Question about Lands Phones
Can not clear full message storage area on KX-TG4500. This is the second time memory has overflowed and the instructions don't work.
  • 3 more comments
  • ronfunke May 19, 2009
    The written solution, similar to what is in the manual does not work!
    I will unplug the thing while I am out for a while. This isn't the best solution, since I will need to re-program the machine afterword and will lose some messaged I'd rather keep.
    Thanks,
    Ron
    I'll get back to you - this type of service seems like a reat idea.
    The listed instructions didn't work - multiple times.
    I've unplugged the power cord and the battery back-uo and left it off for over two hours.
    I tried reset several times and nothing works. I seems like the last time reset was finally successful. Now nothing.
    I am gi to buy a different phone - this phone has several issues that I don't like, so it's now for sale cheap! $200.00
    You attempts at solution provided no relief.
    Ron
    One last attempt. My Panasonic KT-TG 4500 has a full memory and will not record incoming calls anymore. I have tried the tactics listed below, to no avail.
    If yoy have another idea, let me know - I'll try it.
    Ron
    Ron
    this doesn't delete the exist messages in the full mailbox.
    nothing that anyone has suggested yet has worked.
    re: Auto delete message>
    nothing that anyone has suggested yet has worked yet -- they are all variations on what the manual says.
    If anyone has a new solution, I'll be happy to give it a try.
    Ron
  • 385 Answers
Try this please, thanks
Erasing all messages stored in a
mailbox
While in standby mode, press {MENU}.
2 Scroll to “Initial setting” by pressing {up} or (down}, then press {ENTER}.
3 Scroll to “Initialize base” by pressing {up} or {down}, then press {ENTER}.
4 Scroll to “Messages” by pressing {up} or {down}, then press {ENTER}.
5 Select the mailbox(es) to delete using the corresponding keypad keys {0} to {8}.
You can also use the
{INTERCOM} keys. Select all mailboxes by pressing the {INTERCOM ALL} key.
Note:
Pressing a key toggles the current setting. For example, press {1} once to select mailbox 1, then press it again to de-select.
Pressing a key for an invalid mailbox will result in an error tone.
6 When all valid mailbox numbers have been entered, press {right arrow}.
7 Select whether to delete just messages, or messages and greetings by pressing {up} or {down}.
8 Press {CLEAR} to complete the operation.
Confirmation tone is heard.
Hope this helps
Richard
Posted on May 19, 2009
  • Richard Finney
    Richard Finney May 19, 2009
    Auto delete...
    1 While in standby mode, press {MENU}.
    Scroll to “Initial setting” by pressing {up} or {down}, then press {ENTER}.
    Scroll to “Mailbox” by pressing {up} or {down}, then press {ENTER}.
    Scroll to “Auto message delete” by pressing {up} or {down}, then press {ENTER}.
    The current setting is displayed if the system’s date and time have been set. If the date and time have not been set, you are requested to set them before proceeding.
    5
    Press {up} or {down} to select “On” or “Off”.
    6
    Press {ENTER}.
    Checking the remaining
    recording time and number of
    messages
    This feature displays the remaining amount of recording time available, and the number of messages that may be recorded.
    Press {MENU}.
    hope this helps
    Regards
    Richard
  • 15,935 Answers
Is the General Delivery Mailbox full - or an individual handset's mailbox full??
You must know before attempting to erase messages.
All messages can be deleted from the base unit.
While in standby mode - press MENU
Using ^ or v scroll to "Initial Setting"
Using ^ or v Scroll to "Initialize Base"
Scroll to "Messages" by pressing ^ or v
Select the mailbox(es) to delete using the corresponding KeyPad Keys 0-8
- Select ALL mailboxes by pressing the INTERCOM ALL key -
When all valid mailboxes have been entered press >
Using ^ or v select wether you want to delete just messages or messages and greetings
Press CLEAR to complete
-confirmation tone is heard-
If you do not already have a PDF copy of your owner's manual... http://lib.store.yahoo.net/lib/ahernstore/kx-tg4500b.pdf
The Voice Mail system operating instructions begin on page 51
If you need further clarification - please use the "Continue with this expert" option so we are connected in the future.
Thanks for using FixYa!!
Posted on May 20, 2009
  • Lands Phones Master
  • 13,433 Answers
Try taking the batteries out from the phone and or the station, and unplug it, make sure it has no power. Most of these phones memory gets reset / emptied when the power goes out completely.
there is a battery in the back of the station.
let it be at least a hour without power, Also if that doesn't solve the problem - there is a reset button in the bottom. try pressing it and then check if the messages are still there, if they are try another reset this time hold the button down longer at least 30 seconds.
if the problem is still not solved follow these steps exactly, they should get rid of the messages.
