Question about Sharper Image (SI714SL2) Compact Refrigerator
My refrigerator motor is not running - Sharper Image (SI714SL2) Compact Refrigerator
Everything works. But the fan runs all the time on or off. 25/7
Condenser Fan Motor Operation ' FAQ ' Sub-Zero and Wolf
www.subzero-wolf.com/.../condenser-fan-motor-operation
Sub?ZeroShould the condenser fan motor on a Sub-Zero run continuously? Why does the fanmotor run all the time? ... Refrigerator or Freezer Fan Switch Information.
Refrigerator Condenser Fan Is Always Running ' Home ...
homeguides.sfgate.com > Insurance & Inspections > Insurance Basics
Refrigerator motors sometimes need troubleshooting over time. ... If the fan isn't shutting off there could be several reasons. ... reason a condenser fan is continuallyrunning within a refrigerator is the thermostat. ... All Fields are required. Name.
Oct 30, 2015 | Refrigerators
Frigeair refreator motor keeps running
Good Afternoon Friend,
I see that your Frigidaire refrigerator motor keeps running. I will be more than happy to assist you. If I could please have the model number of your refrigerator, this way I can better assist you in resolving the possible troubles with your appliance. Looking forward to hearing from you.
WP
May 13, 2014 | Frigidaire Refrigerators
Refrigerator runs too long.
Thank you for contacting fixya.com.
There are various reasons why a refrigerator keeps on running.
The motor will run longer under warm conditions or if the refrigerator is receiving direct sunlight from a window or door. At normal room temperatures, your motor will run about 40% to 80% of the time. Under warmer conditions, it can run even more.
A recently installed refrigerator will initially run more while cooling. Allow 24 hours for the refrigerator to completely cool.
When large quantities of food are added, the refrigerator has to run longer to cool the new items.
The motors will run longer when the doors are frequently opened. Conserve energy by getting all items out one at a time, keeping food organized, and closing the door as soon as possible.
Also a worn door seal or gasket in refrigerator or dirty condenser coil can be the reasons for refrigerator to run long.So you need to consider all these factors troubleshoot your problem to your refrigerator.
Please get back to us if you have further query else please accept the suggestion.
Jun 02, 2011 | GE Refrigerators
Side-by-side refrigerator - freezer is working just fine, but the refrigerator is not cooling.
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Dec 27, 2010 | GE GSL25JFPBS Side by Side Refrigerator
Need info for a kenmore side by side refrigerator model#59652673202 it it not cooling nor freeszing ; the light works and the fan works but not cooling any side please help me
Good day,
With that amount of info it would be hard to try to pinpoint it. Here's a list of items that can cause a refrigerator to not cool.
Items that will cause a refrigerator not to cool.....
1. Defective thermostat
2. Defective freezer fan motor
3. Defective defrost timer
4. Defective defrost thermostat
5. Defective defrost main heater.
6. Defective condenser fan motor
6. Defective compressor overload protector
7. Defective compressor start relay
8. Defective compressor start/run capacitor (some models only)
9. Defective compressor
10. Restriction in refrigeration sealed system
11. Loss of refrigerant (leak)
12. Excessively dirty condenser
13. Broken wires, bad wire harness connectors, ect.
14. Defective fan motor switch (some models only)
As you can see it could be one of many,many items. If your handy with a meter you might want to start at the bottom back of the machine where the compressor is located.
Sounds as if it is not running, or running without refrigerant in the system.
Also, if it has a cooling fan motor in that area, make sure it runs, since all fan motors are wired to run at the same time.
Oct 15, 2010 | Kenmore 44103 Side by Side Refrigerator
Refrigerator is not cooling
Dirty condenser, condenser fan or evaporator fan motor are not running, Ice build up on evaporator and restricted the air flow. If compressor, condenser fan and evaporator fan motor are running but not cooling, then either compressor or sealed system problem.
Mar 07, 2010 | Refrigerators
Motor not running Refrigerator not cooling
There are three possibilities why the compressor motor is not running. #1. The thermostat switch is not closing to turn the motor on. #2. The compressor motor is bad. #3 The defrost timer is engaged, preventing the compressor motor from starting.
Solution for #1: Locate the thermostat switch behind the console in the refrigerator. It is attached to the freezer temperature adjusting knob. If you jump the switch out, the compressor motor should start. If it does, replace this switch.
Solution for #2: get another refrigerator. It is not worth repairing.
Solution for #3: Turn the freezer temperature switch to the coldest setting. Locate the defrost timer in the console on the ceiling of the refrigerator compartment. Look for position labels like "cool control" and "compressor". Jump between these two wires. The compressor should start. If it does, replace this module.
Mar 06, 2010 | Kenmore Refrigerators
My uline refrigerator won't get cold at all. Was
If the refrigeration motor is running and it is not getting cold then it probably is low on freon the gas that is used for refrigeration. Also if the motor only runs for a few minutes then stops it is possible that the cold control is bad, This is a common problem in refrigerators and can be fixed by replacing the control. First you must determine that the motor is in fact running. If the motor is running the motor should feel warm to the touch after 10 to 20 minutes of operation, and you should feel some cooling in the refrigerator on the cooling or evaporator coil. If the motor is running and getting warm or hot and you feel no or very little cooling then it is in fact ether low on freon or a component in the refrigeration system is malfunctioning. Freon can only be replaced by a certified technician.
Oct 07, 2009 | U-Line ?chelon 2175RB-00
The fan keeps running by the motor
the fan must only run when the motor are running
May 15, 2009 | Sub-Zero Bottom Freezer Refrigerator
Roper Refrigerator/Freezer side-by-side
1. check the motor compresors working touch the top 2. if the motor comp. working 3. touch the high side of the tube of the motor comp. if to hot the freon is ok if not. 4. cut the low side of the motor comp. plug and on start to pumping the motor close the hole of the low side tube using your finger hold 30 sec. and then open if the presures ok 5. the problem is freon
Sep 22, 2007 | Roper RS22AQXKQ Side by Side Refrigerator
Sharper Image (SI714SL2) Compact Refrigerator Logo
Top Sharper Image Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Sharper Image Refrigerator Expert? Answer questions, earn points and help others
