Question about HP Officejet 6310 All-In-One InkJet Printer
Officejet6310 camera icon flashing
Please help...if can`t solve, throwing out. After starting up, all display lights go out except power button light and camera icon light is flashing...locks up the capability of power button acknowledging your powering off. Have to unplug. Doesnt help to reinstall software and plug in USB when asked.
  • Anonymous May 22, 2009
    i have same problem, i was cleaning up ink spill
SOURCE: troubleshooting on hp printer/scanner/copier
This looks like either there is an paper jam or carriage jam on the unit,
Check the rare access door weather there is a paper jam.
Remove the cartridges and try moving the carriage( the cartridge hold) left to right and right to left and check if its moving freely.
After these try disconnecting the power cable without turning off the unit and hold the On button for 15 secs and then plug in the power cable while your hold the on button.
This should probably fix the issue.
Please do let me know if there is still an issue.
Posted on Feb 19, 2008
taki99
  • 112 Answers
SOURCE: HP C4180 orange light
your cartage is now damage relapse it your problem will be solved
Posted on Dec 17, 2008
  • 27 Answers
SOURCE: hp 845c orange light keeps flashing
When the orange light is flashing, either paper jam or ink problem is happening.Try unloaging & reloading the stack of paper in the main tray. Remove & reinsert ink cartridges in the printer. You may also clean the contacts of the cartridge and inside the product.
Posted on Mar 09, 2009
  • 96 Answers
SOURCE: After pushing Power button the
remove the rear cover that conceals your main pca. turn on your printer and check the cpu fan. if the fan is not rotating up to speed, this can cause your problem. you can purchase a similar fan at microcenter or you can search online for one. shouldn't cost you more than $10.00. you can purchase it direct from HP the part number is (if they haven't changed the number) Q1271-60160
Posted on Sep 28, 2009
  • 142 Answers
SOURCE: All the lights on the buttons flashing with error message
Please perform the following steps:
* Take the cartridges out of the unit. Dis connect the unit from the computer.
* Unplug the power cord from the back of the unit.
* Press OK and Cancel buttons together while connecting the power cord back to the unit.
* Now turn on the unit and verify the result.
:) Dr Tony
Posted on May 12, 2010
I lost a connection of tomy digital viedo srv400
Hello. I think I've worked this one out. Turn both on as usual. Go to the main menu screen on the parent unit and click on add camera icon. Then click camera one.... but before clicking the add button, go to the camera itself and click the power button as follows - two short clicks, then hold the power button - the green light will start flashing. Keep holding the power button on the camera and click the add button icon on the parent unit. They should pair. The camera may turn off then, but it should be paired - simply turn it on again. Worked on mine, but took a long time to work out how to fix. Please email if you need any help. hbmb8@bigpond.com
Oct 26, 2014 | Baby Gear
Flashing green light
hello,are you sure that you have not left your camera flash on,and virtually killed off the battery?as the zig zag icon usually refers to mostly flash related aspects of most modern cameras,all cameras need a certain base level battery power,before they will switch on for use,but may well display all manner of icon's and oddity's when the power is all consumed.hope that helps, cheers.
Jun 02, 2013 | Nikon COOLPIX P510 16.1 MP CMOS Digital...
Inspiron 1501 wont start
Does it look like it is running with the exception of the screen being black?
Does it ever post anything on the screen when you hit the power button?
Beep tones and blinking lights tells thetechnicians what is going on with the laptop and why it is not booting. Most times it's a motherboard issue when you hear beeps or blinking lightscontinuous.
Apr 06, 2012 | Dell Inspiron 1501 Laptop
Hoover dst 10146p fault
Ken did you solve this problem with the machine as mine has just started to do the same thing, thanks
Feb 06, 2012 | Hoover Washing Machines
I downloaded photos on computer ,now I get card not initialized ? what do I do? Its a fujifilm camera..
Insert the memory card into the camera to format it if you are receiving error messages such as "Card Error" or "Card Not Initialized." Press the "Menu/OK" button then press the left/right directional button to select the "SET" option. Press the up or down direction button then press "Set Up" and press the "Menu/OK" to access the setup screen.
