Question about OKI B6500 Led Printer
Ip address collision - OKI B6500 Led Printer
What is the ip address
IP address
noun Computers. a code that identifies a computer network or a particular computer or other device on a network, consisting of four numbers separated by periods. See also IP.
http://dictionary.reference.com/browse/IP+address
PS. Free points for newcomers or are you to lazy to google it?
Aug 23, 2013 | Comtrend CT-520 Router
What is ip address
Internet Protocol is also known as Ip address.Every users on internet have their own ip address.Users on internet identify by their ip address.Ip address provided by the internet service provider.There are two types of ip address static,dynamic ip address...
Static Ip address will not change forever ..Even if you reset the modem the static ip address won't change.Static Ip address also known as dedicated ip address..You can use for website..This ip is dedicated for your website only..
Dynamic Ip address :
Dynamic ip address will change whenever you reset the modem.A new ip address will assigned for your connection...You can use dynamic ip address for browsing and normal internet usage....you can use the site Ip-details.com check the ip address whether it is static or dynamic ip address
Jul 24, 2013 | Computers & Internet
What is an ip address
An IP address is also known as Internet Protocol Address.It is very important in Internet.Every Internet users are identify by their users using their IP address.IP address is Unique.You can get it from your Internet Service Provider[ISP].
IP address are two types.
There are Internal and External IP address
Internal IP means that your system IP address.
If you want to know your system ip address follow these steps:
Start--->run-->Type cmd
Then command prompt will display.
type ipconfig
then it will display your system IP address
External IP address means that your network IP address.
If you want to know your Network IP address then visit IP-details.com here it shows the details like ISP(Internet Service Provider),IP location,country,latitude,longitude etc..
Mar 15, 2013 | Computers & Internet
What is the loop backup ip and why its being use?
Loopback detection is used to prevent any looping of signals of on two ports it will shut the 2 ports down until line is cleared perventing a collision of packet jam Notifies administrator where a problem is
Aug 26, 2010 | D-Link Computers & Internet
How do you troubleshoot input errors eth is UP, line protocol is UP Hardware address is Ip address is XXX.X.X.XX, netmask is 255.255.255.0 MTU is 1500 bytes, BW is 100000 Kbit 100Mb/s, half-duplex ARP...
You have input errors but no output errors, and your link is showing half duplex.
The device connected may be set at full duplex, but this is in fact normal for half duplex connections which do NOT allow send and receive at the same time. Ensure both ends are set to full duplex.
Mar 11, 2010 | Adtran NetVanta 4305 Router (1200890l2)
Genius LAN 16 Port Hub Dropping connections intermittently
Col probably means Collisions. There are probably collisions going on on your LAN. Collisions can happen when there are two adapters with the same IP address or when there's a bad cable. My suggestion is that you make sure that you have unique IP addresses and that you don't have any bad cables - cable tester comes in handy.
Mar 27, 2009 | Computers & Internet
Printer does not print jobs but shows them as ready
Possible collision, check the printer's IP address.
Nov 24, 2008 | HP 4250 Monochrome LaserJet Printer
Dynamic IP address
Dynamic ipaddress - is temporary, the ip changes when you disconnect for example.
Normal, or static ip - It's the same address from day to day.
May 19, 2008 | Computers & Internet
Xoom x6 adsl modem problem
possible issue with freequent connection loss when going over 2 comp on a network are possible issues of collisions on the network meaning that sometimes more often then not, it is possible for two comp to end up recieving same ip address fr modem.
solution: first find out ip range supplied by the router in modem. then statically assign ip address to each comp
this is done by going into tcp/ip properties of either nic or wireless card and set to use following ex
NOTE: IP RANGE USUALLY LAST SET OF NUMBERS IN IP ADDRESSING TIPPICAL RANGE IS BETWEEN 10 TO 99
ip address: 192.168.2.12 (static ip address for computer)
subnetmask: 255.255.255.254 (generic subnetmask)
default gateway: 192.168.2.1 (ip address of router)
Oct 18, 2007 | Zoom X6 (5590) DSL Modem (55900003)
OKI B6500 Led Printer Logo
441 people viewed this question
Top OKI Office Equipment & Supplies Experts
WTF Chuck.....
WTF Chuck.....
Jimbras
Level 1 Expert
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
