Replace 1980 ford pinto starter - Computers & Internet
What is the torque spec for a 1978 Ford pinto differential pinion nut?
170 ft.lbs is the minimum; be aware that this differential uses a crush sleeve to set the backlash and the pinion torque is what crushes the crush sleeve. If you don't set the backlash correctly you can grind up your differential gears.
8 Inch Ford Rear End Torque Specifications eHow
Feb 02, 2015 | Ford Cars & Trucks
1980 ford f-250-5.8L-80k miles-replaced battery, starter, starter solenoid, ran great for week or two, now when I start it, engine turns over and runs, but occasionally starter sticks, and just won't turn...
Remove the small wire from the solenoid and hook up the battery. If the starter engages the solenoid is stuck. If the solenoid does not engage the starter with the small wire removed, check the small wire for a short to power.
Sep 03, 2013 | Ford Cars & Trucks
What is the ignition point gap for a 71 ford pinto 2.3
Put it at .45 mm dwell angle should be between 48 to 52 degrees.
Dec 05, 2010 | Ford Granada Cars & Trucks
Have a kit car with a ford 2.0 ltr pinto sohc,rev counter wiring
Most rev counters of this type wire the positive wire to the contact points on the distributer and the black (negative) to ground.
Apr 16, 2010 | 1978 Ford Granada
My ford 8n starter just clicks now. Is there anyway to get this to stop and work corectly?
You likely need to replace the starter solenoid switch,if it just clicks then one of the contacts has worn out.If the starter is a delco,order one for a Chev half ton 1980, and it will be about $30 cheaper and do the same job.
Feb 15, 2010 | Ford 8n,9n,2n, Tractor Starter With Drive
My 2005 aveo horn does not work I replaced the fuse and still not working
see if the horn will sound as you turn the steering wheel hard in both directions. a lot of time there are this connecting rings in the steering whell that make connection with the horn operation. these rings get worn just by driving even when you haven't used the horn. I hope this is not the cause because it can be costly. many times the fix is to replace the wheel. I had a toyota once and also the ole' pinto that had thses symptoms. both cars had the same cause. the toyota had to have another steering wheel. I can't remember what I did with the pinto. ( I do remember a funny story with the pinto, I lived in an apartment complex and one night at about 2a.m. the horn started blowing, I waited for a while then got mad at who ever is keeping me up I stormed outside and behold it was my ford pinto. I think I remember destroying the center of the wheel to get the horn to stop.)))) hope this helps.
Jun 11, 2009 | 2005 Chevrolet Aveo
Computers & Internet Logo
15 people viewed this question
David Payne
David Payne