Erasing all messages stored in a mailbox
The base unit user can erase all incoming messages in any mailbox. Inform the mailbox owner(s) before erasing, and check that there are no new messages in the mailbox(es).
1 While in standby mode, press MENU
2 scroll to Initial settings, by pressing arrow up or arrow down keys to navigate the menu, ones there press ENTER
3 scroll to Initialize base, same way as before and press ENTER
4 scroll to messages, same way as before.
5 Select the mailbox or mailboxes that you want to delete using the corresponding keypad keys 0 to 8. you can also use the INTERCOM keys. Select all mailboxes by pressing the intercom all key.
When you have selected the mailboxes or all of them press the Arrow right key or play key.
Select whether to delete just messages, or messages and greetings by scrolling the menu as before.
Press CLEAR to complete the operation. Confirmation tone is heard.
If first you don't succeed try again a few times or get a friend to try it, you might be doing a step or two wrong at somepoint.
Let me know if you need further assistance.
Thanks,
Ekse
  • Ekse May 19, 2009
    those are the official steps on how to clear out the messages, it should work, if it doesn't then what happens? do you hear the confirmation sound? did you select all the boxes?. I think you will need to take the phone to a dealer for testing, I'm sure they will find you the fault / fix it.
Erasing Memory from KX-FHD332
Follow page 65 and 72 of Panasonic KX FHD332 Operating Instructions Manual
Memory full
When making a copy, the document being stored exceeds the memory capacity of the unit. Press {STOP} to clear the message.
Divide the document into sections.
Fax/memory full
The memory is full of received documents due to a lack of recording paper or a recording paper jam. Install paper (page 14)
or clear the jammed paper (page 72).
L When performing memory transmission, the document being stored exceeds the memory capacity of the unit. Transmit the entire document manually
Mar 11, 2016 | Panasonic Office Equipment & Supplies
What does a boken dialling tone on my phone mean? It is all working fine and there are no warning messages on the display.
Usually broken dial tone means the line has call-forward set. You get broken tone for 3 or 4 seconds, then goes back to normal. Are you receiving incoming calls normally? It's common to set or cancel 'cause the code might kinda match a number you use. And it may be forwarded to nowhere, example, you dial 729-1111, but press 72#-1111. You might be forwarded to 1111, the code being 72#. The 1111 goes nowhere, someone calls you, calls gets forwarded, then they get a message"that number does not exist". If that's the code for your area, then 73# might be the cancel code. Check the front of the original phone book, or Google codes for your service provider.
Jun 11, 2014 | Panasonic KX-TG4500 Phone
Why does my land line phone display "new voicemail" when there are none?
You apparently have unheard messages on the voicemail system provided by your telephone company. This system records messages when someone calls while you're already on the phone. Please contact your telephone company for instructions on accessing their voicemail system.
May 25, 2014 | Panasonic KX-TG4500 Phone
The message memory is clear bt i can't reply massage
Check all your drafts and saved messages. If any clear them. Also clean your outbox or sent items. Change settings from sim storage to phone storage. You can do this by going to message settings > memory in use> and so on.. again depending on your phone.
Jan 17, 2014 | Sony Ericsson TM506 Cell Phone
Message light blinking messages
You have unheard messages on the voicemail system provided by your telephone company. This system records messages when someone calls while you're already on the phone. Please contact your telephone company for instructions on accessing their voicemail system.
Jan 02, 2014 | Panasonic KX-TG4500 Phone
My voice mail doesn't record but the outgoing greeting keeps on repeating?
try deleting some recorded messages, your memory might be full
Dec 24, 2010 | Panasonic KX-TG4500 Phone
Hi what are the zip files for?
Basicly, your PDA has these kinds of storage areas:
1. Main Storage (Where windows is) 3. Storage Card (2GB in your case)
If your main storage area is full, your PDA will start to show up messages that your memory is full. In this case, if your personal zip files, or other files are in your main storage area, you can transfer them to your Storage Card (cut & paste) using the file explorer in the start menu to free up some space in your Main Storage area. But be carefull while doing this process, because some files are needed to stay in the main storage area for the windows to function properly. So you should consider only transfering personal data like notes, pictures, etc..
Apr 11, 2009 | HTC Touch P3450 Smartphone
Panasonic kx tcd420es
I cant get it to work
Apr 28, 2008 | Lands Phones
Keep Adding Toner to Panasonic KX-FL511
kindly follow this instruction
but doing this will erase all the message in the memory
press menu #9000*550 start
unplug the unit once heard the beep
after 10 seconds, plug it again
Jan 28, 2008 | Panasonic KX-FL511 Plain Paper Laser Fax
Lands Phones Logo
205 people viewed this question
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
