Samsung s7233 auto charging solution - Computers & Internet
What is causing my Samsung s5 to overheat while charging
1. Screen Brightness (auto best)
2. Location Services
3. If your aren't using it turn off wifi
4. Turn on power saving mode
6. Make sure bluetooth is off
7. Close all apps
8. If needed try shutting down phone while charging
Jun 03, 2016 | Samsung Cell Phones
My samsung gt-c3303 champ auto charing problem,tell me solution of this problem?
Hello Friends:::::::::
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
Jan 14, 2013 | Cell Phones
Samsung wave s525 auto charging show problem
samsung wave 5253 auto charging,usb symbol
Nov 22, 2011 | Computers & Internet
I dont know how to connect my Samsung wave 723 to my computer to transfer images and muic to it. How do I do it. Ive plugged the UBS cable in but the computer doesnt recognise it?
I have a samsung galaxy S and the phone doesnt come with a cd and neither does yours. What you need to do is go to:
http://mea.samsungmobile.com/ENG/support/softwaremanuals/softwareKiesUpdate.do?phone_model=GT-S7233 moz-screenshot.pngmoz-screenshot-1.pngmoz-screenshot-2.pngmoz-screenshot-3.pngmoz-screenshot-4.png
When the page loads up there should be a button saying "Download Kies" it should be under the bit that says how to upgrade. You need to click that button and download Kies. Kies is a program that all new samsung phones are using, once download has completed and you have installed kies it gives your computer the essential drivers it needs to recognise your phone. The website also explains how to connect your phone after the installation is complete.
Hope this helps
P.S dont worry about the upgrade part of the website as it is your choice to upgrade your phone it is just what the website is for.
Jan 11, 2011 | Samsung Computers & Internet
Samsung charging problem
If very well could be the charging port. Have you tried a different charger?
If it is the charger port, You have 3 options.
1. get it repaired, warrant if possible
2. Get a new one
3.Get an external battery charger and charge battery separate from phone.Another battery and charger will set you back about 10 dollars on ebay2.gif.
For more information and links to the parts check the following link below.
Samsung SGH-D900 charging problem repair
May 13, 2009 | Samsung SGH-D900 Cellular Phone
Need unlocking code for samsung c300
hi,
THIS CODE WILL UNLOCK ALL OF THE NEW MODEL SAMSUNG PHONES EXCEPT SMART PHONES. (X495-AND UP)
*7465625*638*00000000*00000000#
NEXT ENTER
#7465625*638*00000000#
AND THEN *#7465625# to check the locks....all locks are inactive...these are all the locks...
network lock - inactive
subset lock - inactive
sp lock - inactive
cp lock - inactive
sim lock - inactive
activa lock - inactive
phone lock - inactive
auto network - inactive
auto subset lock - inactive
auto sp lock - inactive
auto cp lock - inactive
auto sim lock - inactive
gaframe = true; ' + '' + google_ads[i].line1 + '
' + '' + google_ads[i].line2 + ' ' + google_ads[i].line3 + '
' + '' + google_ads[i].visible_url + '
'; } } var adsByGoogleRight = "-40px"; if(dartRecieved){ document.getElementById("ga_300x250").style.clear="both"; document.getElementById("ga_300x250").style.left = "0px"; document.getElementById("inner_adv_caption").style.display = "block"; adsByGoogleRight = "5px"; document.getElementById("ga_300x250").style.width = "370px"; } else if(isHealthinationExist){ var healthinationBox = $('healthonationBox'); if(healthinationBox){ var helthinationBot = getObjXY(healthinationBox)[1]+healthinationBox.clientHeight; var ga_top =getObjXY(document.getElementById("ga_300x250"))[1]; if(ga_top-helthinationBot >0){ document.getElementById("ga_300x250").style.width = "530px"; } else{ document.getElementById("ga_300x250").style.width = "410px"; } } $('boxAdWrapper').style.display = "none"; } else{ document.getElementById("ga_300x250").style.width = "530px"; $('boxAdWrapper').style.display = "none"; } //add "ads by google" var logo_img = 'abg-en-100c-000000.gif'+versionno+''; s += '' + logo_img + ''; document.getElementById("ga_300x250").innerHTML = s; var currl = $('related_links'); var currq = $('related_questions'); if(currl!=null && currq!=null){ var currltop = getObjXY(currl)[1]; if(currltop > rltop ) currq.style.clear="left"; } return; }; //--> var niB = document.getElementById("niBannerID"); if(niB && niB.style.display=="block"){ document.getElementById("q_answer").style.marginTop = (niB.offsetHeight+30)+"px"; } -->
Apr 12, 2009 | Samsung SGH-C300 Cellular Phone
Codes
Samsung Secret Codes
*2767*688# = Unlocking Code
*#8999*8378# = All in one Code
*#7465625# = Check the locks
*7465625*638*Code# = Enables Network lock
#7465625*638*Code# = Disables Network lock
*7465625*782*Code# = Enables Subset lock
#7465625*782*Code# = Disables Subset lock
*7465625*77*Code# = Enables SP lock
#7465625*77*Code# = Disables SP lock
*7465625*27*Code# = Enables CP lock
#7465625*27*Code# = Disables CP lock
*7465625*746*Code# = Enables SIM lock
#7465625*746*Code# = Disables SIM lock
*7465625*228# = Activa lock ON
#7465625*228# = Activa lock OFF
*7465625*28638# = Auto Network lock ON
#7465625*28638# = Auto Network lock OFF
*7465625*28782# = Auto subset lock ON
#7465625*28782# = Auto subset lock OFF
*7465625*2877# = Auto SP lock ON
#7465625*2877# = Auto SP lock OFF
*7465625*2827# = Auto CP lock ON
#7465625*2827# = Auto CP lock OFF
*7465625*28746# = Auto SIM lock ON
#7465625*28746# = Auto SIM lock OFF
*2767*3855# = E2P Full Reset
*2767*2878# = E2P Custom Reset
Mar 08, 2008 | Samsung Blackjack SGH-I607 Smartphone
Computers & Internet Logo
43 people viewed this question
David Payne
David Payne
