Question about Sylvania DVC840F
Sylvania model DVC840F. When using DVD or CD video and audio works fine, but when I use VCR the audio works fine, but no video. Please help---Thanks!
sandrew
  • 2961 Answers
SOURCE: HELP! I can't figure out how to Connect my Sylvania DVD/VCR Combo to my older TV
Even if you do get it connected you cannot copy from vhs to dvd as you have bought a vcr recorder with dvd player, not a dvd recorder. You can only record to the vcr tape from a dvd, in the players controls.
Posted on Feb 08, 2007
SOURCE: dvd/vcr sylvania combo
did a few google searches and suggestions were made to buy a**ther vcr...** way to fix the vcr heads. thanks anyways!
Posted on Mar 10, 2008
DOCTOR VIDEO
  • 131 Answers
SOURCE: Sylvania DV220SL8 DVD Player/VCR Combo
You could try cleanining it first that would be a simple solution
Go buy a video head tape or due it yourself radio shack has video head cleaner. Remove cover unplug clead small silver audio head on right side. good luck
doctor video
Posted on May 18, 2008
SOURCE: dvd loading
mine kinda has the same problem but it only happens with one movie Hairspray but it doesn't say error it just says loading for hours until i restart this system in order to get the DVD out. Need Help!!
Posted on Jun 19, 2008
  • 3 Answers
SOURCE: the vcr on my sylvania vcr dvd combo DVC840E eats
Clean the tape path, that any thing the tape come in contact with. there is a roller that presses the tape against a metal guide. The roller should be dull not shining.
Posted on Aug 04, 2009
Why does my vcr always eject as soon as I put a tape in, getting the tape stuck in the machine in the process?
wow a vcr im going to bet this one is ten + years old , as with any item that has ten + year old rubber parts inside it , this id say is your problem as the eaten tape is the tip off for this as a tape drive problem
Oct 30, 2015 | Sylvania DVC840F
Low volume on tv
Its speaker, audio output circuit etc shound be suspected. Contact any service technician.
Aug 24, 2013 | Sylvania 6720FDG 20" TV/VCR/DVD
Im having problems hooking up thru vcr/dvd player
The correct setup depends on whether you have a cable/satellite receiver and whether you want to record to and playback from the VCR. If you are using a cable/satellite receiver, this needs to be connected to both the TV and the DVD/VCR if you want to record. The DVD then needs to be connected to the TV via the video and audio out sockets on the back of the DVD/VCR for playback.
I can let you know exactly which connections to use and where they should all go, but I need to know the following details as otherwise I don't know which sockets/connect you have available.
1. Brand and model number of TV
2. Brand and model number of DVD/VCR
3. Brand and model number of any cable/satellite receiver if you are using one.
Please confirm these details and I will try to assist you further.
Regards,
BElectric
Dec 16, 2010 | Sylvania 6842PF 42 in. EDTV-Ready Plasma...
No video; audio OK. Hooking up to new (used) TV.
Hi... The 3 plug cable is better as long as you match all the colors at both ends.
If there is left over stuff on the laser lens , it wont read the disk
Apr 22, 2010 | Sylvania DVC840F
I need to find Universal Remote Code for Sylvania DVC840G Player
Check www.remotecentral.com for the manual and codes. Also try scanning universal remote codes to see if another brand code that will work. Otherwise you will need a newer remote or a updateable one.
Mar 15, 2010 | Sylvania DVC840G DVD Player/VCR
Sylvania vcr/dvd installation
!st) The antenna INPUT::RF (black wire usually from "cable TV", "Dish TV", even ANTENNA air wave reception,etc.) into INPUT of VCR\DVD, OUTPUT of VCR\DVD to TV RF input.
2nd) If you have INPUT\OUTPUT to what are called " RCA " jacks on your TV, on the front or on the back, then any & all output jacks from VCR\DVD goes to INPUT\OUTPUT of the TV.
In other words:: output of audio on VHS\DVD to input of audio on TV( RCA jacks). Output of video on VHS\DVD to input of video (RCA jacks)
Hope this helps
Aug 14, 2008 | Televison & Video
doctor video
May 17, 2008 | Sylvania DV220SL8 DVD Player/VCR
Sansui dvd/video model # VRD4001
are you using the vcr/dvd out jacks on the back?
Feb 19, 2008 | Sansui VRDVD4001 DVD Player/VCR
Tracking won't zero in
try cleaning the heads with a head cleaner or even a high grade blank tape letting it play for 20 mins.
hope it helps
wg
Feb 02, 2008 | Sylvania DVC840F
VHS has audio but no video
we cannot get the vcr portion to work only the dvd player4.gif works what are we doing wrong?
Have the same problem? Click Here
dc2eb76.jpg MikeNJ1964
Rank:guru_s.gif Guru
Rating: 88%, 431 votes
On some of the DVD/VCR combo units, the VCR output is only available through the RF jack (channel 3), standard video1.gif (yellow) RCA jack and S-VIDEO jack. If you are using the Component jacks, the DVD side will work but the VCR will not. This is because the quality of video recorded on VHS tapes is so much lower than component quality video.
Thank you for rating this solution.
Nov 26, 2007 | Televison & Video
Televison & Video Logo
20 people viewed this question
Top Sylvania Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
