CNM Touchpad 9 frozen
I have a CNM touchpad 9 from Argos since Christmas, altho did get from new. It now will not start past the start up Android screen. It was fine on last use and cannot understand this sudden problem. Have tried to reset but this doesn't seem to work either.
  • Audio Player... Master
  • 5,259 Answers
Did you fully charge the product?
Posted on Dec 30, 2013
ctf1800
  • 4402 Answers
SOURCE: Problems with TouchPad
only thing i know is to replace the pad.
Posted on Dec 17, 2007
SOURCE: Touchpad won't work on my Gigabeat F40
Mine did the same, touch pad became erratic then stopped working, I could still access everything when linked to a computer. Then all stopped, on power up I got a 00000010 or 0000020 error and nothing.
I popped the end caps off, removed the two small screws holding the back on and found the strap of wires connecting the hard drive was almost completely dissconnected. Pushed the connector back together , reassembled and now all working
Posted on May 10, 2008
  • 7 Answers
SOURCE: creative zen touchpad not working!!
If it stopped working after you dropped it, try this:
Hold the Zen in your hand, and with your thumb, press down on the face board as hard as you can. Use your other hand's finger to scroll up or down on the touch pad. Press down different areas of the face board until you find a spot that, when pressed, causes the touch pad to work. Then, using both of your thumbs, press that spot VERY hard until the touch pad works without pressing.
Posted on Jan 23, 2009
  • 13433 Answers
SOURCE: weird lines moving on an 1st gen itouch
Hey,
follow this guide
http://www.fixya.com/support/r561901-ipod_problems_start_5_solutions
in the end theres the warranty info checker, you may need to send this one to repair, check your warranty with the tool ones your done. Its the last thing on the guide.
Thanks,
Ekse
Posted on Feb 16, 2009
aparsons89
  • 40 Answers
SOURCE: zune 4gb won't reset
Hi, try taking out the batteries and leave out for 1 minute, this may reset it. If this doesn't work well I am afraid your Zune has just had a Software Crash. Which will have to be serviced.
Posted on May 11, 2009
My Son has recently been bought a CnM 9.7 Touchpad for his 18th birthday. The Android version is 4.0.4 and a bit flakey. The website says it can be upgraded to 4.2.2 Jelly Bean but the links don't work. I...
Connect the tablet to your home WiFi network. Go to Settings-->General-->Software Update. If a software update is available, it will be shown there. Follow the instructions.
Jan 17, 2015 | Tablets & eReaders
How do I get cnm touchpad 9 to authenticate wifi connection to the internet, what are the correct settings, keeps connecting to bt fon instead.
I am assuming you are on an Android platform, so the first thing you should check is to see if your Wifi is on....Settings, Wifi, then usually there is a on/off switch at the top...if its off turn it on and then try to join the wifi AP. If the wifi is on and your still connecting via bluetooth then shut bluetooth off, settings, bluetooth and try connecting...maybe there is a default setting somewhere forcing you to use the bluetooth ...I'd need to know what OS your using and the version number to give you direct information.
Dec 22, 2014 | Tablets & eReaders
Where is the reset button on mytablet2 from argos
  • Make sure the tablet is charged up to 60%
  • Turn off the tablet completely .
  • Press Volume + button , while holding Volume + button , plug in charger.
  • Release the volume + button.
  • Press Volume + again and press Power button to boot the CnM Tablet.
  • When Android logo appear , release the volume + button.
  • Press Power Button again and press volume + button , Recovery Menu will be appear .
  • Press the volume down and select "wipe data/factory reset"
  • Power button to select it
  • You will see "Yes - delete all user data"
  • Select "Yes"press "Power" button to select it
  • Formating will start. it will delete all user data .
  • Few seconds later, you should see the recovery menu again. Select reboot.
  • It will take approximately 2 to 3 minutes to take you back to its factory (out-of-the-box) state .
you are done.
This Hard Reset method will work with all models of CnM touchpad tablets.
Dec 15, 2014 | Televison & Video
When I try to use my camera on my CnM 9.7 touchpad it tells me unfortunately the camera has stopped?
Try to find and install different firmware version till the camera start to work.Tipical problem with some model
Nov 13, 2014 | Computers & Internet
My daughters my tablet2 by bush has,frozen what do I do
if you can remove the battery start there. is not try to hold the power button for 1min. if that still doesn't work follow the bellow instructions
When Hard Reset is Necessary for Smartphones or Tablets ?
1. Forgotten Pattern Lock on Android Tablets or Smartphones.
2.Too many pattern attempts / Reset user lock.
3. Tablets PC,Smartphones stuck on Gmail account.
4. Android Tablet PC stuck / freeze on Android logo.
5. Tablet Android or Smartphones hang on start-up / Multiple errors generating by OS.
6. Android market having problems or generating errors.
7.Upgrading to new Android version.
Make sure to charge battery upto 60%.
How to Hard Reset Argos CnM TouchPad Android tablet pc ?
you are done.
Jul 25, 2014 | Audio Players & Recorders
Wont load past android logo
Give it about 2-5 minutes , if that doesn't work try holding the power and volume button until it shows you a reboot option.
Mar 31, 2014 | Hannspree SN10T1 101 Tablet
Asus eee pointer frozen
Click Start/Control Panel andlook for the Mouse and open it to check the mouse properties. Make sureyou don't have the touchpad disabled.
Some models will allow you to toggle the touchpad on or off by clicking on thebutton that is located at the top of the touch pad in the middle.
Some models will allow you to toggle the touchpad by tapping twice in the upperleft hand corner of the touchpad.
Some models will require a keystroke to toggle the touchpad. Press andHold the ALT or FN function key located at the lower left portion of thekeyboard, then hit the key that toggles the touchpad. The correct key tohit will have the icon of a finger pointing at a square that represents thetouchpad.
Download and reinstall the touch pad drivers.Get online and got towww.google.com In the google search box type: "Dell Support"(without the quotes and put your manufacturer name before Support). Lookfor downloads and drivers. Enter your model number and operating system whenrequested. Download and install the Touchpad drivers.
May 29, 2012 | ASUS Eee PC 1005HAG Notebook
Frozen cursor on compaq laptop
May 24, 2012 | Computers & Internet
Frozen touchpad
try reinstalling the drivers acer europe will have them
Apr 13, 2008 | Acer TravelMate 240 Notebook
95 people viewed this question
 Grubhead
Grubhead
