Question about Acer Computers & Internet
Acer Q35t-am Motherboard
How does one figure out where the 1 pin is on the front pannel connection on this series of boards
    Brigadier General:
  • Acer Master
  • 3,400 Answers
map9966
  • 2351 Answers
SOURCE: front pannel connection on the mother board d815eea2 motherboard
Hi Billy, please use the manual to help guide you. Turn to page 33. If you no longer have the user manual please download it from this link: http://download.intel.com/support/motherboards/desktop/d865gvhz/sb/c70845001.pdf
You will need adobe reader to view the manual. You can down load adobe for free at this link:
http://www.download.com/Adobe-Reader/3000-2378_4-10000062.html?hhTest=1
Or directly from Adobe. http://www.adobe.com/products/acrobat/readstep2.html
On pg. 3 is a picture of the motherboard's front panel pin connections. Item "C". (Front Panel pin to case LED's).
Armed with this information (Pictures), you can plainly see the pin numbers.
Page 4 shows you which is positive + & which is negative - pins.
Do not be fooled by the manual name. Intel often groups like motherboards into one manual. This manual does cover Intel's D865GV & D865GVHV motherboard. The second toughest thing to do is find which case wires or positive & which are negative.
This changes from case to case. Look at all your front panel wires. Most common ground is white in color. Positive wires are colored except internal case's speaker 2 wire. Black is negative.
Good luck Billy!
Hope you find this helpful.
Mike
Posted on Aug 08, 2008
compdoctor20
  • 172 Answers
SOURCE: Connecting the case to my motherboard
Pin arrangment is Industry Standard Architecture.....
pwr led pwr sw N/C
X X X X O
X X X X O
hdd rst N/C
translated this is top row left to right ...... power led, power switch no connection
Bottom row is left to right........ hard drive, reset, no connection
Note: not all computer cases have a reset button, also the connectors for power led and hard drive produce a light, if the light does not show, power off the pc swithc the cable rooun 180deg on the connector pins and reconnect.
Posted on Dec 05, 2008
sigma_shiva1
  • 188 Answers
SOURCE: front panel hook up
HEY MAN U HAVE SERIUS PROBLEM... OK THIS MAY SOLVVE U R PROBLEM....JUST DOWNLOAD U R MOTHERBOARD USERS MANUAL...AL CONNECTIONS ARE GIVEN THERE..EVEN FRONT PANAL SETTINGS TOO.... BEST REGARDS MAIL ADD- SIGMA_SHIVA1@YAHOO.CO.IN
Posted on Oct 10, 2007
map9966
  • 2351 Answers
SOURCE: Connecting front panel wiring to INTEL 845GRG Motherboard
Hello davideiker1, the Intel D845GRG MB manual is shared with another Intel board. (D845GBV MB). Go to this Intel site & download the D845GRG manual; http://support.intel.com/support/motherboards/desktop/d845grg/sb/cs-008873.htm You'll need Adobe reader to view the manual. Download Adobe from this link; http://www.adobe.com/products/reader/
See page 9 for motherboard layout.
The front panel connectors are shown on page 68, see item C.
On page 69 is, Table 31 shows the pin assignments for the front panel header. Front Panel Header (J9G1).
Pin 1 is power for the hard disk drive led, pin-3 is negative for the hard disk drive. Wire colors coming from the case are important. Look at all of the front case wires. The common color for each 2-pin connector will be ground. In most cases the ground wire is white, except for the internal speaker. Ground for the speaker is normally black. (This motherboards speaker is built into the MB, no hook up is needed).
Pin number 2 is positive for the case power led which lights up as green. Pin 4 is negative for the power led.
The reset switch is a bit different. Pin 5 is negative & pin 9 is positive, however if your case uses a two pin connector than connect pin 7 as ground & pin 9 for positive. The On/Off switch, pin 6 is positive & pin 8 is negative.
If this manual is not what you see on the MB, please advise.
Good luck davideiker1!
Need more information/questions post here.
Thank you for using FixYa.
Input, comments are welcomed.
Mike
Posted on Jan 22, 2009
  • 10 Answers
SOURCE: front panel to motherboard, ASRock P4i65G, connections
the power switch is on the 3 and 4 pins....the 7 and 8 pin are the reset pins. Trying it on wrong pins just won't startup the board but won't short circuit anything.
Posted on Jul 29, 2009
How do i connect the front panel (Powerbutton etc.) with my acer m7721 motherboard (FP1 Pins)? Thanks!
Look onto motherboard there is marked as a name of pw btn--power button and plug in front pannel pwr cable pin here
Sep 23, 2014 | Acer Aspire 7720 Notebook
How to switch on d915pwk desktop mother board?
You will either need to connect the front pannel connector on the several pin located on the motherboard or you can short circuit this by using a pen or screw driver and contact the 2 red pins (on the front pannel connector)
Aug 18, 2011 | Intel Motherboard
Can you please help me to connect the front pannel USB to my pentium4 mother board?
There will be pins on motherebord like :::::: and with these pin front usb writen. Now you have for clips one is one will gre
now connet (1) with one pins in a line and (2) pins with 2nd line.
Jul 12, 2011 | Intel Motherboard
Hi! i am using Intel DG33FB motherboard, i need the information about the connectivity of front pannel audio. for this it is Realtek HD audio port. i am having 5 cables set for the front pannel...
The L&R-Ret2&3 are common so only one needs fitting so for the speakers you only need to connect 3 cables. R-Out, L-Out and one return (either L of R). I'll comment back shortly on the mic pins for you.
Dec 23, 2010 | Computers & Internet
Configuring motherboard powerswitch leds reset
u will find front pannel connection pins on mother board. its in 2 lines. in onle row there is one pin slot idle. next to that vacant pin slot u insert reset sw, next to it insert hdd led, behind hdd led insert power led, next to power led (behind reset sw) insert power sw. thats it done
Jan 06, 2010 | Dell Dimension 2350 PC Desktop
Acer Aspire L100 does'n start. no lite in front pannel. Power supply has 19 volt and getting to motherboard
okay so 19 volts getting to the board, no boot, this could be a few things make sure the mobo is securely grounded (some boards are picky) make sure that all the cables (20 pin connector and 4 pin connector if there) are connected all the way.
If you need further help, reach me via phone at https://www.6ya.com/expert/joel_63c670a84e9f6a97
Oct 02, 2009 | Acer Aspire® (ASL-100UA380A) PC Desktop
How to connect front pannel
How about a picture? Pg. 46 in your manual.
Need manual, download from Intel. (Click on link).
http://www.intel.com/support/motherboards/desktop/RC440BX/sb/CS-013608.htm
Intel RC440BX Specification
Pg. 46
Basic rules case wiring. The color black is considered ground -. Power wires + can be any other color including stripped wires. (This is standard but case Mfg change to their own specification).
Pin 1 is + power for LED Hard drive green LED, Pin 2 is -/ground for Hard drive LED.
(Pin 3 is + power for LED Hard drive yellow LED, Pin 4 is -/ground for Hard drive LED).(See more options on pg. 47).
Pin 5 is + power for case On/off button, Pin 6 is -/ground On/off button.
Pin 7 is + power for Reset Switch, Pin 8 is -/ground for Reset Switch.
Once positive & negative pins has been located each connector follows in suit.
The Intel RC440BX front case connector is in an odd location.
The user will find it hard to connect front case LED connectors while the board in installed into the case.
Good Luck!
Mike
Apr 25, 2008 | Intel Desktop Board RC440BX...
Computers & Internet Logo
3,156 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
