Question about Boss Rc 50
The XLR-input distorts very fast
I hope it's not because it's to much signal for the station: I have a good mixer with three instruments going into the jack-input. a synth goes into the mini-jack. when the song runs and I now sing only a little loud it distorts directly. between microphone and station is also the Boss-vocal performer. I really wonder if some input is broken or if the station can't handle it!? also do you know what kind of WA/AW-24bit (german) are in the station? I think they might be no good. Any help? thx!
  • 238 Answers
XLR inputs often have a pad (attenuator) that is switchable for signal level.
Posted on May 24, 2017
3 Suggested Answers
  • 5603 Answers
SOURCE: boss micro br not converting all the tracks in the song to MP3
You have to "mix" the tracks to create a final work before saving the file.
Posted on Jan 31, 2010
  • 96 Answers
SOURCE: one of the jacks is busted but i dont know which
use boss power supply
Posted on Jul 04, 2010
How to connect my mixer to my guitar combo
You don't mention the make and models of the gear you're asking about, so we can't address your pacifist setup. However, most mixer outputs are going to be at line level, whereas a guitar amp inputs are instrument level. Line level is way hotter than a guitar amp can handle. You need to find a mixer that has a -10dB output to do what you're asking.
Jun 24, 2016 | Music
How do i connect my keyboard and my laptop?
Download USB MIDI driver for yamaha from yamaha website,and install to laptop.
Make sure the POWER switch on the instrument is set to OFF,then use an AB type USB cable to connect the instrument to the laptop.
After making the connections, turn on the power of the instrument.
Laptop will immediately notify that new hardwares is connecting and automatically install the drivers. Wait until the process is finish.
Thats all. In Ableton,the setting MIDI input must be set to USB MIDI.
Aug 19, 2015 | Yamaha PSRE413 Keyboard
Schaller pickup wont work
This is a high output piezo pickup but won't give line level signals expected by some inputs so I would guess you may be going into a line input. If so try a mic input (XLR) instead and see if that works.
Mar 30, 2014 | Peavey XR 8600D Class D Powered Mixer
HOW TO WIRE GEMINI GRAPHIC EQ 3000 TO behringer djx750 proffessional MIXER
Line level output of the mixer would go into the line level inputs of the EQ, and the EQ line level outpputs to the line level inputs of the amplifier. If you are faced with a mix of unbalanced inputs or outputs, to balanced inputs or outputs it gets a little complicated because you need to matrix the balanced signal to unbalanced load and vice versa. There is no single answer to doing this either.
RCA jacks are unbalanced, 2 conductor 1/4 inch connections are unbalanced most of the time. XLR and 3 conductor 1/4 inch jacks and plugs can be either balanced or unbalanced.If either are wired so left and right are a single ring or tip on the 3 conductor 1/4 inch jack, it is unbalanced and they would share a common ground lead. XLR wired with one pin common with shield and right and left have a single conductor on the plug or jack, that is unbalanced.
Apr 26, 2012 | Behringer Pro Mixer Djx750 Professional 5...
Getting distorted sound when connecting from mac pc headphone jack to 1/4" line in input
You are connecting a NOISY unbalnced line to a balanced input. Buy a DI box and then use an XLR to XLR to the mixer inout and run the MAC into the DI with "ground lifted". You will need to make a resistive mixer between the headphone jack and the DI as well. The headphone jack is STEREO. You COULD try a STEREO 1/8 inch splitter to 1/4 inch left and right cable... you MIGHT get away with that. Right now the left and right amps in the MAC are fighting eachother.
Sep 25, 2011 | Samson New Samson Mdr-1064 10 Channel...
Mixer does not sound "clean"; almost distorted
If more than one input is bad, then problem has NOTHING to do with the preamps. Check list:
1. Make sure you are using BALANCED lines everywhere... either XLR or TRS cables.
2. Make sure ALL interconnected equipment, mixers, amps, powered speakers, CD players, etc. are ALL powered from the SAME receptacle or power distribution unit.
3. Do proper setup. Select each channel PFL and set the trims so the indicator never goes into clipping, but is in the 70% range during max volume input to mics, etc..
4. During operation the sliders should be at least 50% up on used channels and the mains. Setting of levels throughout the system is important for noise free operation. Using EXCESS gain at some point results in distortion and noise. Using sliders near the bottom position results in poor signal to noise ratio.
