Question about Whirlpool Washing Machines
Model LSB6200PQ0, Ultimate Care II - Whirlpool Washing Machines
  • 58 Answers
SOURCE: How to take the top off Ultimate Care II
2 screws behind control to loosen control panel. when out panel will hinge back and you should see 2 clips that will pop off with a screwdriver and harness for lid switch. whole cabinet will then come off iff you pull it forward
Posted on Oct 31, 2007
  • 1028 Answers
SOURCE: Whirlpool Ultimate Care II, model LSQ9010KQ0
lid switch lift lid and listen for click when lid shuts.. believe switch on rear left just behind lid hinge or on older models right side about half way opening (ck for boken lever or screw holes)also hinge may not be fully contacting switch ckd hinge screws just in case first if too much play in hinge will fail to contact switch..switch may be acessed by removing screws in bottom rear corners on back of console and lifting console
Posted on Jul 30, 2008
honeymokey
  • 3113 Answers
SOURCE: Whirlpool Ultimate Care II washer fills with water and stops
Lid switch. Push down on lid.
Posted on Jun 18, 2009
jsrock516
  • 5911 Answers
SOURCE: Whirlpool Ultimate Care II, Quiet Wash, Super
If the washer will fill and drain, but won't agitate or spin, you may have a broken motor coupling. The noise of the motor engaging, lack of agitation and ability to still drain are the usual symptoms. This is a common fail item with this model washer through normal wear and tear. Newer versions of the coupler are more resilient and resist breaking. The following link explains how to replace one:
http://www.fixya.com/support/r385250-replacing_motor_coupling_kenmore_top
The motor coupling is located between the drive motor and the transmission and takes the place of a drive belt. They do wear out and can break. The replacement part number is included in the link I provided and is an improved upgraded coupling that is more resilient. It should last longer. If you have questions, or require additional assistance, please let me know. I hope this helps you.
A replacement coupler can be purchased on line at appliancepartspros.com for about $11. Just use the part number in the link and "Search by Part Number" for your search criteria.
Now...a washer that fills and doesn't do anything, or stops right after the wash cycle and then does not advance to the rinse cycle and drain is commonly caused by a lid switch malfunction. The lid switch is usually mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug. If you determine the switch to be defective, the following link explains how to replace one:
http://www.fixya.com/support/r385198-replacing_lid_switch
If the switch requires replacement, a new one can be purchased on line at searspartsdirect.com, pcappliancerepair.com, repairclinic.com, appliancepartspros.com. Just use your model number as your search criteria. All these sites offer competitive pricing, so shop all them for the best price.
Take note of your symptoms:
1. Washer fills, may or may not agitate, will not advance to the rinse cycle, and will NOT drain - lid switch.
2. Washer fills, does NOT agitate or spin, but WILL drain - motor coupling.
If you still have questions, please let me know. If the suggestions I have listed do not match your washer symptoms, please post back and elaborate more on what the washer is/is not doing. That way I can provide you with better assistance. I hope this information is helpful to you.
Posted on Aug 13, 2009
washdryman
  • 154 Answers
SOURCE: Upper agitator on Whirlpool Ultimate Care II washer
replace agitator "dogs"
Posted on Mar 01, 2010
How to fix a broken belt of motor of whirpool wash ultimate care 2
  • Replacing the Belt in a Whirlpool Ultimate Care II ' Home ... homeguides.sfgate.com > ... > Mortgage-Backed Securities Replacing the Belt in a Whirlpool Ultimate Care II by Rogue Parrish. Email; ... The Ultimate Care II washer, ... it may have a broken belt.
  • Whirlpool Washer: Ulitimate Care II - YouTube www.youtube.com/watch?v=bVmjmSzMXHE
    • BY CHERRY HILL
    • 3 MIN
    • 36K VIEWS
    2012-05-30 · Video embedded · Whirlpool Ultimate Care II: ... This is fully funcational washer. Direct Motor Drive works perfectly through each ... Whirlpool Washer: Ulitimate Care II
  • How to replace a broken dryer belt. Whirlpool Ultimate ... www.youtube.com/watch?v=PU8QZeDRl_0
    • BY BAILSOFSTEEL
    • 5 MIN
    • 3.5K VIEWS
    2015-04-04 · Video embedded · This video shows me replacing a belt in a Whirlpool Ultimate Care II ... a broken dryer belt. ... Whirlpool ultimate care II clothes washing
  • http://www.bing.com/videos/search?q=broken+belt+of+motor+of+whirpool+wash+ultimate+care+2&FORM=HDRSC3
    Jul 15, 2016 | Washing Machines
    Model # SM 8280867 How old is this model?
    6 - 10 years in 2012
    Whirlpool Washer Ultimate Care ii - Appliance Repair Forums www.applianceblog.com/.../32099-Whirlpool-Washer-Ultimate-Care-ii
    • LAST UPDATED: 2012-05-28
    • 6 POSTS
    • FIRST POST: 2012-05-28
    Whirlpool Washer Ultimate Care ii Model Number: SM 8280867 Brand: Whirlpool Age: 6-10 years Hello, The washer ...
    Jan 27, 2016 | Washing Machines
    Replace belt for model CJ4732600
    that model number you sent isn't a good model number,your problem is under Whirlpool Ultimate Care II LSQ9549L Top Load Washer,if this is your washer there isn't a belt in it,it has a motor coupling,let me know if this si your washer and i can help you out.
    Jan 16, 2012 | Whirlpool Ultimate Care II LSQ9549L Top...
    I need a part for my Ultimate Care II LSQ9549L Top Load Washer Problem
    Go to www.appliancepartspros.com and enter your model number,select your model then locate your part on the diagram. Then order your part from them.
    Aug 24, 2011 | Whirlpool Ultimate Care II LSQ9549L Top...
    Whirlpool Ultimate Care II LSQ9549L Top Load Washer were is the drain filter
    Hi.
    With Whirlpool top loader models the pump is located at the bottom of the appliance. The pump is accessed from underneath the appliance. Some model may have an access panel at the back. I think that with the Ultimate Care models the pump must be accessed from underneath. Here a repair video.
    Here parts and diagrams.
    Aug 07, 2011 | Whirlpool Ultimate Care II LSQ9549L Top...
    Will not fill with water
    Return to dealer and request the model with the Ultimate, Ultimate Care... preferrably the one with the Ultimate care III feature.
    Mar 20, 2011 | Whirlpool Ultimate Care II LSQ9564J Top...
    Washer will not spin.
    May be the coupler between the motor and the transmission.
    Sep 08, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
    How do I take off Whirlpool Washer cabinet to get to the pump
    Go to;
    http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=LSQ9564J
    click on your model number. The new window will give diagrams in the left-hand side.
    Click on the diagrams. This will show the assembly of the unit. Use this as a guide for dis-assembly and re-assembly and do not mix-up parts as they are removed.
    Apr 13, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
    I can't find the model number on washer Whirlpool Ultimate Care
    Model # and info is under the lid. Open lid and look directly under it - area facing you. You should see a small silver tag with all the factory info on it. My washer is also 9 years old.
    Dec 08, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
    Washing Machines Logo
    Dan Webster
    Dan Webster
    Sal DeAngelo
