Question about Toys
Loose wire inside head of fur real large butterscotch pony? It's grey and blue with a small white fitting on the end. Should this be connected to somewhere? Or is a sensor .
  • 4 more comments
  • Matthew Simmonds
    Matthew Simmonds Sep 29, 2015
    Hi i have the same problem i see this was 2 years ago did you ever find out where it went?
  • Kimberly Inman
    Kimberly Inman Oct 16, 2015
    I just acquired smores second hand, head detached for shipping. Once attached the left ear and left eye did not work. When I detached the head again, hoping to find something loose or disconnected, I noticed thus small gray and blue wire with a fitting on the eND but nothing to plug it into. While searching the net for a wiring guide, I noticed this post, so I attached a picture.
  • Justin Sipes
    Justin Sipes Apr 18, 2016
    Same issue here. Did anyone get an answer on how to fix or what the wire goes to ?
  • Farm Sitter
    Farm Sitter Aug 06, 2017
    Did anyone ever find this answer? Also has any ever found the sensor to make the gallop sound work?
  • Edward Jones
    Edward Jones Aug 15, 2017
    Where does it goooooooo?!?
  • Edward Jones
    Where does it goooooooo?!?i
    Problem Solver:
  • 6 Answers
I need a picture, Mam. But I assume it needs to be connected to another wire, and I am so very sorry if I did not help at all.
Posted on Dec 30, 2013
2 Suggested Answers
jacksparr689
SOURCE: I need a battery compartment for butterscotch fur
I found one of this on a garbage deposit. I opened the battery box and it was completly destroyed. A good technician could restore all the conections on this...not a big deal, but I'm not LOL, so I took out th two main cables (red and black) by take out the three screw placed where the battery box snaps in. The I conected a 9v battery directly on this two wires and voila! the pony is alive again
Posted on Apr 16, 2013
How do you take the head off
This video shows exactly what you need to do. Requires a little handyman skills.
Hasbro FurReal Friends Smores Butterscotch Pony Head Removal How To...
Jan 10, 2015 | Hasbro Fur Real Friends Smores Pony
Saddle, carrot and brush for butterscotch pony
Check oksanas*heirloom*treasures on eBay for replacement tack. You can get replacement carrot and adoption certificate on eBay from bet_em on eBay.
Nov 16, 2011 | Hasbro Fur Real Friends Smores Pony
The tail broke on my butterscotch pony and I would like it fixed. What can I do? Thanks
Had the same problem and the fix is easy. Hopefully, the tail snapped off at the base of the plastic plate on the tail. If so, go to a hardware store and buy 1 ft. of plastic tubing with 1/4" inner diameter and 3/8" outer. Cut off a piece about 1 1/2". Now, look at the base of the tail and you should see a small screw that holds in what remains of the stub that broke. Unscrew the screw and remove what is left of the stub. KEEP THE SCREW. Now drill a small hole thru the plastic tube about 1/8" from the end. This will later be inserted into the tail and the screw will go through the hole. Next, take a hair dryer and heat the undrilled end of the tube to soften it and push it on to what is left of the broken stub inside the pony. It will be a tight fit which is what you want. The end of the tube with the hole should be just visible. Now slide the tail over the end of the tube and insert the screw. I just did it today and it works good as new! If the tail is too far away from the body of the pony, carefully remove the tube and shorten it. Since you bought a 1 ft. tube, you can have several trys to get it right! Total cost for the tube was 21 cents. Good luck! Kip V. Tryon, NC
May 25, 2010 | Hasbro Fur Real Friends Smores Pony
Replacement parts
Not sure about the ear but here is how to repair the tail. Had the same problem and the fix is easy. Hopefully, the tail snapped off at the base of the plastic plate on the tail. If so, go to a hardware store and buy 1 ft. of CLEAR plastic tubing with 3/16" inner diameter and 5/16" outer. Cut off a piece about 1 1/2". Now, look at the base of the tail and you should see a small screw that holds in what remains of the stub that broke. Unscrew the screw and remove what is left of the stub. KEEP THE SCREW. Now drill a small hole thru the plastic tube about 1/8" from the end. This will later be inserted into the tail and the screw will go through the holes. Next, take a hair dryer and heat the undrilled end of the tube to soften it and push it on to what is left of the broken stub inside the pony. It will be a tight fit which is what you want. You will probably need to twist the tube gently while applying firm pressure on it to make it slide over the stub. The end of the tube with the holes should be about even with the outside top of the white plastic hole and the tube holes should be level, looking at it from side to side. This makes the alignment of the screw hole to the tail correct. Now slide the tail over the end of the tube and insert the screw. I just did it today and it works good as new! If the tail is too far away from the body of the pony, carefully twist and remove the tube and shorten it. Since you bought a 1 ft. tube, you can have several trys to get it right if you cut it too short! Total cost for the tube was 21 cents. Good luck! Kip V. Tryon, NC
May 09, 2010 | Hasbro Fur Real Friends Smores Pony
Hi, Where can I buy a new tail for my daughter's Butterscotch pony Furreal Thanks Michelle
Not sure where to buy a replacement but I just fixed mine today. Hopefully, the tail snapped off at the base of the plastic plate on the tail. If so, go to a hardware store and buy 1 ft. of plastic tubing with 1/4" inner diameter and 3/8" outer. Cut off a piece about 1 1/2". Now, look at the base of the tail and you should see a small screw that holds in what remains of the stub that broke. Unscrew the screw and remove what is left of the stub. KEEP THE SCREW. Now drill a small hole thru the plastic tube about 1/8" from the end. This will later be inserted into the tail and the screw will go through the hole. Next, take a hair dryer and heat the undrilled end of the tube to soften it and push it on to what is left of the broken stub inside the pony. It will be a tight fit which is what you want. The end of the tube with the hole should be just visible. Now slide the tail over the end of the tube and insert the screw. I just did it today and it works good as new! If the tail is too far away from the body of the pony, carefully remove the tube and shorten it. Since you bought a 1 ft. tube, you can have several trys to get it right! Total cost for the tube was 21 cents. Good luck! Kip V. Tryon, NC
Apr 18, 2010 | Hasbro Fur Real Friends Smores Pony
Furreal pony, Butterscotch, Head floppy/leans left
There is a smaller "u" shaped spring in the middle of the neck mechanism that I found one side was snapped off. Looks normal, but it's broken. I made one out of a coat hanger for temporary purposes and it works like new! I will order one from Hasbro. Hope this helps!
Dec 09, 2008 | Hasbro Fur Real Friends Smores Pony
Toys Logo
546 people viewed this question
Top Toys Experts
ray gallant
Are you a Toy Expert? Answer questions, earn points and help others
