Question about Cats
Blinking oil light - Cats
My R15 v2 YZF engine light blinks 10 times firsts 5 blinks slow rest very fast bike tends to stop whenever it appears n stop but when the light is on upper the bikes dont stop above 90 km/hr not stop
Yamaha yellow blinking light start Motorcycles Questions ...
www.fixya.com > ... > Tags > yellow blinking light start > Motorcycles
Ad. Question about 1997 YZF 750 R ... oil light blinking on 2004 yamaha r1 oil lightblinks 10 times stops then blinks 10 ... My yamaha r15 v2 I drive to bike after sometimes yellow engine light on aftersometime I light on to yellow engine light of.
Yamaha blinking yellow light Questions & Answers - Fixya
www.fixya.com > Forum > Tags > blinking yellow light
oil light blinking on 2004 yamaha r1 oil light blinks 10 times stops then blinks 10 times ... Question about 2008 YZF-R15 ... My yamaha r15 v2 I drive to bike after sometimes yellow engine light on aftersometime I light on to yellow engine light of.
[Ownership Thread]: Yamaha YZF-R15 - xBhp.com
www.xbhp.com/talkies/.../4854-yamaha-yzf-r15-1951-print.html
Jul 11, 2013 - 4 posts - ‎3 authors
2months back i got this problem while riding the engine goes off, but ... of heavy traffic after transporting it from my home town. then it works fine and all of a sudden i find the bike engine light blinking. it reads '42'. then after showing it to ... the ECU alone wil cost me to 10k. and obviously it is very expensive ...
Yamaha YZF-R15 version 2.0 - xBhp.com
www.xbhp.com/.../20138-yamaha-yzf-r15-version-2-0-a-786-print.html
Nov 26, 2013 - According to me the problem of chain with my bike is because i ... list about the required changes at 10k kms like Fork oil change and ... On switching on the ignition, the engine malfunction light, the orange(?) ... From your description that a longblink coupled with 3-4 short blinks it .... All times are GMT +6.5.
Jan 27, 2016 | Motorcycles
Check engine light blinking
why did you add oil, without checking what the light says?
only light that blinks is the maint, required light, it tells you that you need to change your oil, then you need to reset it, follow your manual to reset
Jul 03, 2014 | Scion Cars & Trucks
Oil light blinking on 2005 vw gti
Check your owners manual for the procedure to reset the oil change indicator. Sounds like the oil was changed but the reminder was not reset.
Feb 07, 2018 | 2005 Volkswagen GTI
Oil light blinking
My 2002 Toyota camry oil light blinks when the car idls we changed toe oil sending unit and oil pump what can I do to get the oil light to stop flashing..
Feb 27, 2012 | 2002 Toyota Camry
Oil light blinks on
If your oil level is good, that is between the low and high marks, that light blinking is an indicator there is a problem with your oil pressure. The light flashing could be low oil level, a bad oil pressure sensor, your oil pump going out or a clogged line or pick up. Start by checking your oil level, then test the sensor if both are good drain your oil and pull the oil pan off to see if the pick up is clogged, if it is clean it. If everything is good at this point then the problem is the pump itself and you'll need to replace the pump.
Nov 10, 2011 | 1993 Lincoln Town Car
Why is oil light blinking?
Oil light blinking usually indicated low oil pressure / viscosity. Probably either low on oil, incorrect oil weight, poor quality oil, or needs oil changed..........Mike
Jun 19, 2011 | 2002 Mercury Sable
Blinking oil light on 2003 Mazda Protege. Changed oil and oil filter as well as oil sensor. Light still blinks when the car is idled up.
You need to reset your change oil warning light. To do this, turn the ignition key to on but do not turn over the engine. Then rapidly push down the gas pedal three times. This will reset the system and turn off the blinking light. Then when you drive another 3000 miles, that light will once again tell you it is time to have your oil changed. J.
Jun 20, 2010 | 2002 Mazda Protege
Oil light blinking on 2004 yamaha r1
Have you ever changed the oil and oil filter before, it is telling you to change it? Good enough
May 03, 2010 | 2004 Yamaha YZF-R1
Oil light blinking but oil is full, smoking on startup
the oil light is telling you you have low oil pressure. possible bad sensor or filter.
Mar 29, 2010 | 1999 Plymouth Grand Voyager
Blinking oil light, when oil is full
The oil gets lighter as the engine heats up.
Was this problem there before you changed the oil? If no, thn the grade of the engine oil you have used (replace) could be of wrong specs., try using a higher grade.
Hope this helps!
Jun 19, 2009 | 1994 Ford Taurus
Cats Logo
152 people viewed this question
Top Cats Experts
Ruth summersides
Tom Chichester
RANDY POWERS
Level 1 Expert
Are you a Cat Expert? Answer questions, earn points and help others
