Question about Craftsman Sears Snow Thrower Manual Model 536.881800
How to clean carbretor
Starting problem new plug new gas
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 2,069 Answers
Unscrew the Bowl on the carburetor. The brass bolt that held the bowl on is the Jet. it has two large holes by the head of the bolt and one very tiny one at the end of the threads. make sure they are clear .
That's usually what goes bad
Posted on Jan 22, 2014
New spark plug, fresh gas, clean air filter. Wont start.
take the fuel line off at the carburetor. if fuel is coming out then you have a plugged carburetor. take it off and apart. clean it really good with carburetor cleaner and put in a new needle and seat. it should run as good as new.
Apr 30, 2016 | Garden
My poulan won,t start ,i put new primer bulb on and new gas lines nowit won,t start
Flush old gas. Clean or replace spark plug. Check float on carb, clean carb bowl if equipped.
Jun 03, 2015 | Poulan Garden
Rebuilt a honda c50 engine valve timing is set and i have spark at the plug and can not get it to fire i also replaced the carbretor
Squirt a little gas into the carb. If it starts must be fuel system. If it doesn't it's the ignition system.
Sep 07, 2014 | Cars & Trucks
I have a 2007, 6500 Craftsman tractor with 26 hp engine (kohler) that won't start. The tractor was running (old gas) when we got off it for a few minutes then went back to start it again but it would not...
First check fuel shutoff valve on bottom of carb . Disconnect and remove , clean witn carb cleaner and be sure there is power at wire when the key is on . Also clean carb jets and bowl .....
Jun 11, 2017 | Craftsman 26 Hp 54" Deck Yard Tractor
Was rideing and just stalled like it had no fuel!! but does have fuel. now i turn it over by electric start and is now back fireing threw the carbretor and blowing the carbretor off any one know wot this...
clearly a valve issue. the valve that give gas and air to the chamber and closes in combustion may be damaged as it is letting the cumbustion out to the carb.
very dangerous i may say as the shraps from the carb will be a shotgun shots on your leg.
have this repaired as a new valve will be around 100-300$ depending on the brand and the condition. get an oem
Oct 06, 2009 | 2003 KTM 640 Duke 2
25cc TB25BP new plug, new Gas, Clean Carb.. will not start
Check Make sure its the right plug.- Check for stuck choke-Check.Air/fuel mixture screws out of adjustment.
Sep 22, 2009 | Troy-Bilt 25cc 2-Cycle Backpack Blower...
Honda Pressure Washer HP 5 not starting
You can try spraying some carburetor cleaner into the carb. If it starts for a minute, your carburetor need cleaning. When you added new gas did you remove the old gas first? Is the air filter clean?
Jul 18, 2009 | Honda 8 HP Engine
I have a chainsaw carb problem
clean out the two gas hoses with a pipecleaner then check replace the in-tank fuel filter if the carb still does not recieve gas your fuel float in the carbretor is not rising to let in the gas this will require disassembly of the WT324 carbretor
Apr 28, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Looking for briggs+stratton repair manual 271172
wiill not start has all new spark plugs and fuel filter
Mar 20, 2009 | Briggs & Stratton Garden
Craftsman Sears Snow Thrower Manual Model 536.881800 Logo
100 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
