Question about Hoover Dryers
Replace door seal hoover tumble dryer - Hoover Dryers
yalmer
  • 552 Answers
SOURCE: hoover nextra tumble dryer
Please first check if both fuses or the circuit breaker has not tripped.
If you are getting only 120v on one leg of the 140v power, you may get lights and no heat, otherwise please give the make and model.
Posted on Feb 27, 2008
hards327
  • 30 Answers
SOURCE: How do i replace belt on condenser tumble dryer
you need to remove the whole front of the machine by removing the : top by the 3 screws at the back,then unscrew the screws across the front of the top of the bezel then remove,then open the door,remove the circle of screws then put the machine on its back,remove the screws at the bottom front of the machine,then lift the front bottom of the machine and slide it upwards then you should be able replace the belt then refit in reverse order good luck.
Posted on Mar 17, 2008
SOURCE: Hoover tumble dryer hdv6
my dryer this model does not get warm?
Posted on Jun 19, 2008
hunter19_46m
  • 7482 Answers
SOURCE: The felt seal on my Hoover HNC175 tumble dryer come off.
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Remove the electrical box that holds the timer switch, start switch, etc. from the top of the dryer. Be real careful not to knock any of the wires off of the timer switch. Then remove the top of the dryer.
Remove the front of the machine, this will expose the belt and drum, and the felt seal.
You may be able to replace the felt seal at this time, or you may have to buy a new one and install it.
I would also recommend that you do the following while you have gone this far.
Remove the drum and belt and this will expose the drum rollers, idler arm bracket with pulley, and motor with pulley. Be sure to pay attention to the route of the belt, this will come in handy later when you go to reinstall the belt and drum
While you have the drum out, I would recommend that you lubricate the drum rollers at the shaft of the roller with a good grade of machine oil like 3 in One oil. This will save you a problem later with the rollers getting noisy, also check your drum rollers for flat spots, if they have flat spots on them this will cause a noise like a thumping type noise. You will need to replace the drum rollers if they have flat spots on them.
I will include these two websites for parts and further help:
http://www.partselect.com/
http://www.appliancepartspros.com/index.aspx
Both also have chat assistance 24/7.
Good luck,
I hope this helps
Posted on Oct 19, 2009
rogrrabbit
  • 986 Answers
SOURCE: Hoover Condenser Tumble dryer HSC 170 not heating up
The heating element have got old and brittle over time and finally gave up the ghost. But it is not always the element. It could be one of the safety Hi-limits have blown. All parts of the dryer will have continuity if its working properly. Test for continuity by using a meter set on Ohms,or use a poor man's meter. You can make your own poor man's meter by using an ordinary flashlight . Break the circuit in the flashlight and add a couple of wires to it so that you can make the light come on in the flashlight, that's right hot wire that flashlight. When the bulb lights up you have a circuit! You now have a poor man's meter. The next step is to check each little gizmo on the dryer that the wires attach to. All the limits attached to the side of the heat element, the door switch (when door is closed) etc.should have continuity (closed circuit)(the light should come on in the poor man's meter) If you come across an thing near the blower housing with 2 wires attached to it, that is a thermal limit, a safety or a control thermostat (So as not to get a false circuit you need to remove one of the wires to each thing you check) Look for lint buildup or blocked vent going out the house. If everything is good and you have paid the electric bill, then the timer could be bad.
Posted on Nov 27, 2009
How do I replace the door switch
Go to espare.com and watch the vidios about that
Dec 04, 2015 | Hoover Vision HD VHC691B White Electric...
Hoover DYC9913AX
gentlmen you need to move with the times this tumble dryer has no element it is whats caled a heatpump solution ,there is no exhaust for the air to go out of as it is a sealed enviroment the air re-circulates within the machine
Nov 07, 2012 | Hoover Dryers
Good luck,
I hope this helps
Oct 18, 2009 | Hoover Dryers
Rubber door seal
Try here: http://www.searspartsdirect.com
Jul 12, 2008 | Hoover HDV7FM Electric Dryer
Tumble dryer door seal
you should use high temp glue
Mar 24, 2008 | Candy CDC266 Dryer
Dryers Logo
Top Hoover Dryers Experts
Tim Whalen
John Tripp
John Tripp
Are you a Hoover Dryer Expert? Answer questions, earn points and help others