Now re-read #2 above... and believe it. I have seen a lot of equipment blown due to ground bounce of building power. That is why the pro's run power back to their mixer from the area where the amps are powered.
Apr 28, 2011 | Behringer EURORACK UB2442FX PRO Mixer
I have a Behringer 1202fx and I'm going to use it with a pair of Harbinger APS15. The line inputs on the APS15 are unballanced R&L RCA and XLR. The Behringer 1202fx mains are 1/4" unballanced...
Personally I would run the RCA outputs to the RCA in on the APS.
If you insist on using XLR from the APS to the board (like through a snake etc) I would higly recommend using XLR to 1/4" adapters. These things have wonderful little transformers in them (yes, wire wound transformers) that do the 1/4" to XLR conversion really nicely so that you can run your signal through the snake or just so that you don't get the hum and distortion that can be associated with unbalanced signal transfer.
You want a HI-Z unbalanced to LO-Z balanced adapter.
Not always easy to find, but if you absolutely cannot locate any, I have a couple in stock.
I suggest you look around though, because mine aren't cheap!
Feb 27, 2011 | Behringer Xenyx 2222fx Premium 22 Input...
I record a podcast with the 8track multimix usb Alesis. I use one XLR - Jack input and the rest XLR-XLR. There are 4 inputs being used in total. I seem to be getting alot of hiss and buzzing from the...
What is the source of the input signals? These need to be balanced lines and the sources need to be balanced. If you happen to be using condenser mics, you probably haven't turned on the Phantom Power in the mixer. If you are recording from a sound card in the PC, those have a lot of noise and are unbalanced and you have to use DI's with ground lift ahead of this mixer.
Feb 08, 2011 | Alesis Multimix 8 USB 2.0 8-channel Mixer
How do I attach power amp to 1832 mixer
There are a number of configurations for a mixer like the 1832, the most common are PA system and Recording system. There are Main output jacks which carry the mix as summed in the main faders. These in a PA system would feed the pa amplifiers which drive the house speaker system for the audience. These connectors are XLR 3 pin type on the rear, intended for professional pa amplifiers which use balanced +4dbv line input level. Amplifier which have 3 pin XLR connectors for input signals can accept that high level signal. For home style HiFi amplifiers, the signal level is nominally -10DBv and balanced or unbalanced signal lines with 1/4in diameter phone plugs which are connected to the mixer by way of a second set of Main output connectors which are 1/4in phone jacks. Use whichever amplifier input level your amp has.
If you are not using it as a main PA house mixer, but using it for recording, the main output connectors go to a 2 channel recorder or computer sound card recorder. The power amp and your monitor speakers are connected to the connectors labeled "Control Room" (CTRL Rm). These output are useful for recording because the signal through the mixer can be monitored from several buses, Solo, main mix, selected by buttons provided. The buttons only affect the signal heard through the control room monitors, and not the main output which only sees the main mix so selecting "solo" does not interrupt the signal going to the recorder while the engineer in the control can be checking other signal paths through the board.
Jan 21, 2011 | Behringer Xenyx 1832fx Mixer 18 Input 32...
How do you use the mixer with a regular combo amp and stereo mic cable?
This is not hard to do, but it will require some adapters. Hosa company makes adapters to accomplish this. For example, if your Stereo mic has "1/4 inch male phone plugs" Hosa makes and adapter that has 1/4 inch female plug to Male XLR connectors. The Mackie, and just about every mixer in the world these days has Female XLR connectors for it's microphone inputs. So that will handle tha.
I'm not sure what you mean by the "combo" amp. If it has XLR inputs you can use Tip Ring Sleve male output jacks to the output. If your amp as conventional 1/4 inch female input jacks. Than a simple
1/4 inch Male to Male Guitar Cable will work fine. DON'T USE A SPEAKER CABLE as it is uninsulated and you will get 60Hz hum.
I hope this helps,
That looks like a great quality mixer you have!
Happy New Year,
Jan 01, 2011 | Mackie 402vlz3 Mixer 402vlz3 402vlz3 Vlz...
Boss Rc 50 Logo
20 people viewed this question
Top Boss Music Experts
Michial Gueffroy
Vito Vacirca Jr.
shaun taylor
Are you a Boss Music Expert? Answer questions, earn points and help others
