Question about Toshiba Satellite L455DS5976
Can only certain alpha keys
A function key f10 seems to be stuck
    Problem Solver:
  • 17 Answers
I would try cleaning your keyboard. If you are gentle you can remove the F10 key and check that they is no dirt underneath. Check other keys near the F10 key in case others have the same problem. I know that a sugary Cola spillage on a keyboard really sticks things up. In that case it was easiest to get a new keyboard.
Posted on May 21, 2014
4 Suggested Answers
harvester3
  • 181 Answers
SOURCE: 10 key pad within the alpha keyboard
Utilize the numLK button located in the upper right area of the keyboard. Depending on the layout, you may need to press it in conjunction with the Fn or Shift key.
Good luck.
Nice laptop
Posted on Nov 02, 2007
SOURCE: keyboard keys non functional
I spilled a little water on my keyboard as well.Just a few drops not much but the keyboard stopped working , some of the keys at least.I bought a new keyboard from the Internet and it works like a charm now.
They have pretty good install pictures on this site.I watched the pictures and replaced the keyboard myself.It took me no more than 20 min.I payed something like 20-30 bucks for the keyboard.
PS
I called a shop here in Vegas and they were asking 75 just to "diagnose the problem".
Posted on Sep 09, 2008
sim4182
  • 393 Answers
SOURCE: None of my keys are typing or functioning. I have
1st of all u make sure keyboard it self has problem or not .. if same thing with new one kleyboard ..then open the laptop u can see white ON/OFF swicth cable just clean the print of this cable from both side.. and return everything back.. that's it. Thanks
Posted on Sep 14, 2010
Key working alpha
The alpha key activates the alphabet keyboard and a few extra symbols. To access the MATH menu and the ToFrac command, press the key below the ALPHA key. The key is marked with MATH.
On the TI84PLUS with the newer operating systems (version2.5x), the APLHA key opens up a few functionalities. That is not available on the TI 83Plus.
Sep 02, 2013 | Texas Instruments TI-83 Plus Calculator
How do I enable a compaq laptop's keys
Compaq Presario computers provide users with a row of function keys for added keyboard functionality. Function keys can serve a dual purpose as well.
Function keys are located at the top of Compaq Presario keyboards.
By learning how function keys work on a Compaq Presario you can take advantage of time saving keyboard shortcuts.Purpose
Use function keys to access menus, save changes and create shortcut keys.
Various applications, including Microsoft Office, allow you to select a function key as a shortcut key for running specific tasks. These settings are usually found under the Tools, Settings or File menu.
Each Compaq Presario computer has twelve function keys.
The most common used keys are "F2," "F8," "F10" and "F12."
The first three are used mainly to access and use the Compaq BIOS. "F12" is used to access a set of run from options during the boot process.
How to Access
Access function keys on a Compaq Presario by pressing any of the keys on the top row of the keyboard. Access the key's dual purpose by first pressing the "Fn" key located on the bottom row of keys.
Use function keys as shortcut keys by pressing them anytime while in the desired application. Remember, you must set them as shortcut keys first.
Note that some programs may already have certain function keys set as shortcuts.
Open menus and view the shortcut keys beside each menu item before setting your own shortcuts.
Dual Uses Each function key has a dual use. Press "Fn" plus the desired function key for the key's other use.
Below each function number is a small picture within a square or rectangle.
This dictates the dual use. "F1" opens help and support. "F2" serves as a printer shortcut.
Open your homepage by pressing "F3."
If you use dual monitors, switch between monitors by using "F4." "F5" puts your computer in stand-by mode.
Quickly lock your computer by pressing "F6." "F7" and "F8" adjust the screen's contrast.
Play and pause your music in Windows Media Player or other default media player by using "F9."
Press "F10" to stop playing media. Skip ahead or rewind media by using "F11" and "F12."
Other "Fn" Keys
In addition to function keys, the "Fn" key is also provides other keys with a dual use.
Any key with a small square on the key has a dual purpose such as the "scroll," "insert" and "delete" buttons.
Since laptop keyboards have no number pads, certain keys serve as the number pad by pressing the "Fn" key.
Jan 08, 2012 | Compaq Computers & Internet
Function key F10 is a little box with a finger pointing into the box. This is on a Gateway NV79. It makes it so the mouse pointer won't move. I can't seem to turn it off and on by pushing the...