Press the down directional button to select "Option 1" and scroll down to the "Format" option. Press the right directional button to select the format option. Press the "Menu/OK" button to start the format process.
Move away from the target or brighten the lights if the auto focus does not work. Rotate the scenery mode dial at the top of the camera to the "Auto" mode. Press the "Flash" button to enable the flash mode to provide additional lighting if necessary.Manually set up the Fuji E500 camera with your computer if the computer does not automatically detect it. Connect the camera to the computer using the supplied USB cable and power on the camera. Click the "Start" button then click on the "Computer" option and select the FinePix Icon. Choose next on the download wizard to start the download process.
  • 2 Press the down directional button to select "Option 1" and scroll down to the "Format" option. Press the right directional button to select the format option. Press the "Menu/OK" button to start the format process.
  • 3 Move away from the target or brighten the lights if the auto focus does not work. Rotate the scenery mode dial at the top of the camera to the "Auto" mode. Press the "Flash" button to enable the flash mode to provide additional lighting if necessary.
  • 4 Manually set up the Fuji E500 camera with your computer if the computer does not automatically detect it. Connect the camera to the computer using the supplied USB cable and power on the camera. Click the "Start" button then click on the "Computer" option and select the FinePix Icon. Choose next on the download wizard to start the download process.
  • Read more: How to Troubleshoot a Fuji E500 Digital Camera ' eHow.com http://www.ehow.com/how_7636592_troubleshoot-fuji-e500-digital-camera.html#ixzz1OOyWsAIU
    May 31, 2011 | PNY Optima Pro 2GB Secure Digital Memory...
    Hi I have a fuji finepix camera. On the display screen there is a yellow icon of a camera with an exclaimation mark and vibration marks. Please explain what this is and how I get rid of it. Thanks
    basically it means the camera is finding it hard to focus as there is not enough light. Set the camera to automatic and turn on your flash. when you put the flash on the yellow camera icon should disappear and you will see the picture in the viewfinder is a lot sharper. I have the same camera and had the same problem. Turning on the flash solved it.
    Sep 04, 2010 | Fuji Cameras
    How do you turn the flash on? (with the vivitar vivicam 8018)
    Your camera has a built in flash function which enables you to take photos when the light condition is not good.
    1. Press the Up button. (for reference of buttons, please see the below figure mentioned)
    2. Press the Up button once until you see the icon appear on the LCD screen. This indicates that the flash is forced on.
    3. Press the Up button again to change to the auto flash function.
    4. The icon will appear at the top of the LCD indicating that the auto flash is turned on and ready to use.
    5. Press the Up button again to change from the auto flash to the red eye function.
    6. The icon will appear on the LCD indicating that the red eye reduction function has been activated.
    7. To turn off the flash function, press the Up button again until the icon is displayed on the LCD.
    Note: A “Low Power” message will appear on the LCD screen, if you select the flash function when the battery power is insufficient. To continue using the camera with the flash, please change new batteries
    Feb 13, 2010 | Vivitar ViviCam 8018 Digital Camera
    Camera will not take photo
    I don't know which shooting mode you are in, but the red shaking camera icon indicates that based on the settings that your camera is in, you may experience camera shake (which is your image stabilizer or "is" in action). The yellow blinking indicator light means that your camera is having a hard time achieving proper exposure and that the shutter speed with be slowed down to reach a proper exposure. Extending the shutter speed means that you are at risk for camera shake (i.e. blurry image).
    Solutions for this are:
    • increase ISO
    • use a tripod
    • use flash
    Hope this helps!
    May 31, 2008 | Cameras
    A drop image on screen
    hi i have panasonic NV DS 65 initially when i power on the cam it started then after 5 to 10 sec the power light automatically flashes and the buttons on camera doesnt work any more. but now the problem has got worsend the powen light keeps on flashing and no buttons work moreover a drop image is flashed on the screen.
    plz have me solve my problem
    sam_rav
    Jan 24, 2008 | Panasonic NV-DS65 Mini DV Digital...
    HP Officejet 6310 All-In-One InkJet Printer Logo
    199 people viewed this question
    Ben Johnson
    mukhtar21 shaikh
    mukhtar21 shaikh
