Samsung rv511 the power point on my laptop overheats and melts the charger why?
    Top Expert:
  • Computers & ... Master
  • 25,262 Answers
Faulty connector?
Posted on Dec 30, 2013
5 Suggested Answers
jts4utotrip
  • 20 Answers
SOURCE: HP Ze2000 laptop charger overheats
CHECK THE POWER OUTPUT RATING ON YOUR POWER SUPPLY AND SEE IF IT IS HIGHER THAN THE COMPUTERS POWER RATING, THIS INFO IS ON BOTH THE LABELS OF THE COMPUTER AND SUPPLY, IF ONE IS HIGHER THAN THE OTHER THAT WOULD EXPLAIN THE OVERHEAT, IF THAT IS NOT THE CASE, THEN GO TO ACERS TROUBLESHOOTERS WEBSITE OR CONTACT THEM DIRECTLY FOR HELP... JON T
Posted on Dec 07, 2008
SOURCE: My Samsung laptop rv511 won't
Check in the back side you can see battery inside the laptop. Pull it then reconnect .if still same then make sure your battery is working fine. There should be issue with battery if battery is fine then you need to take it to nearest service center because there is problem inside the laptop like motherboard or circuit related issue. most of time laptop battery create this type of issue..So check the battery. Let me know if you need further assistance. Thanks for using FixYa.
Posted on Jun 30, 2011
elix0411
  • 3530 Answers
SOURCE: My Samsung rv511 wont powered
Welcome to Fixya
Try to drain the electrostatic charge of the board. Take out the batery then unplug the adapter from the wall. Press and hold the power button for 15secs. Plug in everything back then turn ON the computer.
If same thing happens, please provide infromation that i need.
Did you hear that the harddrive is running on your computer?
The green light that you are referring, is it the power light inidicator?
Thank you for using Fixya!
SOURCE: my samsung RV511 laptop won't boot and the monitor keep on flashing on and off but the power indicator still ligths on
The monitor keeps flashing on and off? Or does your system keeps trying to reboot which causes the monitor to go on and off. Does the screen turn Blue before it goes off?
Posted on Apr 10, 2012
My charger wire broke right at adapter and was wondering where the blue and brown wires go on adapter? One goes in centre and other attaches to the pin that inserts into laptop?
In the manual it shows a picture of the side of the laptop.
on which it shows an engraving which show the power plus pin goes to the centre and the negative to the outside (shell)
see the manual here
http://downloadcenter.samsung.com/content/UM/201409/20140902090435936/Win7_Vista_Manual_eng.pdf
Mar 17, 2015 | Samsung Rv511
My samsung laptop charger gets hot and starts to melt when pluged in and powered up and does the same if i take the battery out please helptried a new battery and new charger could it be the jack on the...
I'm unclear however
Does the new charger get too hot? If so the problem is not the charger or the socket.
Does the laptop work with the new charger plugged in but no battery? If so the socket on the laptop is probably ok
Is the actual charger melting or is it just the plug that goes in the laptop that's getting hot, if it is the plug on both chargers then the socket will need repairing or resoldering, they are a weak point, the soldered pins go high resistance and can generate a lot of heat around the plug and socket. Its usually obvious if the socket is faulty because as you move the plug it makes contact intermittently.
DONT USE THE CHARGER THAT'S MELTING and if both are getting hot have the socket repaired.
If only the one charger getting hot the short is probably in the plug on that charger but read on
On a different note the genuine chargers should be over current protected and overheat protected, they should never melt.
May 13, 2014 | Samsung Rv511 Series Laptop Intel I-core...
When i plug charger samsung rv511 laptop its showing plugged in not charging .how to fix to fully charge
maybe the battery is full charged. run without plugging in that is best. pluging in and battery at full charge is not a good thing.
Mar 14, 2014 | Samsung Rv511
The power point keeps melting the charger
Which power point? The power into the charger or the power lead to the laptop?
Jan 20, 2014 | Samsung Computers & Internet
Samsung rv511 a03za
Download the guides from the link below to assist.
http://www.samsung.com/uk/support/model/NP-RV511-A07UK-downloads
You can also run the crucial memory check to determine what you need.
Dec 27, 2013 | Samsung Rv511-a01 Laptop
Adapter from power cord gets power, but is not charging samsung rv511 laptop
Step 1:
b> If your laptop charger seems broken, it's most likely because the battery will not charge. You plug in the cord, the lights come on, but the charging light doesn't change or blinks repeatedly. When you remove the power cord, the laptop shuts off instantly due to the depleted battery. There's more than one cause for this, and it's not always a broken charger.
Check the connection between the charger and the laptop. It should fit firmly in the DC jack without wiggling. If it is loose, use electrical tape to hold it in place so the charger can receive power. This is a temporary fix, however, because a faulty connection can create sparks and cause a fire or injury. A loose connection will just get worse over time, so have it sent to a DC jack specialist as soon as possible. Turn off the laptop and flip it upside down. Locate the latch that secures the battery and slide open. The battery should pop out; give it a tug if it doesn't. Apply a small amount of rubbing alcohol (Methylated Spirits)to the tip of a cotton swab and use it to clean the battery's connectors. Dirt can build up and interfere with the connection, giving the appearance of a broken charger. Let the alcohol dry completely and re-insert the battery. Slide the latch to secure it and plug in the power cord to test it. See if the laptop powers on with the charger only and battery removed. If it does, the battery is the likely culprit and should be replaced. If the charger is truly broken, the only thing to do is to replace it or the power cord attached to it. Look on the bottom and write down the part number. Call the laptop manufacturer for a replacement charger or search for the part number on eBay. If you purchase from anyone other than the original manufacturer, ask for genuine parts to reduce the possibility of problems. Troubleshoot Mag Safe adaptors
http://support.apple.com/kb/ts1713
Feb 12, 2013 | Samsung Rv511
Laptop RV511 shutdown during surfing
have look at your system indicator??
if CPU are full a too long time it overheat and the computer shotdown
try to see less page at the same time and close useless programmes
Oct 28, 2012 | Samsung Rv511
The needle from my charger broke inside my laptop how do i get the needle out
You mean the charger pin stayed in the power jack? Power jack is very fragile, you'd better not force it out. Take it to a repair company, they will help.
May 08, 2012 | Samsung Rv511 Series Laptop Intel I-core...
My samsung RV511 laptop seems to be overheating a lot. Whenever the computer is under a heavy load it just shuts off. I bought 2 different cooling mats and they do not help. It is to the point now that...
Check the cooling fan at the bottem of the laptop see if is working ,also use a can of compressed air and blow out the fan give it a thorough cleaning if need you might have to replace the fan .If you will supply me with a model number I will get instructions on how to disassemble to put in a new fan
Sep 07, 2011 | Computers & Internet
Computers & Internet Logo
78 people viewed this question
David Payne
David Payne