Are you holding down the Fn key at the same time as pressing F10? Also you might need to enable that function in software in control panel
Jun 05, 2011 | Computers & Internet
How do I the ALPHA f1 function menu to appear so I can enter fractions
Hi...
You can access F1 by
  1. Press and Release "ALPHA" Key
  2. Now press desire function key. Here in this case, Press "Y="
Many keys in this calculator serves one than one function which can be access through by pressing either "2nd"(Blue Key) or "ALPHA"(GREEN KEY). Such extra functions are noted on keys in Green or Blue color. These additional functions are accessed by first pressing corresponding color key and desired function Key.
For example:
pressing UP and DOWN keys navigates the screen up and down
if we press ALPHA key and then UP/DOWN key, it will scroll screen UP/DOWN by a page. Also you can use this combination for copy functions.
if we press 2nd Key instead of ALPHA, we can change Contrast of The screen
Mar 18, 2011 | Texas Instruments TI-84 Plus Calculator
My son has a TI-84 Plus calculator and it is completely frozen. There is a message on the screen that reads " RAM cleared". Below that message it says "Press ALPHA F1-F4 to locate shortcut menus" but it...
The calculator OS has been upgraded to the version 2.53 MP.
For this version, whenever you remove batteries (or replace them) and turn calculator ON, you are reminded to Press [ALPHA][F1-F4] to locate Shortcuts Menu.
The calculator also asks the user to press either
[1:Do NOT show Again]
[2:Continue].
Here is what these cryptic messages mean.
Certain functions implemented on the new OS are available by pressing the [ALPHA] key followed by F1, F2, F3 or F4.
Since you may forget how to get to them, the calculator gently reminds you that there are other functions accessed only by pressing the [ALPHA] key.
It also gives you the option to flash the reminder every time the calculator memory is reset (CONTINUE) or NOT to SHOW the REMINDER again.
Usually after the RAM cleared message, press [2:Continue] or any other key but [1: ] to keep being reminded how to access the new functions.
Once a key is pressed the screen is cleared and you have the solid blinking cursor.
Oct 06, 2010 | Texas Instruments TI-84 Plus Calculator
How can I find out what all the F1, F2, F3, etc. keys on the keyboard do?
The link below will tell you what all the keys on the key board will do.
http://www.internet4classrooms.com/winkeyboard.htm
Good Luck and please rate 4 thumbs up for the free answer
Oct 01, 2010 | Computers & Internet
How do you get on second function on a calculator
Use the Shift key or the Alpha key to type letters. If there are two symbols near a key,on the body of the calculator, the symbol to the left is accessed with SHIFT, the one to the right with ALPHA. On certain calculators symbols are color-coded.
Jan 31, 2010 | Casio FX-9750GPlus Calculator
CASIO fx-300ES
Storing
  1. To store numerical values in the variables A,B,C,D,X,Y and M you use the [SHIFT][RCL] key combination to access the (STOre) function.
  2. In what follows [ key] is the physical key and (key) is the SHIFTED key
  3. ex: store the value 13 in variable A
  4. 13 [SHIFT][RCL] (STORE) [(-)] (A)
  5. The calculator displays 13 --> A on top line and 13.000.. on bottom line.
Recalling
  • To recall a value stored in a variable ex: recall value stored in variable A
  • Press [RCL][(-)] (A)
  • Calculator displays A on top line and 13 on bottom line.
If you need to use the variables A,B,C,D,X,Y, and the = sign to create an expression to be solved with the solve( function you must press the [ALPHA] key
=: [ALPHA] [CALC](=)
A: [ALPHA][(-)] (A)
B: [ALPHA][ 0 ' "] (B)
X: [ALPHA][ ) ] (X)
Y:[ALPHA][S<=>D] (Y)
etc.
Jan 05, 2010 | Casio fx-300ES Calculator
TI-84 Plus calculator without ~ | or y keys
type 15 then click a button that looks like this^. then 365. Then hit enter. it is like a normal clcutor except with more function. Sometimes you need to use the 2nd and the alpha button to do some functions.
Jan 17, 2009 | Texas Instruments TI-84 Plus Calculator
Keyboard Fn appears to be stuck
check to see if the num lock key is on
Nov 22, 2008 | Dell Inspiron 1501 Notebook
Toshiba Satellite L455DS5976 Logo
19 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
