Question about Toshiba Satellite Computers & Internet
Problems with toshiba computer keyboard
Only can use certain alpha keys
    Top Expert:
  • Toshiba Master
  • 26,218 Answers
Hold down Alt and Ctrl keys and click the + key. That should toggle the Fn number keys on or off.
Posted on Dec 30, 2013
warlock61
  • 659 Answers
SOURCE: keyboard Fn appears to be stuck
check to see if the num lock key is on
Posted on Nov 24, 2008
mikeleach
  • 48 Answers
SOURCE: problem with toshiba laptop keyboard pressing wrong extra keys
Take the keys off yor keyboard, clean and remove and dirt, replace keys and try again
hope this helps
Posted on Jun 07, 2009
darkpain
  • 316 Answers
SOURCE: I have a Toshiba NB100 notebook and the alpha on
Hello
Unfortunately my friend this is the big problem with that laptop,small keyboard and not good back lighting,the only think you can do is to buy keyboard stickers or a keyboard
Here is a link to ebay for stickers
http://shop.ebay.com/?_kw=keyboard%20stickers&_fcid=80&_localstpos=&_sticky=1&_stpos=&gbr=1
Posted on Jan 13, 2010
SOURCE: red symbols on keyboard - Toshiba satellite A350
You hold down the "Maser" RED or BLUE keys, down bottom left, with red & blue circle etc on the master key.and "Tap" the corresponding Blue key, to access the "Function" under that Key.
Posted on Mar 24, 2010
  • 17 Answers
SOURCE: Keys that have Alpha and Numeric always show numeric and not alph
Try replacing the keyboard. sounds like a button is stuck and is causing the problem.
Posted on Jun 04, 2010
Can only certain alpha keys
I would try cleaning your keyboard. If you are gentle you can remove the F10 key and check that they is no dirt underneath. Check other keys near the F10 key in case others have the same problem. I know that a sugary Cola spillage on a keyboard really sticks things up. In that case it was easiest to get a new keyboard.
Dec 30, 2013 | Toshiba Satellite L455DS5976
My Toshiba satellite C650 laptop has certain keys that don't respond, certain letters, spacebar, shift. I replaced the keyboard, but the same problems persist. The keys that do not function are for example...
ok
solution
you need to open the computer
select c drive
right click it select properties
list will open
select
tools here you will see
drive errors click it will scan for anything not working
if not try this in search bar bottm left
type in drivers
this will open the device manager
look in list
select keyboard
update driver
done
Aug 18, 2013 | Computers & Internet
Alpha keyboard not working
if usb keyboard and local keyboard aren't working i'd check to see if you have a fuction key pressed that disables you from using the keyboard, try restarting, if it solves the issue it was a FN key if not, problems deeper and you may want to look at hardware diagnostics
Apr 17, 2013 | Acer Aspire Computers & Internet
How do you solve log problems on your calculator
I have no idea what type of log problems you want to solve. It does help to know what you have in mind. To type in the log function log(, you have two ways:
1. Use the keyboard to type it in on the command line APLHA L, ALPHA o, ALPHA g followed by opening parenthesis. Or if you can LOCK the alpha keyboard, lock it and press the keys corresponding to the letters l, o, and g.
2. Press [Diamond key] [7]
The last trick works on the TI92 and TI Voyage 200 PLT which have a full fledged keyboard. Try it anyway, if that does not work you can still use the ALPHA keyboard.
Jul 26, 2011 | Texas Instruments TI-89 Calculator
Certain key (The A,B,N, Enter and right hand Shift keys will now work. Any fixes for this problem? Toshiba says it's a motherboard problem. I'm thinking it's not.
It shouldnt be a Motherboard problem. You may need to take apart the keyboard and clean it or it may be need to be replaced all together but the keyboard is separate from the Motherboard.
Feb 28, 2011 | Toshiba Satellite A505S6981 Notebook
Jun 03, 2010 | IBM ThinkPad T41 Notebook
Hello
Jan 13, 2010 | Computers & Internet
Problem with toshiba laptop keyboard pressing wrong extra keys
hope this helps
Jun 07, 2009 | Computers & Internet
Keyboard disfunction
your hot keys are set that way goto search and find "hot keys" with out the ""
and you should be able to fix the problem
Nov 01, 2008 | Toshiba Tecra M2 Notebook
10 key pad within the alpha keyboard
Utilize the numLK button located in the upper right area of the keyboard. Depending on the layout, you may need to press it in conjunction with the Fn or Shift key.
Good luck.
Nice laptop
Nov 01, 2007 | Toshiba Satellite M45-S169 Notebook
Computers & Internet Logo
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
