Question about Garden
Weak pressure Lavor Thermic 3s petrol pressure washer works fine from outside tap but weak pressure when fed from a barrel. Any help?
    Sergeant:
  • 402 Answers
Seals may be worn although a high speed pump is not normally recommended for siphoning due to pump rotating at an rpm as fast as the motor belt drive gear drive or slower rpm pumps will siphon much better.
Posted on Jan 04, 2014
david04928
  • 102 Answers
SOURCE: north star petrol pressure washer.
Sounds like the regulator is sticking or is airbound. loosen the water connection and then tighten it back. Could also be that the trigger gun is faulty or needs adjustment. Hope this helped
Posted on Mar 15, 2009
  • 174 Answers
SOURCE: how do i know if my outside tap has a non - return
If del_brenda_s lives in Canada or US, just go to the hardwre stire and get a Gardena connection for your garden hose. Under $10
Posted on Jun 05, 2009
#1 Taper
  • 1040 Answers
SOURCE: I have Lavor Yukon Pressure Washer. I removed the
This website should be able to help you with your problem. You may have to have them send you a schematic of your machine.
Good Luck!
Jim
Posted on Aug 14, 2011
  • 6468 Answers
SOURCE: Low pressure from pressure washer
sounds like the pressure relief valve is stuck inside the pump
Posted on Aug 10, 2012
  • 6468 Answers
SOURCE: lavor thermic 3/s
remove the spark plug and see if the cylinder if full of gas if so replace the needle and seat in the carb
Posted on Aug 15, 2012
I have lost pressure on my Lavor pressure washer
Oil seals are needed for sure. But you also need to check the valves! To check them, remove the valves, clean them and check them! You can check them to see if they are working properly by put the valve to your lips with them metal side or the bottom to your lips then blowing, if they "flutter" good then try to suck air through them! If you cannot suck air, they are good! Then inspect your water seals. They tend to dry out and weaken when used all the time.If they look worn, then replace them making sure you put the new ones back Exactly like the old ones came out! You should be good then! If not, check all components out side of the pump mainly the Unloader (regulator). Best of luck to ya!
Sep 23, 2014 | Garden
Lavor thermic 3/s
Aug 09, 2012 | Garden
Whats the part number for a 95 camry timing belt is it 94167 (163stp8m267) thanks for ya assitance
3.0 Liter V6 engine use Dayco 95257
2.2 Liter 4 cyc engine use Dayco 95199
======== 94167 is an old Deyco Euro part #
It will fit the following
Toyota Camry 2.0 i 1996 3S-FE Petrol 10/86-06/91
Toyota Camry 2.0 i 16V 1998 3S-FE Petrol 10/86-06/91
Toyota Camry 2.2 i 16V 2164 5S-FE Petrol 06/91-07/01
Toyota Carina E 2.0 i 16V 1998 3S-FE Petrol 02/92-10/97
Jul 31, 2011 | Toyota Camry Cars & Trucks
I'm using a Dewalt 2800 power washer and someone set it on its side. And now it will not start. The air cleaner is full of oil. I think there is oil in the carb. I took the air filter off and almost get it...
take the air filter off and wash in petrol.allow to dry,and put back on. then take the fuel bowl off and clean.turn fuel tap on and drain fuel from carby for a few seconds.turn fuel tap off.put fuel bowl back on.then take spark plug out and turn motor over,be care some oil might come out of hole.if the plug is oily then clean with petrol and dry.put spark plug back in. turn fuel tap on and start
Nov 30, 2010 | Dewalt 3800 PSI Pressure Washer
I have brought a petrol pressure washer that says it draws is own water from a static water source (ie barrel) but it needs priming first. what does this mean and how do you do it? i will be using the...
priming means: fill the pump and hose completely with the fluid you intend to pump
start to turn the pump until all air is expelled and liquid comes out of the pump before you put it in the barrel and, start to use it; this must be done; so, that air is removed because the air can not be pumped and will prevent the pump from working.
Jul 27, 2010 | Garden
I have mixer taps on my bath, cold water tap works
Remove the tap outer cover. Take out the barrel & inside there is the washer on the end of a screw which slides in and out when the tap is turned. This could have been turned too far out and will not go back in. Clean both the screw thread and inside the barrel, lubricate with petroleum jelly or similar and reassemble & test before replacing the barrel. Again lubricate all threads.
Alternatively buy a new barrel
Mar 11, 2010 | Home
Honda excell pressure washer does not have pressure
if the machine is running on suction, ie sucking out of a barrel there may be an air leak on the suction hose or pump. it will pull air easier than pulling water .
put the machine under mains water pressure, hose pipe straight from tap to pump.
check all around the pump and inlet pipes for leaks.
if water leaking this needs rectifiying for it to work on suction.
run the pressure washer while on mains pressure with the hose on, does this make a difference?
if not then probably the unloader is stuck in the pump head. remove unloader , clean and replace it
parts breakdowns are available on the internet for your machine.
possibly valves stuck, or the valve springs have broken, seen this quite few times on these machines. if so replace springs .
These sort of machines do not last very long anyway, about 50 hours use if your lucky.
Jul 22, 2009 | Honda Garden
How do i know if my outside tap has a non - return valve i want to start using a pressure washer
Dear del_brenda_s,
I have been servicing Power Washers for the last 5 years. And I cannot understand why you need a non-return tap outside. I think "outside" you are refering to the main supply after the water meter.
Well if your power washer needs a non-return, you can fit a cheap garden hose non- return attachment.
Regarding the non-return at the outside tap,..this is most probably NON-RETURN. If you want to be sure you can contact the water works division of your country and city...and I am sure they know what sort of taps should be used. In my country it is a must that a non-return outside tap is used. This is important so that when there is a cut in the water supply, the water meter and the whole system will not have to be bled out of air when the water comes again.
Regards,
Fulltech.
Apr 19, 2009 | Karcher K2.26 Electric Power Washer
North star petrol pressure washer. working fine, then no high pressure, checked water feed, water filter , pressure relief valve and gun nosall well work sometimes and keep working, when you release the...
Mar 12, 2009 | Karcher 2500 PSI Pressure Washer
Garden Logo
110 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
