. my lexmark x6150 won't take in paper right. it only takes it in on the right side. what is wrong?
Did this start with a paper jam? There could be a piece of paper(ripped corner) binding up the wheel on the left side.
Nov 05, 2009 | Lexmark X6150 All-In-One InkJet Printer
Lexmark 4270 won't feed paper to print or copy!
In this Case take out the Paper from the Paper Feed Tray........ Unplug the Power Supply from the Printer.......... Remove both the Cartridges from the Printer.......... Now take a size 10 Envelope fold it so that it should become like a thin long strip........ Now Insert that Envelope on the left side corner of the Printer and move it from right to left and left to right as fast as u can for about 10 times.......... Now Insert the Ordinary Papers onto the Printer and insert both the catridges and Turn on the Printer...... Good Luck
Jan 16, 2009 | Lexmark X4270 All-In-One InkJet Printer
Lexmark C544dn Laser Printer Logo
194 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
