Question about Canon BubbleJet i560 InkJet Printer
Prints black on test page, but not when a job is sent to the printer
I just hooked up the Canon i560, after it sat for 6 months.  The colors print OK, but the black won't print when I send a letter to the printer.  The color logo on the letter prints OK, but without any black on it, and without black text.  I tried sending different jobs, but no different result.
Under 'maintenance', I did the nozzle check, and the black prints good.
Any suggestions will be much appreciated.
  • 5 more comments
  • price7 Nov 15, 2007
    Having the same problem as grmack, only my printer had not been sitting awhile. Worked fine one moment, but not the next. Have tried maintenance, and a new black ink cartridge. Still not working.
  • tylerplari Nov 16, 2007
    I have the same exact problem. Received advice from Computer person at work. Go to Canon website and re-install print driver. No change. Try to print test page from the "Printers and Faxes" properties. Only the Windows color logo prints. No black at all. Only prints black with the test page. Black ink cannot be dried up if it does print on the test page, right?
  • dan862 Nov 19, 2007
    Same problem. Prints color but not black text. "Nozzlecheck"printsblack but only because it is mixing the 3 other colors tomakeblack.Test page prints windows logo but nothing else. Black inkandothercartridges have all been replaced. I've reinstalled the driverandthesame problem happens.
  • Vigen Glandian
    Vigen Glandian Nov 26, 2007
    i cant ptint black text or images
  • robinme Nov 28, 2007
    I have the same problem! My black ink wont print AT ALL. I've replaced the cartridge with a canon one after I used a cheap $1 cartridge I got online. I've reinstalled the drivers and still nothing. I hope someone has the answer because I dont want to buy a new printer.
  • Anonymous Dec 22, 2007
    deep cleaning
    head alignment
  • Anonymous Mar 25, 2014
    Copies in IR400 copier giving black horizontal lines test print is OK
Dont even use generic inks especially black - - i installed canon - -now it works fine
Posted on Dec 08, 2007
I just posted and also fixed my problem. Try "deep cleaning" under the maintenance tab. Choose the black cartridge only. Mine only took once to fix but i'd try it 1-3 times before giving up on this solution. It now prints the test page with black and color
Posted on Nov 19, 2007
  • 38 Answers
Make all your printer settings to default. If any problem in that simply uninstall & re-install the driver.
If still no good, your black cartridge might have dried-up
Posted on Oct 20, 2007
My i560 Canon printer prints all colors but not the black ink
after a month of not using the printer, most probably the print head is clogged.. try using the printer utility to clean the print head.. it's under the printer properties.. normally that should resolve the print missing issue...unless your print head is really clogged up...
some would suggest to partial soak the print head onto warm water..but it doesn't work everytime..
May 24, 2010 | Canon BubbleJet i560 InkJet Printer
Distorted printing on i560 printer
Double-click print centre icon.
when it opens up, select I560, then click configure.
click I560 then click select
click the down arrow to select test print.
nozzle, alignment etc...
run the tests try resolve the problem.
Hope this helps
Regards
Apr 16, 2009 | Canon BubbleJet i560 InkJet Printer
Printer not printing
Go to the printer properties and make sure there is not a previous print job. Cancel all print jobs. Then send a test print to the printer.
Mar 27, 2009 | Canon imageCLASS MF5750 All-In-One Laser...
Canon I560s printer
Was this the problem prior to changine the cartriages? If not check the contacts between the machine and the cartriges. there may be tape, ink, papaer in between.
Jul 03, 2008 | Canon BubbleJet i560 InkJet Printer
Stripes on Images only - Text OK
Perhaps the CMY color heads need alignment. If you have not already done so, run a head alignment from the driver maintenance section. It will print out a page containing several lines and text, and request you select the closest-aligned images. After this is done, do another image print to check for improvements.
Normally, the printer uses the black cartridge for text and the CMY inks for images (even for black on photo and specialty paper). So when you are printing normal text pages on plain paper, only the black ink is used. A good check for this would be to print a normal text page, but select photo paper in the driver to trick the printer into using the CMY inks to make a substitute black text page. If this looks ok, then you are having issues other than cartridge alignment.
May 24, 2008 | Canon BubbleJet i560 InkJet Printer
Color ink runs out too fast
See this link. Type "print using black ink" in the Search box and click the Search button. Select the appropriate option for your computer's OS. Note that you can only do this using plain paper. (I think the printer will still use a little color ink when doing print head cleanings. If you leave the printer powered on all the time, this will reduce the number of print head cleanings.)
May 19, 2008 | Canon BubbleJet i560 InkJet Printer
Canon i560 won't print black text anymore
I have now found the solution elsewhere in the internet: black text only prints on the Canon i560 if selct "normal paper", but not,for instance, if you have "professional photo-paper" selected.
Apr 16, 2008 | Canon BubbleJet i560 InkJet Printer
Canon i560s printer - color problems
I changed the black ink in my printer, now it will not print everything in black!, I changed it back to the old ink, but still not printing black ink, what do I do?
Mar 23, 2008 | Canon BubbleJet i560 InkJet Printer
Balck ink not working
The printing head have some dryed black ink inside.
Look at Canon i550 section in this website. I have posted several answers on how to clean the print head.
Feb 09, 2008 | Canon BubbleJet i560 InkJet Printer
Won't print text or test page
try with diffrent printer driver and see. bye
Sep 22, 2007 | Canon BubbleJet i560 InkJet Printer
Canon BubbleJet i560 InkJet Printer Logo
608 people viewed this question
old marine
old marine
