Vibradorm remote initialisation - Televison & Video
How do I reprogramme my vibradorm remote for bed
Just put upside down, pour a gallon of gasoline over it, and use a cigarette lighter to test the condition.
Aug 21, 2016 | Televison & Video
Alarm activated and is unable to deactivate
REMOTE KEY INITIALIZATION For this type of key.
The initialisation of the FZV keys is required to establish the Lock/Unlock signal synchronisation with the GM V. The initialization procedure provides the GM with a key identification number and a "rolling code" for each key. If the initialisation is not performed, the GM will not respond to the key signals. Up to 4 remote keys can be initialised. They must be initialised at the same time. Key initialisation is only possible with the vehicle unlocked.
Procedure:
1. Close all doors and have all keys available.
2. Using key number 1, turn the ignition switch to KL R, then switch off within 5 seconds and remove the first key.
3. Within 30 seconds of turning the ignition switch to "off" Press and hold button #2 .
4. While holding button #2 , press and release ("tap") button #1 three times within 10 seconds.
5. Release both buttons. The LED in the key will flash momentarily. The GM will immediately lock and unlock the doors signalling a successful initialisation.
6. If additional keys need to be initialised repeat steps 3 - 5 within 30 seconds.
7. Switching the ignition to KL R completes the initialisation.
SERVICE NOTE:
The key memory function of the GM responds to the key identification number of each key. If the keys are not initialised in the same order prior to initialisation, the key memory functions activated by the keys will not be assigned correctly. Always initialise the keys in the same order.
REMOTE KEY INITIALISATION For this type of key.
The initialisation of the FZV keys is required to establish the Lock/Unlock signal synchronisation with the GM. The initialisation procedure provides the GM with a key identification number and a "rolling code" for each key. If the initialisation is not performed, the GM will not respond to the key signals. Up to 4 remote keys can be initialised. They must be initialised at the same time. Key initialisation is only possible with the vehicle unlocked.
Procedure:
3. Within 30 seconds of turning the ignition switch to "off" Press and hold the arrow button.
4. While holding the arrow button, press and release ("tap") the roundel button three times within 10 seconds.
5. Release both buttons. The GM will immediately lock and unlock the doors signalling a successful initialisation.
SERVICE NOTE:
The key memory function of the GM responds to the key identification number of each key. If the keys are not initialised in the same order prior to initialisation, the key memory function activated by the keys will not be assigned correctly. Always initialise the keys in the same order.
Apr 08, 2014 | 1996 BMW 540i
Plip battery spent
You remote (plip) needs new battery: CR 0523 (3V).
After a change of battery, it may be necessary to re-initialise the remote control. To do that, switch on the ignition and immediately press "lock" button on your remote control to trigger the action desired. This may take some ten seconds.
Sep 28, 2012 | Citroen C2 Cars & Trucks
Key fob not working
does the led on remote flash when pressed, if so try to initialise remote by inserting key in door barrel or ignition lockthen turning key, whilst doing this press and hold lock/unlock button. the led on dash should flash to show the key has been initialised, then remove key and test operation. If none of this works then a new remote and coding to car is needed by your nearest dealership
Apr 29, 2010 | 2000 Porsche Boxster
I recently reset my ps3 and now my bluray controller wont work
you go to settings- and then search for something called bluray remote control initialising or something.
and from then you can intitialise it. hope this helps
Jul 25, 2009 | Sony Playstation 3 (PS3) Console
Failed to initialise hardware
Hi
It could be a problem with the drivers for the tv tuner card....
Pls uninstall the drivers and then reeat the tv tuner card and then reinstall the drivers for the tv tuner card.
Restart the computer after renstalling the drivers and check if it works.
Feb 25, 2008 | Computers & Internet
Toshiba RD850-T Error Message14
try hitting the diplay key (couple of times/rebooting) Solved the problem for me...
Jan 21, 2008 | Toshiba RD-XS34 DVD Player/HDD Recorder
Televison & Video Logo
96 people viewed this question
Top Televison & Video Experts
